Old 10-23-2013, 03:57 PM   #16
NICO
NWGS's pwner!1!!1!
NICO's Avatar
Oddometer: 25,975
Would an overfill cause the oil to foam, limiting the pump's ability to circulate it?
Originally Posted by NWGS
This post has zero to do with civility and more to do with stupidity.
NICO is offline   Reply With Quote
Old 10-23-2013, 04:31 PM   #17
joexr
Oddometer: 3,773
Possibly. I could also be belching oil into the airbox and filter.
Old 10-23-2013, 04:58 PM   #18
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,507
How to check the oil level on the DRZ400: http://www.youtube.com/watch?v=LSHrXfwa5W8
If the oil level is above the upper level mark on the dipstick then the engine has too much oil.
Stan_R80/7 is offline   Reply With Quote
Old 10-23-2013, 05:59 PM   #19
kartl
Oddometer: 10
I would say yes that is very possible and due to this it can also increase the pressure that can cause internal damage. Running to much oil is almost the same with running with out oil at all.
kartl is offline   Reply With Quote
Old 10-23-2013, 06:31 PM   #20
viverrid
not dead yet
Oddometer: 30,482
DRZ is dry sump and nothing to do with hydraulic valves or hydraulically driven variable timing.
The bike needs to be recently run to check the oil level. The dipstick is way up on the frame that acts as the oil tank. It is not down on the case.
Advanced pancreatic cancer found 04/2010. Have outlived +/- 97% of patients with this diagnosis, but 08/2013 cancer now in liver, vascular system and lungs with 20+ lung tumors. Sick/weak sometimes, not riding much. No more treatments & now under Hospice care.
viverrid is offline   Reply With Quote
Old 10-23-2013, 06:37 PM   #21
*Gmoney*
don't look here
*Gmoney*'s Avatar
Oddometer: 911
Would an overfill cause the oil to foam?
Its got Rabies!
*Gmoney* is offline   Reply With Quote
Old 10-24-2013, 06:08 PM   #22
KeithinSC
KeithinSC's Avatar
Oddometer: 1,557
Did you remember there are 2 O rings around the filter? One about .5" dia, the other about 2" dia.
Lay the bike on its' side (no spill method) and take the filter cover and filter out again. Make sure they are there and didn't get sucked into the engine.
KeithinSC is offline   Reply With Quote
Old 10-24-2013, 09:46 PM   #23
RidingAgin
RidingAgin's Avatar
Oddometer: 403
Did you get water mixed in with the oil? That would get it to foam. DAMHIK.
If it is foaming, I would drain and put new oil in. Start fresh.
08 R1200GS, 11 F650GS twin
RidingAgin is offline   Reply With Quote
Old 10-25-2013, 03:51 AM   #24
Fixnfly
Fixnfly's Avatar
Oddometer: 393
I wish The OP would get back in this conversation....
An update sure would be nice.
01 DRZ400S 93 GSXR750 13 Z1000
Fixnfly is offline   Reply With Quote
Old 10-25-2013, 05:32 AM   #25
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,977
His bike locked up in a bad neighborhood.
Support the AMA.
Waco is offline   Reply With Quote
Old 10-25-2013, 05:40 AM   #26
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 691
Draining, and filling to listed capacity without measuring is never a good idea. This is how places like Jiffylube always overfill your car.
uraberg is offline   Reply With Quote
Old 10-25-2013, 10:51 AM   #27
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,540
Correct, also a dry sump engine will not foam the oil as the crank is not splashing about in it.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 10-25-2013, 12:42 PM   #28
1greenmachine
Oddometer: 782
A overfill will let the crank hit the oil and windage it which will flow the same but not lubricate like its suppose to.
1greenmachine is offline   Reply With Quote
Old 10-25-2013, 01:22 PM   #29
Waco
Waco's Avatar
Oddometer: 14,977
What do you do? Fill it partially, warm the engine, check the oil, and add some more? I've only done that when the capacity was unknown. If it says 3.75 qt, I'm pouring in 3.75 qt.
Support the AMA.
Old 10-25-2013, 02:49 PM   #30
ohgood
ohgood's Avatar
Oddometer: 2,936
I drain frame and pan, change filter, the dump in 2 quarts. The extra 200ml our whatever burns off sob enough anyway. ;)
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Times are GMT -7.   It's 10:42 PM.
