Old 10-18-2013, 02:36 PM   #38671
Kent Glasscock
Kent Glasscock's Avatar
Oddometer: 162
rear rack with the wolfman side racks
On the purchase list is the wolfman side racks and was looking at a decent rear rack. I did see where the OEM rack works but may require a little more work for installing. I like the moose racing rear rack and Immix also has a nice one. Has anyone tried to use either of these with the Wolfman's. Thanks!
Kent Glasscock is offline   Reply With Quote
Old 10-18-2013, 02:52 PM   #38672
livetofly
livetofly's Avatar
Oddometer: 61
Originally Posted by bluzharp View Post
You may breathe some life back into that battery, but since you ran it completely flat, it is pretty much on its last legs. Plan on budgeting for a new one soon.
Got a replacement battery for $65 at AutoZone and all is well again. Didn't realize you could drain the battery so much that a jump or push start wouldn't get it going again. Glad I figured this out in the driveway and not in the woods somewhere.
Sent from my C5215 using Tapatalk
2008 Yamaha WR250X
2006 DR650 - sold
2005 KLR250 - sold
Pura Vida !
livetofly is offline   Reply With Quote
Old 10-18-2013, 03:05 PM   #38673
debaisley
debaisley's Avatar
Oddometer: 1,424
I put the AIS removal kit on my bike probably 4 years ago, I just noticed today that the rubber plug that goes into the air box where the old AIS hose used to connect is all dry rotted and cracked , what is a good common item to use as that plug ?
debaisley is offline   Reply With Quote
Old 10-18-2013, 04:19 PM   #38674
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,436
I left a short bit of hose, plugged it with 1" of aluminum rod I had laying around and sealed it with a small stainless hose clamp.
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is offline   Reply With Quote
Old 10-18-2013, 04:25 PM   #38675
sieg
sieg's Avatar
Oddometer: 2,846
https://www.google.com/search?q=chai...w=1280&bih=563
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Old 10-18-2013, 04:38 PM   #38676
ramz
Professional Trail Rider
Oddometer: 2,006
See plastic cap and clamps in several places on the page, including the picture at the top:
http://rickramsey.net/CRF250Lcccmods.htm
ramz is offline   Reply With Quote
Old 10-18-2013, 04:54 PM   #38677
debaisley
debaisley's Avatar
Oddometer: 1,424
readily available at a hardware store , thanks
anyone know if the plug on the vacuum port on the throttle body is susceptible to the same type of rot /cracking ? should I pull the tank and take a look ?
Old 10-18-2013, 07:40 PM   #38678
malignity
The Hurt Locker
Oddometer: 376
So I screwed up.
I came across a snag that may potentially kill my dual sport ride this weekend with a friend of mine on with him his 08 WR250R (our first ride riding the WR's together)
I buggered up the steel wool gasket that goes between the header and exhaust. Its completely unusable. I got this bright idea to RTV the hell out of the thing and simply crank down on the clamp mechanism and pray for the best. Unfortunately it leaks air like mad and didn't work.
I'm in a bit of a bind. With the abscense of a gasket and with RTV being not enough, what can I use? Will exhaust tape work? :(
Any other better ideas?
'10 Yamaha WR250R , '93 Yamaha TW200, '03 Honda Foreman 450ES 4x4.
gldsmc.org
malignity is offline   Reply With Quote
Old 10-18-2013, 08:11 PM   #38679
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,436
Originally Posted by malignity View Post
So I screwed up.
Did you try this?
http://shop.advanceautoparts.com/web...atex_7020007-p
That's what I used on my FMF Pipe to Powerbomb, I don't remember no steel wool.
Old 10-18-2013, 08:52 PM   #38680
malignity
The Hurt Locker
Oddometer: 376
Originally Posted by Scott_PDX View Post
Did you try this?
Yes, used the red high temp RTV (Same stuff) and it doesn't expand. I simply can't get it on thick enough. The gap without the gasket is way too big. Stock exhaust.
gldsmc.org
Old 10-19-2013, 01:41 AM   #38681
LTCOliverNorth
Peeping Tom
LTCOliverNorth's Avatar
Oddometer: 782
+1, just did the AIS removal on my WR and used a rubber chair-leg cap from Ace Hardware. Fit like a glove.
2007 BMW G650X Challenge
2005 BMW R1200GS
2002 Ural Patrol T
LTCOliverNorth is offline   Reply With Quote
Old 10-19-2013, 05:19 AM   #38682
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 455
'06 Wee-Strom
'08 WR250X with X and R setups
'08 KTM 300xc-w - Plated
Colorado 2012
UPAT 2011 2014
jgino157 is offline   Reply With Quote
Old 10-19-2013, 02:02 PM   #38683
mtntrails
Oddometer: 461
Oil Change Procedure
2009 WR250X
So, I'm checking the owners manual for oil capacity and noticed a "burping" procedure mentioned to check for proper oil pressure. The check valve is on the rear of the cylinder on the left side.
Is this part of the normal oil change procedure or a separate procedure just to check oil pressure?
mtntrails is offline   Reply With Quote
Old 10-19-2013, 02:50 PM   #38684
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 333
Originally Posted by mtntrails View Post
2009 WR250X
It is listed in oil change procedure per manual. I always do it as it only takes an extra min, however I know others that don't.
EEKAMOUSE is offline   Reply With Quote
Old 10-19-2013, 03:36 PM   #38685
Superstar
Superstar's Avatar
Oddometer: 492
2009 WR250X
I'd bet most people don't do it.
Superstar is offline   Reply With Quote
Times are GMT -7.   It's 02:07 AM.
