Old 08-09-2013, 08:09 PM   #91
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,530
Originally Posted by Navin View Post
Good news! Pods and a Area P tune work great on the 300! I'm running that set up, it is excellent!
Rear wheel is 4.25" wide, probably the same as the DRZ 400SM version. Check that but it must be within .25". My KTM SM wheel is 4.5".
How do the pods work when riding in the rain for 12 hours? How bout water crossings? I think I'd like to avoid them if I can.
Too tired to address all of the points above but I appreciate all of them and will reply tomorrow when I'm fresh.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 08-10-2013, 06:49 AM   #92
Navin
Navin's Avatar
Oddometer: 8,412
Well, I haven't done deep water on the Ninja but you could fab a splash shield pretty easily. I ran my 950SE and SMR with pods and lots of rain and a few very deep water crossings in one flooded enduro, no problem. The intakes on those bikes are very high though.
The intake height on this engine/DRZ frame should be as good as a Husky 610, and probably better than my air box on my EXC530, which is just a pretty face. It is as effective as a gill net for keeping water off the filter.
How about running the intake thru tubes to a remote single pod in the stock DRZ box if you are really worried? Hey, if you want to get crazy, fuel in the subframe, air filter up where the tank should be a-la Husaberg-ish. Weld aluminum panels to box in the sub, maybe hang a remote side panel fuel tank like the ones for the older KTM EXCs? Dakar style rear tank? Chop the DRZ tank for an air box?
Navin is offline   Reply With Quote
Old 08-10-2013, 01:38 PM   #93
DRjoe
DRjoe's Avatar
Oddometer: 5,256
Just grab a grinder and start cutting.
Old 08-10-2013, 02:23 PM   #94
tonymorr OP
tonymorr's Avatar
Oddometer: 2,530
That's a big leap of faith. I want to be a lot more sure I can make it work before that happens. I think I'm going to take a big step back right now. This should be a winter project. I'm going to try to muster up the patience...
Old 08-11-2013, 12:17 PM   #95
Navin
Navin's Avatar
Oddometer: 8,412
Chicken.
You could always just build a 500cc wide ratio DRZ now!
Old 08-16-2013, 12:01 PM   #96
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,561
This could get interesting.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 08-26-2013, 08:07 PM   #97
doogiepooch
doogiepooch's Avatar
Oddometer: 964
Well?
Current: 13 Ninja 300 Past: 12 KLR650, 09 Ninja 250, 98 VFR, 88 KLR650, 88 XT350, 07 ZX6R
A nation of sheep will beget a government of wolves....Edward R. Murrow
www.nationalmssociety.org
doogiepooch is online now   Reply With Quote
Old 08-27-2013, 06:52 AM   #98
tonymorr OP
tonymorr's Avatar
Oddometer: 2,530
Originally Posted by doogiepooch View Post
Well?
On hold for a little bit till I have proper time to devote to it.
Old 08-27-2013, 02:46 PM   #99
Eddieb
Eddieb's Avatar
Oddometer: 1,009
Tease
Eddieb is offline   Reply With Quote
Old 08-28-2013, 06:15 PM   #100
Navin
Navin's Avatar
Oddometer: 8,412
Come on Tone!
Get some angle iron and lag bolts and make it happen!
I wonder how easily this would slip into a KLR650 chassie, not that I even like them. I had one and hated it, but the 300 would be a better power plant and 6g of fuel could give a range of 500 miles or more. Might be neat and they have the 650 twins fitting there very cleanly.
Old 08-29-2013, 04:09 PM   #101
JohninVT
Oddometer: 687
Since you've taken a step back to reassess.... How about tucking the 300 into a TW200 chassis?
JohninVT is offline   Reply With Quote
Old 08-29-2013, 05:42 PM   #102
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,486
Someone beat me to the TW idea...
Why not the XR chassis? Easy to modify the frame especially since you are not needing to put oil in the frame.
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 08-31-2013, 05:48 AM   #103
Navin
Navin's Avatar
Oddometer: 8,412
And I thought the DRZ was a bit of a roach to start with...
Old 09-23-2013, 10:13 AM   #104
Navin
Navin's Avatar
Oddometer: 8,412
Toooony!!!
I rode my N300 on forest service dirt & gravel last week at 35-70 MPH... The engine deserves a good rally type chassie/suspension. 3-4th gears are awesome at my +1 CS and 17" wheel gearing. Smooth response, enough torque and almost zero vibes. My bro had his piped/jetted KLX250 there too and said he'd take my 300 engine over his all day long, just slip it in his frame/wheels/suspension.
I'm thinking a older KTM 620/640 LC4 Adv roller for mine...
Figured you needed a boot in the rump to get started!
Old 09-23-2013, 10:19 AM   #105
tonymorr OP
tonymorr's Avatar
Oddometer: 2,530
Toooony!!!
Without pictures it didn't happen!
Times are GMT -7.   It's 06:45 PM.
