Old 09-18-2013, 02:12 PM   #2851
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,464
Cush hub options for the XR650R?
Originally Posted by KustomizingKid View Post
How much for a cush hub setup reusing the stock wheel for an XR650r? And how much more for a heavy duty black wheel and heavy duty spokes?
We can re-use your oem rim, which is a 32 hole D.I.D. and lace it to the RAD Cush hub using stainless steel spokes/nipples, it would be 788 + shipping, and include's the billet hub w/ sprocket carrier, superlaced with heavy duty stainless steel spokes/nipples. If you wanted an 18 x 2.15 excel black rim, it would be 998 + shipping for the full wheel.
If you would like to order anything, it's best to call us at 303-936-0232 or email us at woodyswheelworks@gmail.com
Thanks Zach
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 09-19-2013, 10:21 AM   #2852
KustomizingKid
Oddometer: 678
But if I get a black excel (looks killer imo) then I have to do the front too
The horror.
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 09-20-2013, 02:36 PM   #2853
MadM
Dreamer
MadM's Avatar
Oddometer: 298
Wheel off-set
I am in the process of swapping forks from kawasaki's conventional 41mm forkt to KTM WP 4357 forks. But there is a slight problem. When I have installed a Kawasaki wheel in KTM forks, it all fitted like it was made to fit. And so I thought. After measuring the distance from each fork to the centre strip on the tyre I got 1mm off-set left-right.
Here is my question to you:
Can this 1mm of off-set cause any safety or handling issues?
Here is the picture:
Thanks for your help!
'08 Honda XL125V Varadero
'05 Kawasaki KLE 500
'03 KTM LC4 640 Enduro
My Blog
MadM is online now   Reply With Quote
Old 09-21-2013, 05:08 AM   #2854
Built to Last
Oddometer: 3,464
centering your rim between the forks,,,Rx=????
FYI,,,when the wheel isn't centered you wi ll notice that the bike wants to fall to one side easier and be harder to flip into a corner/turn in the other direction....is that dangerous???could be,,,the more off set the contact point is from thepivot- axisthe more difficult it will be to have balanced turning in either direction...
Rx #1 = centering the rim,,in your case moving the rim 1mm to the left when you sit on bike,,,any wheelsmith can re-center the rim,,,If your wheel is true and all your spokes are evenly tensioned,,and you have access to the proper spoke wrench,,you could safely do it yourself,i'd start by loosening every nipple 1/4 turn on the right side and follow it up by tightening every nipple 1/4 turn on the left,,,i bet that will put ya in the ball park
there are other ways BWOE maching the axle spacers,,,adding a shim on axle all far more complicated,
NOTE,,the above suugestion is based on the assumption that the rest of the components fit properly . ie that your disc is centered in the caliper when you tightened your axle bolt
good luck
woody
PS we charge $35-55 to re-true the wheel depending on how out of wack it is.....re-locating the off set is included
Old 09-21-2013, 07:56 AM   #2855
MadM
Dreamer
MadM's Avatar
Oddometer: 298
good luck
woody
Thanks for the detailed information. I was getting all sorts of information on other forums, and was confused what effect will it actually have. I would like to send you my wheel, but unfortunately I am half way around the world from you. I don't have the guts to re-true the wheel, so I will draw some spacer's up and get them machined at work. I am still in the process of making a caliper bracket as kawasaki caliper doesnt fit KTM forks.
My Blog
Old 09-21-2013, 10:05 AM   #2856
Djunta
Djunta's Avatar
Oddometer: 204
...NOTE,,the above suugestion is based on the assumption that the rest of the components fit properly ...
good luck
woody
If something is not ok with forks, twisted mostly, and wheel"s axle isn"t perpendicular to both forks rods, distance from the picture will differ.
(Woody "entschuldigung")
"If we do not get better, we'll be worse"
Djunta is offline   Reply With Quote
Old 09-21-2013, 01:01 PM   #2857
MadM
Dreamer
MadM's Avatar
Oddometer: 298
Thanks, will have a look at this to!
My Blog
MadM screwed with this post 09-21-2013 at 01:01 PM Reason: Typo
Old 09-26-2013, 11:38 PM   #2858
Sfladvrider
Mr.n00b
Sfladvrider's Avatar
Oddometer: 173
hi ,couple questions.. I have a 2014 f800gs adventure and wanted to upgrade to a 18'' rear.
1.best width choice for front and rear . mostly on road but like to get off road as much as i can. was thinking 18x3.5 and 21x1.85.
2. if wanted to get aggressive how much differance is the 18x2.5 then the 3.5. and is the 2.5 strong enough for the gsa loaded 2up ?
3.can you use the anodized nipples from rad and powder coated spokes?
Never underestimate the predictability of stupidity
R.I.P '88 Honda cb1, '07 Honda crf 230, '12 Honda cbr 600rr
USCG 100 ton captain , Padi Divemaster , EMT (future paramedic) , FL Waterman .
Sfladvrider is offline   Reply With Quote
Old 09-30-2013, 08:15 AM   #2859
Built to Last
Oddometer: 3,464
Rim choice's for F800GS
IF you are wanting the 18'' for more off-road and are on the road quite a bit, the 21 x 1.85, 18 x 3.5 will be best with 90/90-21 and 140-150 x18 tire's. The key thing is keeping the tire pressure up to avoid any issues with rim's bending easier and to keep the tire's from wearing out quicker.
The 1.6 x 21 and 2.5 x 18 would be best if you want to have the strongest option for aggressive off-road riding and plan on using it more off-road than on-road.
We can use the anodized nipples with the heavy duty p/c stainless steel spokes, they aren't as strong as the stainless steel nipples and do loosen up easier than the stainless nipples we use.
If you would like to order anything, it's best to give us a call at 303-936-0232 or email us at woodyswheelworks@gmail.com
Thanks Zach
Old 10-02-2013, 08:22 PM   #2860
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,051
Hey Woody
When are you going to start lacing 9x0 hubs onto the new 1190 Adventure tubeless rims?
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 10-03-2013, 04:54 AM   #2861
Built to Last
Oddometer: 3,464
9x0 hubs,,,Huhhh????
Originally Posted by Nowwhat View Post
Hey Woody
Nowwhat,,what am i missing,,haven't heard of 9x0 hubs,,,,Please,clue me in on what year model bike you are referring to...
thanks,,
woody
Old 10-03-2013, 08:21 AM   #2862
URAL CT
Oddometer: 94
Rim cracks
Howdy Woody,
What causes cracks along the hole (on the rim) where the spokes come out? I'm puzzled by this. Thanks for any advice.
URAL CT is offline   Reply With Quote
Old 10-03-2013, 10:35 AM   #2863
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,051
thanks,,
woody
Sorry boss
950 or 990....got lazy hence 9x0
so the old hubs with the new tubeless rims off the 1190 adventures....seems like a slam dunk....I have the ktm tubeless wheels fitted on my 690 enduro....they are simple and work....
Old 10-04-2013, 02:54 PM   #2864
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,246
UPS just delivered these to my door. These are for my 2009 F800GS; a 21x1.85 for the front and 17x3.5 rear sealed for a tubeless tire.
Just gotta find some rubber for them now.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 10-07-2013, 09:31 AM   #2865
Built to Last
Oddometer: 3,464
Wheel options for the new 1190!
thanks,,
woody
We know what you meant by 9x0, which mean's the 950/990 hub's as they are the same hub front and rear, the only difference is the disc side spacer on the rear wheel that's different.
We haven't had the new 1190 wheel's in here to see what will interchange. If you are close or have a friend with a bike who would be willing to let us do some testing and R and D on their bike, which would only take a couple hour's we can figure out what will work best.
Thanks Zach
Times are GMT -7.   It's 07:50 AM.
