Old 02-18-2013, 03:49 PM   #31
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Hellracer, It will go over 45 deg. or the floorboard to within 2 1/2" of scraping, about 1/4" from using all the side tread.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 02-20-2013, 02:53 AM   #32
Hellracer.nl
What the hack???
Hellracer.nl's Avatar
Oddometer: 406
That's pretty good!
Nice build.
To beer or not to beer, that's no question.
My Leaner build: http://advrider.com/forums/showthread.php?t=836987
Hellracer.nl is offline   Reply With Quote
Old 02-21-2013, 01:49 AM   #33
vortexau
Outside the Pod-bay
vortexau's Avatar
Oddometer: 1,700
A two into one exhaust (mounted left side) would have permitted a straight lateral to the rear helm joint. Did you consider this?
'08 Suzuki AN650A Burgman (and trailer)
vortexau is offline   Reply With Quote
Old 02-21-2013, 11:43 AM   #34
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Vortex, you did not notice my red suspenders and pipe, besides I'm a cheep bastard.
To tell the truth that thought did not pass thru my mind. I'll look into that if this gives me any problems. Thanks.
Old 05-05-2013, 09:07 PM   #35
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Got back last night from my first sidecar rally in east Texas and logged 671 miles by the odometer, the GPS showed the speedy to be reading 10 mph to high. Did not have any problems and even hit 95 gps mph. The only time I felt the car at speed was heavy ruts from bad tarmac patches.
My 630 mile stop caught by a fan.
cleatusj screwed with this post 05-06-2013 at 03:05 PM
Old 05-16-2013, 02:46 PM   #36
Willi-Jens
Oddometer: 284
Originally Posted by cleatusj View Post
Looking at your rear connection to the Heim joint, knowing the limited ground clearance from first hand experience and remembering Hiho's accident (http://www.advrider.com/forums/showt...=841428&page=2) I would think that vortexau's comment should be considered. Could otherwise be nasty in a left hander...
Willi-Jens is offline   Reply With Quote
Old 05-16-2013, 06:42 PM   #37
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
The frame rail would still be a quick limit. Unless it's road kill or debris in the road, i'm more worried about dragging the floorboard.
Old 09-22-2013, 06:56 PM   #38
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
It leans no more. I've spent the last two days converting it to rigid with 3 1/2" more ground clearance. I had to buy a few bolts but every thing else was fabricated with a welder, hand and drill press, plus angle grinder.
I was able to get it out for a short ride that proved it needs more tuning as it does try to shake it head. It is also very lite but when I brought the chair up I was able to keep it flying for a couple blocks. That is something I have not been able to do with the Convert.
I'll get some pic's up when I pull it apart to paint brackets.
Old 09-23-2013, 01:35 AM   #39
Hellracer.nl
What the hack???
Oddometer: 406
What is the main reason for converting it to rigid?
The ground clearance? Did you hit somethis on the way that scared you?
Old 09-23-2013, 03:46 AM   #40
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
I find my self running mostly gravel back roads and with the leaner I have to run much slower. The other reason is I like the full body/mind riding experience. Kind of like driving 60+ year old cars and trucks.
Old 09-23-2013, 08:57 AM   #41
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,544
Now that you have 2 rigid hacks how will their use differ ?
Or will it be a case of, I don't feel like shifting so , the Convert. Or just the Big one and the little one.
Will you be building forks for the Cali ?
Old 09-23-2013, 04:40 PM   #42
cleatusj OP
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,124
Baker, I'm most likely going to build LL's but I want to try it this way for a while.
I'm waiting for rings for the Vert, so at this time I only have the Calli on the road and have a dual sport rally coming up in October.
Times are GMT -7.   It's 09:30 AM.
