Old 12-17-2012, 08:17 PM   #286
JRWooden
Oddometer: 4,303
Originally Posted by ebnelson View Post
I'm surprised I didn't see the GS911 CAN bus interface listed in toolkits. It will definitely be in my "toolkit" for next year's trips. Talk about removing some guess work! I wish I had a tool as useful as this for my Sprinter van (yeah, I know about the ScanTool II).
I have one and carry it with me on longer trips.
I have an old Thinkpad X61 with a solid state hard drive that does not care about being bounced around that is my road PC for e-mail and such ... I have the GS-911 software loaded and am ready. Many intermittent and frustrating faults will be logged in a way the 911 can give you some clues .... It will certainly not help in all situations, but since I own one, I always take it!
Old 12-17-2012, 08:20 PM   #287
JRWooden
Oddometer: 4,303
Originally Posted by MikeMike View Post
I am building a bypass cable out of the old controller, if you do not buy the available cable from aftermarket that lets you connect to your battery, the pump goes on and off with the key. If you buy the bypass cable that goes to the battery you have to unplug it when you stop.
I'm with you MM - before my next trip I'll be building an adapter cable to go from the Gerbing plug I have at the front of my seat to the fuel pump ... will just unplug it when I stop...
Old 12-18-2012, 08:47 AM   #288
ebnelson
Frozen rider
ebnelson's Avatar
Oddometer: 233
Will the GS9-11 tool inform you of a duff fuel pump controller?
Mine went in a Mexican mountain town on Saturday, 250kms from home so I did the Tim Cullis bypass procedure and rode it back. The troubleshooting was easy, it was obvious it wasn't the clutch nor the sidestand as it would turn over but no smell of fuel.
Used the Leatherman in my tank bag to do the job.
You need a T-10 and patience, or just use the longnose of the pliers on the Leatherman.
If you can afford it, a spare fuel pump controller is a good investment. But the bypass will get you back and if you roll your own cable you are going to be fine the next time it quits. I am going to zip tie the bypass cable I am making to a good spot under the seat and also a T-10 key with it, it will then be about a 90sec unplug and then plug and play.
Keep an old no good controller and gut it for the parts you need.
Glad to hear you were able to get running again. Your bypass cable seems like a good thing to put in an emergency spares kit. I would have expected a code of some sort to be generated from a faulty fuel pump controller, although it might not have been very informative. Certainly, on board micro-controllers do not replace mechanics. A prepared mechanic may want to use all tools available.
ebnelson is offline   Reply With Quote
Old 12-18-2012, 03:12 PM   #289
MikeMike
MikeMike's Avatar
Oddometer: 4,150
This is the interesting thing, will the GS-911 give you the fuel pump controller fault code or will it leave you guessing?
Old 12-18-2012, 05:37 PM   #290
JRWooden
Oddometer: 4,303
Good question ... for OBD compliant systems, the fault codes are somewhat standardized e.g. :
http://engine-codes.com/make/bmw
I've posted a question on the GS-911 asking if such a list exists for the bikes..................
Edit:
Got an answer quickly (for different model bike, but likely the same):
Error 10167 - Output stage to electric fuel pump
Symptoms: Idling irregular. Battles to start. Fault appears to start intermittently. Bike may start and ride, then will appear to have fuel starvation.
Repair: It is a little aluminum unit with fins on... (at fuel tank). Check the o-ring of this unit. Unscrew the unit and check for moisture in the cavity below it. Use moisture repellent spray and contact cleaner to clean this device.
If not corrected replace
This does seem to me to be something the computer can monitor to an extent.
If the computer tells the controller to throttle up or down and then sees that the pressure sensor on the fuel rail do something unexpected ... etc...
JRWooden screwed with this post 12-18-2012 at 06:05 PM
Old 06-18-2013, 06:09 PM   #291
Full Power
Oddometer: 1,538
The 2013 model of F800 has a few changes:
The 800 fasteners are just about all Torx vs hex or Allenhead.
So to work on the bike you need the following:
left control housing... ?? smaller than T10 ?
T20 throttle assembly
T25 fairings, control, body work
T30 muffler mount, signals, motor chassis, rotor
T40 triple clamp, brake pivot, rear rotor, brake line
T45 body, exhaust mount, fork axle pinch bolts, controls
..... Bar Ends changed to T45
Torx socket
E10 handlebar clamps
E12 Front Caliper brakes
13mm Chain tension bolt AND lock nut, requires TWO 13mm spanners
17 mm Front Axle
24mm Rear axle
...... Drain plug is now 10mm Allen wrench
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 06-19-2013, 03:47 AM   #292
MikeMike
MikeMike's Avatar
Oddometer: 4,150
I dont recall much hex nor allen on the old F8.
That list looks the same as for my F658 09 model.
Old 07-15-2013, 10:58 PM   #293
txtallywhacker
screw schedules
txtallywhacker's Avatar
Oddometer: 108
bag
where are yall finding those tool bags to velcro under the seat? i have searched high and low and cant find anything.
Originally Posted by drrags View Post
So I sashay on down to the local sanatorium with a cup full of poop.
txtallywhacker is offline   Reply With Quote
Old 09-12-2013, 05:30 PM   #294
Pangia
Pangia's Avatar
Oddometer: 229
Talking E8 Torx / Gear Shift Lever
Torx socket
17 mm Front Axle
24mm Rear axle
For the 2013 F800GS, I would suggest adding an E8 Torx Socket for the stock gear shift lever....that is what mine is...
2013 F800GS / Santa Fe to Cinnamon Pass Ride Report
Pangia is offline   Reply With Quote
Old 09-13-2013, 03:11 PM   #295
moto74
displaced
moto74's Avatar
Oddometer: 210
Left control housing is a T8.
moto74 is offline   Reply With Quote
Old 02-21-2014, 10:26 PM   #296
AussieRidin
Oddometer: 2
Just checked over my Australian 2013 F800 GS and here are a few tool specs which I haven't seen mentioned, or seem to differ slightly from other posts:
  • T9 for left side indicator/horn control housing screws
  • 16mm socket or ring spanner for rear sprocket nuts
  • 21mm socket(s) for the swingarm pivot bolt & nut (ring spanner won't fit in there)
  • 24mm socket for rear axle (ring spanner wont fit in there properly but might work if that's all you've got)
Cheers.
AussieRidin is offline   Reply With Quote
Old 02-23-2014, 02:16 PM   #297
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,686
F800GS Toolkit needs
I can get a 24 mm wrench on the rear wheel with no issues. Motion pro makes a tire iron with a box end 24 that is nice. For a lot of the oddball sizes that you don't use regularly a pair of vice grips or an adjustable wrench will do in a pinch. The vice grips make a good emergency shift lever and a million other uses.
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 02-24-2014, 06:11 AM   #298
sturgeon
sturgeon's Avatar
Oddometer: 946
+1 The MP tire iron/24mm works just fine; I've used it on the road numerous times.
Dyslexics Untie!
sturgeon is online now   Reply With Quote
Old 05-14-2014, 06:19 PM   #299
dirtysouthjacket
dirtysouthjacket's Avatar
Oddometer: 571
Thanks for the awesome simplification of what would take me a long time to figure out! Kudos to those that have posted. Trying to make sure I have a real kit for a few trips this year. Tired of just throwing tools in one of my cases that may or may not save me. So far I haven't needed much.
Did anyone figure out how long of a thin wall 5/8" spark plug socket is needed? Just trying to get the shortest one that will still work. There is quite a range for sale. Thanks in advance!
I may not have gone where I intended to go, but I think I ended up where I intended to be. -Douglas Adams
2011 F800GS Alpine White, 1998 KDX 200, 2000 KL250G Super Sherpa
DSJ's Shenanigans
dirtysouthjacket is offline   Reply With Quote
Old 05-14-2014, 06:59 PM   #300
Bumbobee
Bumbobee's Avatar
Oddometer: 171
Anyone got a complete tool kit list for the 2013 F800GS?
2013 BMW F800GS
Bumbobee is offline   Reply With Quote
Times are GMT -7.   It's 04:55 AM.
