Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 10-17-2013, 04:37 PM   #4531
speed_racer
speed_racer's Avatar
Oddometer: 707
Originally Posted by PPiA View Post
The prefilters are a course foam that will not stop much dust, but will stop heavier particles getting in.
There are two filters to stop the dust placed where the stock filter was.
UniFilter claim their system was designed to flow the same amount of air as the stock filter.
I think there is a lot of over reaction going on here.
Yes, if you did a deep water crossing where the intakes went under, you would get water in the airbox.
Yes, if you did drown it, you would need to spend a bit longer taking the extra stuff off to get to it.
But how many of you will actually try to do deep water crossings on one?
Seriously?
I agree.. when i got the uni filter added at the first service, even bolt on said we didn't bother putting the socks in because they can be too restrictive..
I will try a deep river crossing on mine if its in my way but it just means if its real deep ill keep an eye on the front and a finger on the kill switch just in case..
I think for a hybrid sports / adventure bike, your going to have some elements that are from either side.. and the air intake in this case sports..
it isnt all bad though.. i think we will be using its roar power 99% of the time in comparison to river crossings :P
as they say, you cant have your cake and eat it too.. well you can but the cake may taste better than it looks or vice versa.. :P
13' KTM 1190 Adventure R
KLX650R
RIP - BMW F650 GS Twin
speed_racer is offline   Reply With Quote
Old 10-17-2013, 04:40 PM   #4532
speed_racer
Oddometer: 707
Originally Posted by RoundOz View Post
...the last time I posted it a few pages back, but the 1190 stand is only mounted with 6mm screws...it probably doesn't represent as big an issue as the 9x0 stand does in the event of an impact....as long as you carry a set of screw extractors and a battery drill. But it might be worthwhile mentioning it to the vertically challenged who habitually mount the bike by climbing on via the foot peg when on the sidestand. Do I remember reading a warning against this practice in the 990 owners manual....?
I've never noticed.. but thanks for the tip.. i usually do that when my legs are tired :)
KLX650R
Old 10-17-2013, 04:45 PM   #4533
speed_racer
Oddometer: 707
Originally Posted by Alarm View Post
Here you go with some links
http://www.advrider.com/forums/showthread.php?t=911775
http://www.ktmforum.eu/forum3/wbb/95...r-abgebrochen/
And here someone touches the ground with the stand while driving
http://advrider.com/forums/showthread.php?t=914734
I bet they spend many months designing it
interesting read.. although the bottom one is in regards to a adventure std not the R model which has more clearance..
id love to see the pics on how it broke.. im sure with a bit of time in the garage someone could find a solution..
KLX650R
Old 10-17-2013, 05:01 PM   #4534
speed_racer
Oddometer: 707
Originally Posted by keener View Post
So...given the light bracket holding the stand and the smaller screws ,It looks like KTM designed the 1190's side stand bracket (part#6030302600033S SIDE STAND BRACKET) to break off before the engine case breaks.
Given the pressure on the engineers to make the bike lighter, I am not surprised about their decision. Its not the end of the world. Many 9x0 owners rode their bikes for years and didn't even hit the stand once and don't even know what a relocator plate is..., never mind breaking the case. Go riding.
I just found this site on working bolt strengths.. it seems the tiny 6mm isnt so weak after all..
http://www.tech.plymouth.ac.uk/sme/desnotes/boltb.htm
So it takes 24550 newtons to break a 6mm bolt = 5519 pounds or 2503 kg hit.. given that website is correct..
any engineers want to confirm?
KLX650R
Old 10-17-2013, 05:22 PM   #4535
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,719
The strength isn't as important as the grade. If it's a grade 6 or 8, it will stretch somewhat before it breaks. If it's a grade 10 or 12, it will be stronger, but more brittle and it will sheer off more easily.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 10-17-2013, 07:41 PM   #4536
4corners14
4corners14's Avatar
Oddometer: 670
New comparison between the 1190R and 990 Baja
If it's already been posted......I haven't seen it on the thread yet.
https://www.youtube.com/watch?v=DK57...layer_embedded
4corners14 is offline   Reply With Quote
Old 10-17-2013, 10:35 PM   #4537
dragos
Belzebut
dragos's Avatar
Oddometer: 1,157
I made a thread for it few days ago:
http://www.advrider.com/forums/showthread.php?t=927669
ADVENTURE: I absolutely loathe adventurers, and I particularly hate this old pseudo-adventurism where the mountain climb becomes about confronting the extremes of humanity. (WH)
dragos is offline   Reply With Quote
Old 10-18-2013, 06:08 AM   #4538
RoundOz
Plenty of seasoning
Oddometer: 1,017
Many variables...
Shear strength and ultimate tensile strength are two different things. Both of these vary significantly depending on the material the bolt is made from and how it is heat treated.
It's possible those bolts could be subjected to both forces depending on how the sidestand was hit. Also note that there are very long levers involved that magnify the forces significantly (for example if the distance between the bolts was 1.5" and the stand 15" long, the forces might be 10 times higher). Acceleration due to gravity and the speed of the bike also increase the forces. All this is speculative...the real world is a large target sample (thousands of new owners) and lots of testing (thousands of miles of rocky trails). So you guinea pigs...uh...astute 1190 owners....who bought the first year model, get out there and ride em like they were meant to be and we will take notes...
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 10-18-2013, 06:28 AM   #4539
Alarm
Oddometer: 292
Come on, lets get serious. If we see the current center stand braking, do you think they (KTM) would put so much science on a 3-4 bolts ? Now honestly...
Alarm is online now   Reply With Quote
Old 10-18-2013, 03:42 PM   #4540
Harold Waikiki
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 406
Put a deposit down on a 1190r and consigned my multi! I'm pumped!!
14 KTM 1190R,12 KTM 350 EXC
82 Honda CT110, 09 KTM 950 SE Erzberg
Harold Waikiki is offline   Reply With Quote
Old 10-18-2013, 05:03 PM   #4541
schoals
schoals's Avatar
Oddometer: 559
FINALLY!!!!!!
Fresh out the box
schoals is offline   Reply With Quote
Old 10-18-2013, 05:15 PM   #4542
nikoktm
nikoktm's Avatar
Oddometer: 283
Originally Posted by schoals View Post
FINALLY!!!!!!
Fresh out the box
Congrats!
nikoktm is offline   Reply With Quote
Old 10-18-2013, 05:39 PM   #4543
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,418
In the USA
Nice that's good news they are starting to come in
ebrew is offline   Reply With Quote
Old 10-18-2013, 06:01 PM   #4544
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,837
MCN Test off road
http://derestricted.com/travel/ktm-1...ocus-diary-mcn
"Experience alone is not the great teacher; Experience has to be multiplied by intelligence to yield sustained progress." Phil Schilling
Deuce is offline   Reply With Quote
Old 10-18-2013, 10:25 PM   #4545
Womble_CH
dribbling baboon
Womble_CH's Avatar
Oddometer: 335
Originally Posted by Deuce View Post
Haha, I like how this guy gets breathless whenever he talks about the Adventure :)
Sent from my IBM Simon using morse
Womble_CH is offline   Reply With Quote
Times are GMT -7.   It's 11:05 PM.
