Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-08-2013, 05:27 PM   #1
jrsue OP
Oddometer: 95
Basecamp and Roads and Rec
Will Basecamp recognize The Roads and Recreation maps? I downloaded BC and on the "map dropdown menu" Roads and Rec does not show up there.. Roads and Rec is what i use most of the time for offroading, and snowmobiling. I use all tracks, never Routes.
I am a long time user of Mapsource, Roads and Rec. and multiple 376 units. I just ordered a new Montana(hasn't got here yet), and am realizing I may have to give in to using Basecamp. I wish I could just continue using Mapsource and R.R
Sugestions please
jrsue is offline   Reply With Quote
Old 10-08-2013, 08:57 PM   #2
250senuf
250senuf's Avatar
Oddometer: 2,410
I think there may have been a recent change. As I couldn't recall if RnR showed in Basecamp I fired it up and walked away as it loads slowly. When I came back there was a box saying UPDATE ready to install now? later? I let it update and when that was done I checked the drop down; NO RnR. Basecamp 4.2.3 on a XP laptop. Sure wish I had clicked "apply update later" and checked if RnR was in the dropdown.
So then I fired up my Win 7 netbook without it being hooked up to the Internet. Opened Basecamp and turned off the update options. Basecamp 4.2.2 , RnR shows in the drop down.
I didn't read what this latest update was supposed to fix but I'll leave the natbook with Basecamp 4.2.2 until such time that there is no choice but to update. I really can't recall if RnR ever showed on the XP machine so it may be more than just the different version of Basecamp causing the difference.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 10-08-2013, 09:16 PM   #3
mcnut
Oddometer: 1,381
I am running a W7 PC with BaseCamp (4.2.3, an update to an existing install) & MapSource (6.16.3). My R&R displays fine in both, no change I can find. My R&R CD was copied to the hard drive and installed from that location so it doesn't have to access the CD drive for content.
Bruce
mcnut is offline   Reply With Quote
Old 10-09-2013, 04:43 PM   #4
Timmer
Timmer's Avatar
Oddometer: 2,361
I'm on 4.2.3 on BC as well and can see US Roads & Rec just fine.
Tim in Burien, WA
'05 R1200GS '03 F650GS
'08 WR250R
'03 Wing
'01 ST1100
Timmer is offline   Reply With Quote
Old 10-09-2013, 06:06 PM   #5
250senuf
250senuf's Avatar
Oddometer: 2,410
Think I figured out why mine don't show on XP laptop
Mine probably don't show because the RnR CD is on drive D, a partition that held the language choices. Had I known I would have put the RnR CD on Drive C. Neither drive is all that big.
Old 10-10-2013, 06:50 PM   #6
jrsue OP
Oddometer: 95
I just installed R.R on my harddrive ( previously was run off CD and it wouln't show in BC) and now it shows up in Basecamp. Next question is will basecamp send RR maps to the Montana and does the Montana read/show them. I understand there is no auto routing with RR but until I get hooked up with City Nav this will give me street level detail, if they load.
Old 10-10-2013, 07:20 PM   #7
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,770
Technically, Basecamp doesn't send maps anywhere. You can make a call to MapInstall from Basecamp, or run MapInstall on its own to send the maps to the device or the uSD card you plan to use in the gps.
Times are GMT -7.   It's 07:41 AM.
