Old 08-10-2013, 02:50 PM   #46
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,657
just rode the bike. i like it much better then the k60. brakes and accelerates better, and much smoother when leaned over. very impressed so far, i cannot wait for the 150. i only rode it 20 miles on pavement. i will do a good mixed surface test tomorrow.
150 k60 vs 140 karoo, both dismounted. i did not measure them dismounted, only mounted on the wheel. the 140 k3 is 1/4" narrower then the 150 k60, both inflated. nearly the same.
as you can clearly see, the 150 k60 is molded for a much wider wheel. it took 3x and a lot of lube to seat the beads.
the sidewall bulges a bit because the tire is stretched on the 4.25 wheel. it is not quite VW stunna stretch, but i can picture it cutting a sidewall if you are spinning while leaned over on a sharp rock. no biggie, 150 will fix that.
even stretched, the k3 is much more curved then the k60.
mounted on the bike
Originally Posted by DUCATIJAY
Don't quote me in your signature, you make me sound like an a55hole...
2015 Rides: Katie M Big girl, Berg Hoon'icycle, Katoom 3hunny (pic)
Rodknee is online now   Reply With Quote
Old 08-10-2013, 03:28 PM   #47
JRod152
will work for tires
JRod152's Avatar
Oddometer: 344
...on a 950SE
Nice pics Rodney. Thanks for posting.
I recently removed a set of K60's from my bike as well... not a fan.
I typically run knobbies (Pirelli Rally front & rear are a hard deal for me to beat right now), but I bought a Karoo 3 rear to see if I can make it last the 4,000 ish miles I try to get out of the front knobbie. I'd go through 2 rears to a front w/ the Rally. If it does, I'll be thrilled , especially for the price of the 140.
Unfortunately most of the riding I do is lame... commuting, gravel grids in the midwest, etc. But when I have the chance to hit the trails, sandy river bottoms, and other areas, I hate having a 50/50 tire on. For street use, the knobbies offer enough grip for me to ride to the edge of the knobs. I am lacking street binder power on the SE anyway, so the knobbies keep me in check.
The jury is still out as of now... only 1,200 miles on the rear right now, but I can say:
-Road grip is no worse than K60.
-Forward drive on gravel/dirt/sand is much better than the K60. The knob spacing I'm sure has everything to do w/ this.
-Side to side role is easier & more progressive with no surprises (yet).
-Lateral stability/traction isn't as good as knobbie but much better than the K60 or Mefo.
-Noise is not obtrusive for me at all. I'm use to knobbies though, so I dont expect it to be a Cont. TA.
-They are wearing evenly w/ minimal cupping
No feedback on sidewall stiffness, mud, or slab w/ heavy load yet.
If I had any balls, I'd run this set for my upcoming trip, but a part of me doesn't feel like trying to be conservative with my right wrist... 3,000 or so miles w/ lots of slab, twisites, and dirt/rock. Dare me? I'd kinda feel like a guinea pig, but it would be a good test. I'll probably be packing an extra rear along.
I'll post an update when I have more time on it.
"Never let the things you want make you forget the things you have"
JRod152 is offline   Reply With Quote
Old 08-11-2013, 03:59 PM   #48
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,657
i will mirror jrod's assessment of the 140 karoo. i put 180 miles on mine today, on a lot of mixed surfaces. seasonal use roads, big gravel, sand, small gravel, dirt and asphalt. there was wild spinning in the beginning, but i tapered that down as the day wore on. the tire is a marked improvement over the k60 offroad, at the expense of wear. the tire sticks WAY better then the k60 on the road, especially leaned over. last 30 miles was all pavement, as it was getting late and i needed to get home. i am fairly happy with it, especially for the price. i would have to see how the 150 wears, but if it wears at the same rate, i will run 140's instead.
10 miles
40 miles
80 miles
180 miles
the only issue i had, was leaned over in the dirt she felt a tad odd, most likely my fault since i am stretching the tire on the 4.25" wheel. all in all, i am very happy with the tire. as soon as i get a 150, i will post up.
Old 08-28-2013, 12:55 PM   #49
liftedlimo
PNW Stump Jumper
liftedlimo's Avatar
Oddometer: 66
We finished a 2800 mile, 95 percent slabbing it trip to Ak last week. My tire is done. We ended up driving to Prudhoe Bay in the car due to no tires and snow in the pass. Still was an amazing time.
'12 KTM 990 Adventure
'12 Yamaha Wr450F
'08 Can-Am Ds450X
'05 BMWDakar(sold)
liftedlimo is offline   Reply With Quote
Old 08-28-2013, 01:03 PM   #50
liftedlimo
PNW Stump Jumper
liftedlimo's Avatar
Oddometer: 66
The front tire is fine. I really liked these tires. On road they hum, and above 65 they scream! On road manners are great. The hundred miles or so of gravel we did they were very predictable and excelled. I am going to throw another one on the back for next year. Hopefully the trip south will have a much larger amount of mud and gravel.
Sent from my SCH-I535 using Tapatalk 4
'12 Yamaha Wr450F
'08 Can-Am Ds450X
'05 BMWDakar(sold)
liftedlimo screwed with this post 09-22-2013 at 12:42 AM
Old 08-28-2013, 01:20 PM   #51
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,977
We saw a 990 heading North to Fairbanks on roughly the 22nd as we were heading south......maybe it was you.....?....
We made it to Prudhoe..lots of ice coming back....
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 08-28-2013, 01:25 PM   #52
liftedlimo
PNW Stump Jumper
liftedlimo's Avatar
Oddometer: 66
That sounds about right. Couldn't of missed me, hid headlight, white helmet, orange coat, and lots of reflective tape. My buddy had a bright yellow helmet on his green kawi.
We heard it was a snow storm! Then it cleared up. Then it snowed again so we decided to take the car up. The the motorcyclists we meet up there were miserable haha
'12 Yamaha Wr450F
'08 Can-Am Ds450X
'05 BMWDakar(sold)
Old 09-13-2013, 08:53 PM   #53
bikepsych
Oddometer: 235
Any luck on the 150's? I'm waiting on one now.
BG
Bruce
Camarillo, CA
2015 Triumph Tiger 800 XCx
2009 Harley Road Glide
2006 Buell Ulysses
bikepsych is offline   Reply With Quote
Old 09-14-2013, 05:41 AM   #54
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,657
BG
nope. did you actually order one and was it shipped? from where?
Old 09-16-2013, 10:16 PM   #55
ericGSsti
ericGSsti's Avatar
Oddometer: 548
I'm getting a 150 fitted tomorrow here in Ireland ahead of me taking part in the Paddy Dakar this coming Saturday. I'll keep you posted.
2003 KTM 525 EXC
2004 KTM 950 Adventure S. (GO!!!!!!!!!!!)
IBA membership no.35934
"In the spirit of adventure, open to all riders and carrying a message of friendship between all men"- Thierry Sabine 1977 founder of the Paris Dakar -
ericGSsti is offline   Reply With Quote
Old 09-17-2013, 12:57 AM   #56
Unruled
950S
Unruled's Avatar
Oddometer: 120
2800 miles seems pretty poor to me... My Mefo's (SE) are at 8.000 now, and they're not nearly done. Have some funky characteristics now, but no need to replace them anyway.
Only thing I hate about them is that they're reaaally crap in the wet.
If you can't fix it with a hammer, you've got an electrical problem.
Unruled is offline   Reply With Quote
Old 09-17-2013, 04:01 AM   #57
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,657
Originally Posted by Unruled View Post
2800 miles seems pretty poor to me... My Mefo's (SE) are at 8.000 now, and they're not nearly done...Only thing I hate about them is that they're reaaally crap in the wet.
i would rather swap tires every 3k then have a bike that is scary to ride in the wet.
eric, when you get it mounted, post up some pics. i would like to see the profile of the 150, thanks.
Old 09-17-2013, 05:22 AM   #58
Unruled
950S
Unruled's Avatar
Oddometer: 120
Well yes that is a consideration. Still though, there has to be some middle way. 3k is pathetic
Old 09-18-2013, 09:55 AM   #59
ericGSsti
ericGSsti's Avatar
Oddometer: 548
150 Profile.
2003 KTM 525 EXC
Old 09-18-2013, 12:47 PM   #60
Rodknee
sensitive? who, me?
Rodknee's Avatar
Oddometer: 2,657
depends on use. i kill rear tires on the 990 in a 1000 miles or less. i know others who get 10k out of the same tires.
eric, looks good! could you get a measurement of the tread width? also, please keep us up to date on wear rate and riding style/conditions. thanks!
Times are GMT -7.   It's 03:35 AM.
