Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 10-15-2013, 01:42 AM   #4516
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
Originally Posted by Alarm View Post
Agree, as i hope you also agree that the airbox should be sealed better :)
No argument from me there, but it only took $69.95 and 1/2hr out of my life to fix it.
PPiA is offline   Reply With Quote
Old 10-15-2013, 02:48 AM   #4517
Bundu
Bundu's Avatar
Oddometer: 730
are you saying it took you only 30mins to replace the filter?
Bundu is offline   Reply With Quote
Old 10-15-2013, 02:58 AM   #4518
FuzzyDunlop
Oddometer: 283
The prefilters are a course foam that will not stop much dust, but will stop heavier particles getting in.
I dunno about that. The inlet filters are oiled and the oiled foam pre-filter I had on the Tiger 800 kept the air box and main filter mint. I think I'm gonna try the Uni kit.
Currently riding 2013 KTM 1190 Adv R
FuzzyDunlop is offline   Reply With Quote
Old 10-15-2013, 03:01 AM   #4519
PPiA
Pete
PPiA's Avatar
Oddometer: 1,182
About 30mins. Yes.
Once you know the sequence to remove the panels and tank it's not that hard.
I will admit that the first time I tried (fitting heated grips) it took much longer.
Old 10-15-2013, 05:41 AM   #4520
keener
Speed changes you.
keener's Avatar
Oddometer: 982
This is not going to be as easy as 9x0 side stand relocation. There is nothing there to bolt it to and not block oil drain bolts . At least I didn't see anything during a brief look at the dealer. May be a tough skid plate that also hold the stand?! Just a thought.
04 ADV 950
keener is offline   Reply With Quote
Old 10-15-2013, 07:34 AM   #4521
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,712
There were close to a dozen solutions that people came up with for the 9X0 side stands - some of which moved back and used the passenger foot rest brackets. Someone will come up with something.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 10-16-2013, 04:20 AM   #4522
RoundOz
Plenty of seasoning
Oddometer: 1,015
Not that anyone noticed it....
...the last time I posted it a few pages back, but the 1190 stand is only mounted with 6mm screws...it probably doesn't represent as big an issue as the 9x0 stand does in the event of an impact....as long as you carry a set of screw extractors and a battery drill. But it might be worthwhile mentioning it to the vertically challenged who habitually mount the bike by climbing on via the foot peg when on the sidestand. Do I remember reading a warning against this practice in the 990 owners manual....?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 10-16-2013, 02:49 PM   #4523
keener
Speed changes you.
keener's Avatar
Oddometer: 982
I wounder if a slightly wider skid plate could protect the side stand from getting hit.
I agree that 1190 side stand is designed to break o$$.
04 ADV 950
Old 10-16-2013, 10:54 PM   #4524
Alarm
Oddometer: 292
I thought its the central stand that brakes. Now it also seems the side stand brakes as well ?
I start to feel day by day that those guys just rushed too much to put the bike in production.
In the end it's all those (many) things that give a bad image to the bike.
Alarm is offline   Reply With Quote
Old 10-16-2013, 10:57 PM   #4525
manxkipper
Fishpistel
manxkipper's Avatar
Oddometer: 515
Has a stand actually broken off? No reports suggesting same. No point discussing something that has not happened yet. Pure conjecture!
Norton 650 Mercury
1936 BSA Y-13 Project
1969 BSA Rocket 3
2014 KTM 1190R
manxkipper is offline   Reply With Quote
Old 10-17-2013, 01:21 AM   #4526
Alarm
Oddometer: 292
Yeap, read 2-3 threads about a broken central stand :)
Old 10-17-2013, 01:25 AM   #4527
Alarm
Oddometer: 292
Here you go with some links
http://www.advrider.com/forums/showthread.php?t=911775
http://www.ktmforum.eu/forum3/wbb/95...r-abgebrochen/
And here someone touches the ground with the stand while driving
http://advrider.com/forums/showthread.php?t=914734
I bet they spend many months designing it
Old 10-17-2013, 04:16 AM   #4528
RoundOz
Plenty of seasoning
Oddometer: 1,015
The side stand issue may be pure conjecture, but it is based on a long history of problems with the 9x0's that have the sidestand mounted to the engine case in the same manner. There is enough leverage that many of them suffered broken engine cases as a result of an impact to the folded stand. The hope is that because the 1190 uses much smaller screws this will not happen, that the screws would snap instead, but many people would rather have seen the stand attached to the frame.
As far as a larger skid plate protecting it, I kinda doubt it, as it is an impact to the foot of the stand that would be the most likely culprit. It has been pointed out that a mounting plate that mounts to the frame may not work for the 11...I wonder if a frame-mounted bracket with a U-shaped receiver into which the aft end of the stand locates when folded might be an option. It would stop the stand from deflecting and the load applied to the case would be much less. Might be a little ugly when the bike is on the sidestand, but so is a puddle of oil under the motor...
I still expect that someone will come up with a relocating plate pretty soon. There are enough design geniuses out there and enough of a market, even if no sidestand ever breaks.
2009 KTM Adventure
Old 10-17-2013, 04:43 AM   #4529
Alarm
Oddometer: 292
It seems that KTM found the idea of Ducati, putting the stand on the engine is a really smart idea, so they made it too.
How stupid is that, really. Put on a sensitive metal the stand that holds so many kg.
Sometimes i wonder what do they drink when they design things that are already set as standards for decades now on most of the bikes and work.
Old 10-17-2013, 03:05 PM   #4530
keener
Speed changes you.
keener's Avatar
Oddometer: 982
even on 950 and 990 you should ride very aggressively in tough rocky trails to hit the side stand. I can see some scratches and dents on the arch of my 950's stand (no marks on the tail end of the stand). I have used a side stand relocator plate and I even broke that! Its a good upgrade if you want to ride among boulders.
From the frist look it seems KTM hasn't done anything about this by mounting the side-stand to the engine case again. On closer look I see the stand is held by much smaller bolts (M8). On my 950 I have beefy M10x30mm screws mounting the stand to the engine case:
950/990 ADV:
see Part #8:
HH COLLAR SCREW M10X30 WS=13
0015100303
image source missioncycleangus.com
1190 ADV:
(image source ktmtwins.com)
See Part#19:
0025080166 HH COLLAR SCREW M8X16 TX40
So...given the light bracket holding the stand and the smaller screws ,It looks like KTM designed the 1190's side stand bracket (part#6030302600033S SIDE STAND BRACKET) to break off before the engine case breaks.
Given the pressure on the engineers to make the bike lighter, I am not surprised about their decision. Its not the end of the world. Many 9x0 owners rode their bikes for years and didn't even hit the stand once and don't even know what a relocator plate is..., never mind breaking the case. Go riding.
04 ADV 950
Times are GMT -7.   It's 05:23 PM.
