Old 09-14-2013, 01:44 PM   #1
JRose OP
JRose's Avatar
Oddometer: 629
Cheaper Source for Seals??
Anyone found a cheaper source for common maintenance seals like axle and forks?
I'm all about OEM parts for some things, but don't feel BMW rubber is superior to other, especially as expensive as BMW seals are!
JRose is offline   Reply With Quote
Old 09-15-2013, 04:34 AM   #2
machinebuilder
Oddometer: 1,116
Probably the easiest is, when you have it down for maintenance next time take the seals to your local industrial bearing supplier, I fairly certain they are not a custom design/spec seal.
if you clean them and know where to look you can probably read the part number and search MSC Industrial, or McMaster Carr.
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Old 09-15-2013, 12:44 PM   #3
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,790
Just search the threads. The wheel seals are common SKF and other mfg's used on all kinds of bikes/atv's. Same with fork seals.
I've done them all on mine, sorry I don't have the links handy.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 09-15-2013, 06:11 PM   #4
jengel451
1 Cool MotherF#$cker
Oddometer: 799
small caveat.
the '13 and up WP fork seals are BMW proprietary voodoo unobtanium made on a moon of saturn.
jengel451 is offline   Reply With Quote
Old 09-15-2013, 06:21 PM   #5
STisma
STisma's Avatar
Oddometer: 148
The CR Seal, now owned by SKF,
worked for me on many axle, bearing and other seals.
Different story on the fork seals as they are very specific in design by the OEM.
SKF Seals
If it can go wrong, it will go wrong!!!
STisma is online now   Reply With Quote
Old 09-15-2013, 07:11 PM   #6
JRose OP
JRose's Avatar
Oddometer: 629
Originally Posted by jengel451 View Post
small caveat.
Ugh..... Krafty Germans......
Old 09-16-2013, 09:42 AM   #7
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Take the old seal to a bearing supply house.
They will read the measurements and hand you a new one if you give them about $2 bucks.
Same for any circlip.
But you'll be saving big money when you buy your bearings from a bearing supply house and not the dealer. Ask the dealer the price of a set of steering head bearings and then ask for a quality bearing cost from a good bearing supply house.
Cha-ching! Now you know how the dealer affords his old lady's bolt ons.
Old 09-16-2013, 10:18 AM   #8
JRose OP
JRose's Avatar
Oddometer: 629
Hahahaha.
Good idea! Maybe then I can afford some bolt ons for my old lady.
Old 09-16-2013, 11:28 AM   #9
der-Seppel
Dominik
der-Seppel's Avatar
Oddometer: 384
I don't know how you measure seals over in the US but this is what i ordered for my wheels at a bearing shop over here in Germany
DIN 3760 - AS 25,0x47,0x7,0 NBR 2,90€ ~3.87$
DIN 3760 - AS 30,0x47,0x7,0 NBR 1,70€ ~2.27$
Exploring Australia Ride Report
Where am I ?
en.dmoto.de Exploring Australia
der-Seppel is offline   Reply With Quote
Old 09-16-2013, 01:43 PM   #10
MikeMike
MikeMike's Avatar
Oddometer: 4,150
DIN 3760 - AS 25,0x47,0x7,0 NBR 2,90 ~3.87$
DIN 3760 - AS 30,0x47,0x7,0 NBR 1,70 ~2.27$
Seal measurements are often marked directly on the seal.
Old 09-17-2013, 02:50 AM   #11
machinebuilder
Oddometer: 1,116
Mikemike
there are the measurements
AS = seal type (I think)
25.0 = id
47.0 = od
7.0 = thickness
NBR = material
Old 09-17-2013, 03:41 AM   #12
der-Seppel
Dominik
der-Seppel's Avatar
Oddometer: 384
The type of seal you nead is DIN 3760 (DIN is the German Institute for Standardization like ISO)
http://en.wikipedia.org/wiki/Radial_shaft_seal
Where am I ?
Times are GMT -7.   It's 05:52 PM.
