Old 10-18-2013, 02:22 PM   #1
canadasax OP
canadasax's Avatar
Oddometer: 345
Cam chain tensioner upgrade
I have a 2005.5 950 adventure with 60,000 Km's
It has been suggested to me that I replace the tensioners as a maintenance procedure.
Is this a matter of pulling the old ones out and putting the new ones in.
Or is there something else I have to do as part of the procedure.
I had a look through the H.O.W. But I did not find my answer.
Thank you for any advice you can give me.
canadasax is offline   Reply With Quote
Old 10-18-2013, 03:51 PM   #2
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 403
Its easy
I just replaced mine on my 04 950. Tools required: 8mm Allem w/ball end. small wire for hooking tensiner body. I bought new caps also. Pump/Lube up the new ones withthe type of oil you use. My bike is much quieter overall and on start up now. Have fun.
Steve
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 10-18-2013, 04:46 PM   #3
canadasax OP
canadasax's Avatar
Oddometer: 345
Thank you
Old 10-18-2013, 09:52 PM   #4
renogeorge
Oddometer: 1,330
When you are changing the tensioners you can check the wear on the timing chains by measuring the distance from the loosened tensioner to the cylinder. See the service manual for details.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 04-19-2014, 12:09 PM   #5
outbacktaz
outbacktaz
outbacktaz's Avatar
Location: 6 minutes away from a KTM dealer! Total bliss!!
Oddometer: 522
Quick question, as my bike is back in storage now that it snowed a lot again here!!
Are those quite accessible or do I have to take half the bike apart to check/change the tensioners??
Thanks guys!!
Marty aka Outbacktaz!!
__________________________________________________
Only the dead have seen the end of War! George Santayana
To sin by silence makes cowards out of men! Ella Wheeler Wilcox
Peace is mostly valued by those who are sworn to protect it! Unknown
outbacktaz is offline   Reply With Quote
Old 04-19-2014, 10:21 PM   #6
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 709
Back one is easy... Front one is not so easy but it's not too bad.
Check your chains as suggested above while you are in there. They do not have much room for stretching.
I did my chains at 50,000 miles on my 990 and they did not really need it at all if it makes you feel better.
The tensioners go much more quickly but the new ones pop right in. Re-torque the cap and off you go.
Pistolero screwed with this post 04-19-2014 at 10:28 PM
Pistolero is offline   Reply With Quote
Old 04-20-2014, 12:12 AM   #7
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 522
Cool!! The only way I can see with the Shop Book is after engine removal...!!
When I look into the front of the bike, I can see the front one. But I can't see the back one...?? It's in the Vee, right?
Old 04-20-2014, 02:45 AM   #8
Bowber
Oddometer: 139
Just imagine you've flipped the cylinder round the piston, the cap should be on the right rear.
The cam chains run from each side so the front cylinder cam chain is on the left and the rear cylinder cam chain is on the right.
Steve
Bowber is offline   Reply With Quote
Old 04-20-2014, 03:00 AM   #9
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,464
The cap for the rear cylinder is on the right hand side of the front of the cylinder. Same side as the intake port, unlike the front one which is on the same side as the exhaust.
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 04-20-2014, 03:06 AM   #10
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 522
Steve
Thanks guys!! I'll have a look at them tomorrow...!!
Old 04-20-2014, 04:06 AM   #11
Bowber
Oddometer: 139
So it is, I was looking at the wrong blanking plug
Steve
Old 04-20-2014, 04:08 AM   #12
JK1
JK1's Avatar
Oddometer: 112
I changed the tensioners, cam chains and rails when I did mine recently. Mines an 03 37k miles on the clock. The old chains where slightly longer than the new ones and one of the plastic rails was slightly worn.
Current KTM 950 Adventure S 03
Old Suzuki TS50, Aprilia Chesterfield RS125 , Honda NC30, Cagiva Elefant 750
JK1 is offline   Reply With Quote
Times are GMT -7.   It's 03:53 AM.
