Old 10-17-2013, 01:15 PM   #31
veesquared
Oddometer: 126
Valve grinding paste
Originally Posted by Hair View Post
In the past I have had problems with the Allen part of the cam bolts rounding off.
So when I remove the bolts I make sure that my Allen tools are high quality with no ware.
But that didn't help me this time.
This is the second time that I have checked the valve clearance on my SE. This time I wanted to record the shim sizes so I could plan ahead for when I might have to change a shim.
I was using a brand new Allen tool. I held the ratchet head in place. But the Allen head stripped out anyway. The bolt didn't move from its factory setting.
So now I have a few months to figure out how to remove the bolt.
It really seems that the 950 cam bolts are unacceptably soft.
When my allens show a little wear i will use air cutoff wheel and remove the worn area.I use an angle air sander and take off any burrs and make sure the end is flat. Try a very small dab of valve grinding paste on the end of the allen. Clean bolt head before re- stalling.
KTM 1190 KTM 690 E KTM 200 Exc
veesquared is offline   Reply With Quote
Old 10-17-2013, 01:22 PM   #32
rockohlic
rockohlic's Avatar
Oddometer: 137
had the same problem on the bikes first valve adj.(950 adv) I think Hans at the ktm factory can't hear the little click the torque wrench makes! I won't even tell you what I had to do to remove it!
rockohlic is offline   Reply With Quote
Old 10-17-2013, 01:37 PM   #33
BigTony
Oddometer: 237
Good tip here - I think I my tools may be due for this treatment
BigTony is offline   Reply With Quote
Old 10-17-2013, 05:13 PM   #34
GLRRA47
Oddometer: 90
One of the bolts holding the cam bridge down on my bike was bent. Obviously a factory defect bolt. Couldn't even fix it with a die. Apparently the person who did the first valve check didn't notice it and messed up more than one threaded hole. A couple helicoils later and a new bolt all is fine. Be sure everything fits together smooth. The bolts should screw-in all the way - pretty much by finger - then use a good torque wrench to snug them up. It's easy, once the bolt starts OK to want to go ahead and seat it- even if it's a little sticky feeling - but don't do it if it doesn't feel right.
GLRRA47 is offline   Reply With Quote
Old 10-17-2013, 06:56 PM   #35
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 823
Just a thought, if there is enough meat around the hole ,, look at threadserts instead of heli colis.. They are installed like a helicoil but designed for aluminum, they use them on the head studs of heavy power VW cases. I found them once through an aircraft supplier. They have a special tap with them and the threads engage DEEP they are Iconal If I recall so really tough but match AL expansion ..
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is online now   Reply With Quote
Old 10-18-2013, 09:29 AM   #36
Katoom72
Katoom72's Avatar
Oddometer: 917
I stripped a bolt aswell and that made me buy new bolts for the front and rear, just to be sure id never run into this.
https://dl.dropboxusercontent.com/u/...320_154706.jpg
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 10-18-2013, 09:44 PM   #37
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,184
You can grab the head of these bolts with a small needle nose vice grips. Works great.
"Son, you can't do both"
Old 10-19-2013, 08:06 PM   #38
Scribe
£Bob£
Scribe's Avatar
Oddometer: 7,765
Rounded one the last time I checked the valves. I spent a good three days bemoaning my fate and thinking I was going to have to drop the engine to get a shot at the bolt. I finally ended up grinding the damn thing off (put a rag in the engine to catch the shavings, it was not pretty). New bolts every time now.
"Do or do not. There is no 'try.'"
— Yoda
Man Ball Rolls Through Coloutahrado 2014!
Scribe is offline   Reply With Quote
Old 10-25-2013, 01:05 PM   #39
Hair OP
Outside the boxer
Oddometer: 14,225
It's been years since I visited this thread. It's been a couple of years since I last owned an LC8. I am thinking of buying another one. It's a little sad to hear that some of you are still having to deal with this issue. On the other hand it's good to hear that it is still a rare occurrence.
Hair is offline   Reply With Quote
Old 10-25-2013, 02:03 PM   #40
Katoom72
Katoom72's Avatar
Oddometer: 917
Enough things you can do to prevent it from happening. People that know the engine expect it and act accordingly to prevent it, LC8 'noobs' get caught by it but it's an easy fix.
Now:
Before:
Times are GMT -7.   It's 09:07 AM.
