Old 10-15-2013, 06:12 PM   #1
Honkylicious OP
sup?
Honkylicious's Avatar
Oddometer: 1,202
trials bicycle
Just looking for some advice on building a trials bicycle. Can someone point me towards a decent forum? I am looking to build one from an old mountain bike.
Many a man fails as an original thinker simply because his memory is too good.
Honkylicious is offline   Reply With Quote
Old 10-15-2013, 06:39 PM   #2
DerViking
Shred
Oddometer: 327
Spend real money on a rear hub, a Chris King is the best. The tight engagement will do wonders for your learning curve.
Wear shingaurds that cover clear from your ankle over your knee. Ankle protectors can also be good, for when you inevitably land on your front ring with your ankle bone.
Can't help with the forum. Haven't kept up.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 10-15-2013, 06:43 PM   #3
mud
I just wander.....
mud's Avatar
Oddometer: 1,753
OTN
It is not really safe for work (or kids), but it is what it is.
2007 Factory Husaberg 380FE
2007 Montesa 4rt
1984 Husqvarna 500AE
mud is offline   Reply With Quote
Old 10-16-2013, 04:39 PM   #4
Honkylicious OP
sup?
Oddometer: 1,202
maybe I can wear my MX boots
Old 10-16-2013, 04:41 PM   #5
Honkylicious OP
sup?
Oddometer: 1,202
Originally Posted by mud View Post
OTN
Thanks Mud, found loads of good info on this site. Thanks for the tip.
Old 10-17-2013, 12:28 PM   #6
Kyron
Oncler Inds
Kyron's Avatar
Oddometer: 250
buy a old trials bicycle instead.... the geometry is completely different.
there's a Seinfeld episode like this, .....right?
Kyron is online now   Reply With Quote
Old 10-17-2013, 08:38 PM   #7
DerViking
Shred
Oddometer: 327
Not a bad point.
Another good option is a dirt jumper frame. Not perfect on geometry, but better, and generally has shorter dropouts. Far more available than Trials frames.
That said, you can have quite a bit of fun on a Mountain bike with good brakes. I run AVID 8" mechanical disks on my Moustache Cycles Odin All Mountain Bike, and find them pretty good for trialsin around. My trials bike runs hydraulic disks, but they require more maintenance and are not as strong all around. I ran the Magura Rim Hydraulics for years, and there are things to recommend about them, but the maintenance is high and can be frustrating. Depending on how big you are, buy some heavy duty wheels now. I walked home too many times with destroyed wheels in my first year.
The main point is to tear into it and have fun. If you ride much you will destroy whatever you start on, and can look for something better.
Old 10-25-2013, 10:37 AM   #8
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,673
Check this thread:
http://advrider.com/forums/showthread.php?t=664648
AteamNM is offline   Reply With Quote
Times are GMT -7.   It's 10:02 PM.
