Old 10-11-2013, 05:53 PM   #3616
turbodieseli4i6
turbodieseli4i6's Avatar
Oddometer: 461
Originally Posted by dsbiker View Post
Just want to comment on Sanjoh's service & products both great. I ordered a pair of 60's, a pair of 30's & a wireless dimmer controller late last Wednesday (10/2/2013) Even though site said 60's were back ordered & order confirmation reflected same, on 10/3 I received ship confirmation that said order was complete and on 10/5 order arrived complete and then some. Sanjoh's lights and controllers now have mini connectors that make installation much cleaner and simpler and based on what I ordered he concluded correctly that I intended to control all 4 with the one controller and included an extra Y connector. I saw this an thought it to be a great addition especially for no extra charge. I had lights mocked up and on within 10 minutes of opening using a spare battery. Everything worked great and as of 10/7 on my s10 they are impressive and truly light up the night.
Can you tell when the 30's are on? Those 60's are so bright, I would think it would be hard to tell the difference with the 30's.
I have a pair of 60's and they are bright!
Looks great by the way. If the 30's do make a difference with the 60's, I may add a set.
turbodieseli4i6 is offline   Reply With Quote
Old 10-13-2013, 09:26 AM   #3617
avc8130
Oddometer: 1,532
I got my replacement lens and the new Xpel protection. I have to be honest, when I saw $5 for a STICKER that was supposed to "protect" my lens from stones I was skeptical.
This is no ordinary sticker. The thing is as thick as the glass lens itself! The sticker feels tough as nails. I have a new confidence. I feel like this sticker might protect the bike during a motocross start!
I don't think the protection should be optional. Spring for the extra $5 if you buy these lights. It's cheaper than $10 for a replacement lens.
ac
avc8130 is online now   Reply With Quote
Old 10-13-2013, 03:50 PM   #3618
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
ac
The Xpel lens protection was designed by 3M for aircraft windscreens
Old 10-13-2013, 03:57 PM   #3619
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
New Products
Check out our new lights
M50 - Spot Beam, 2700 lumens
M15 LED Spot Light - Budget priced at $75 a PAIR
Old 10-13-2013, 08:33 PM   #3620
turbodieseli4i6
Oddometer: 461
Would the 50's have a longer throw than my 60's? More is better in my world!
Old 10-14-2013, 12:05 AM   #3621
tc339
tc339's Avatar
Oddometer: 60
2 questions. Whats the lumen rating on the M15? and do you sell yellow lenses for your lights anymore? I see clear, red, and blue, but no yellow.
tc339 is offline   Reply With Quote
Old 10-14-2013, 08:59 AM   #3622
K7TNT
K7TNT's Avatar
Oddometer: 293
Yep need Yellow! What is the dimensions of the new lights? What's the color out put of them, like 5000K? I like the looks of your lights! ( I see the M15 are here at 60mm diameter
52mm front to back
80mm overall height from bottom of mount to top of light
25mm square foot mounting base
6mm diameter mounting hole in foot)
K7TNT screwed with this post 10-14-2013 at 09:14 AM
K7TNT is offline   Reply With Quote
Old 10-14-2013, 09:17 AM   #3623
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
Yes, pics are on the way.
Old 10-14-2013, 09:20 AM   #3624
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
An M15 produces 1100 lumens.
Yellow was discontinued by Mfg. Looking at replacements.
Old 10-14-2013, 09:29 AM   #3625
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,456
Sanjoh, just wanted to give some very positive feedback. Rode down to Baja last weekend. Due to unforeseen circumstances, we had to ride from Coco's corner back to San Diego on Saturday. We left Gonzaga at about 3, meaning that from San Felipe north, we were riding in the dark, in Mexico, on a road with construction detours that were two-way through nasty dirt. Imagine being on a narrow dirt road with loaded semis heading the other direction in pitch darkness!!
I have the 60's with the dimmer that is wired so the LED's go to full bright when I turn on my high beam.
The first time I hit the brights, my riding buddy almost shit himself he was so surprised how much light they put out. They literally turned night to day. (My HID low and high beam didn't hurt ). I was able to see road hazards plenty far enough away to avoid them while going 60 mph through pitch darkness.
Once my buddy gets over the wallet pain of fixing all the parts he broke on his bike when he went down, he's going to be getting a set of your lights too. Thanks again for an awesome product!!
-Scott- MotoGearGrinder.com
Semper Fi
YetiGS is offline   Reply With Quote
Old 10-14-2013, 01:10 PM   #3626
Camarodude
Oddometer: 280
install question
Does anyone run an on/off switch, on top of using the rotary dimmer switch, or just run with them always on, same as the stock headlight?
Camarodude is offline   Reply With Quote
Old 10-14-2013, 01:18 PM   #3627
turbodieseli4i6
Oddometer: 461
I have on/off switches with the rotary dimmer. I can turn them on without any other light being on.
After all the noise interference with my radio, I just use the lights with my high beams. I added some ferrites, but they will still kill my radio signal.
Old 10-14-2013, 01:48 PM   #3628
YetiGS
No Talent Ass Clown
YetiGS's Avatar
Oddometer: 7,456
Mine are always on at a lower setting, but go to full on with the high beams. I can always shut them off with the rotary dimmer switch if I need to.
Semper Fi
Old 10-15-2013, 06:49 AM   #3629
ewagman
Oddometer: 30
Is the M50 housing the same 70 x 55 size as the existing 44's and 60's? I would guess its illumination would significantly out distance the 30's? Looking forward to seeing some output comparison photos.
I have a well used 44 that flickers more off than on, this could be a good replacement. Maybe replace the other existing good 44 with a 60 at the same time, if you think that would be a noticeable upgrade.
ewagman screwed with this post 10-15-2013 at 06:50 AM Reason: spelling
ewagman is offline   Reply With Quote
Old 10-15-2013, 10:46 AM   #3630
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
Thanks for the feedback
I can imagine the trepidation at having to do that trip at night!
Times are GMT -7.   It's 06:52 PM.
