Old 10-18-2013, 02:24 AM   #1861
mookymoo
Mookish Mook
Oddometer: 4,396
Originally Posted by mousitsas View Post
Is there any case that the facet does not corrode due to alternative placement?
Question mainly aimed to river crossers.
The Facet should be completely sealed.
I made extra sure with some sealant around the seams.
(The stocker can easily leak if the grommet on the wiring isnt positioned correctly - and its not trivial to seat properly given the short wiring length - and a tug on the wiring can dislodge it)
mookymoo is offline   Reply With Quote
Old 10-28-2013, 09:12 AM   #1862
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
950SE SAS venting
I apologize, did a search but could not find it. just purchased a replacement 2009 950SE with akras with db inserts on and all smog crap on bike.
I had my first taste of hydraloc while unloading bike from truck, bike tipped over to its left when ramp slid under me , leaving me holding the bike balanced between the side of the bed and what was left of the ramp holding the bike from falling to the floor for more than 40 minutes till a friend arrived and helped me lift and unload the bike. Talk about a closed one, my back, my arms are still sore for saving the bike from doing damage to either truck or bike. Not a scratch on the bike and no damage to toyota tacoma.
When bike tipped over, the bike filled its cylinders with gas since i had not closed the petcocks so experience was starter locked up. rocking bike in 6th gear backwards finally allowed bike to sputter and start.
SO as priority one now that i already installed the kickstand relocator is to remove the smog emissions.
Funny on my previous 950SE had all emmisions removed by previous owner, so i did not pay attention on how the vent lines where routed.
SO it is actually pictures of the vent lines and how they are routed and if you install a one way vent or leave them "open"
is front hose 11" and rear 10"
I also ordered 3 ktm swingarm caps to cover the three holes left when removing the breather hoses from the airbox per a fellow adv'er stating the fit fine on holes and i dont want the " epoxy look"
Feels fine to have an addiction of orange crush
LURKER
pepetrueba is offline   Reply With Quote
Old 10-28-2013, 09:27 AM   #1863
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,453
Any chance this bike has a Mikuni vacuum (pulse) pump??? If yes,,, then not turning of the fuel petcock would most likely cause the hydrolock.
The vent lines coming off the carbs just need to exit down through the bottom of the airbox. There are 2 on each carb,,,, one on each carb gets plugged and the other is as I said.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 10-28-2013, 10:02 AM   #1864
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
950se stock
Nope bike is bone stock, except for the Akra pipes. A little over 4k on the odometer.
Bike was laying on its left side with headsheel rasting on the tacoma's left side of the and i was holding dearly so handlebar would not dent/scratch outside of bed and with right foot held the ramp from completely sliding put od truck.
It reminded me of the "TWISTER game" where you strech to the max on an ackward position.
i did open the aluminum drain bolt on the house on bottom right side of engine and put bike on 6th gear and rocked back till it spilled its gas on the floor.
I did order the dr bean kit for the fule pump bcause on my previous Se before 4k miles, the points where shot.
LURKER
Old 10-28-2013, 11:17 AM   #1865
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,925
My facet is now above the air intake so if it gets wet I'm screwed anyways.......
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is online now   Reply With Quote
Old 10-28-2013, 11:44 AM   #1866
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,007
Originally Posted by mountain eagle View Post
my facet is now above the air intake so if it gets wet i'm screwed anyways.......
+1
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 10-29-2013, 03:54 PM   #1867
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
carb float vents
gents. any pictires of the carb vent floats hoses for the super enduro?
i checked the forum and they show 950 adventure 950 sm , how about the 950 enduro once you remove the epc and sas.
I ordered the sas block off plates. where do you get the plugs for the carburetor and rear airbox?
divaha's method looks like its the easiest but the pictures how he routed the breather are not show. again fron hose has to be 11" and rear 10" and why such lenght if both hoses are capped and zip tied to frame per divaha.com?
thsnks again all mighty orange forum
LURKER
Old 10-29-2013, 04:39 PM   #1868
Monterey_BS
On or Off - not sure
Monterey_BS's Avatar
Oddometer: 249
1) All of your questions can probably be answered through a review of KTM950.info - the all famous Orange Crush Hall of Wisdom. Drill into the carburettor & jetting or canisterectomy pages for this topic.
2) Go to a parts house and ask for hose plugs or caps. You'll find whatever selection you need there.
3) The vents remain open. (top front left on front carb and top rear right on the rear carb.) They are still vents. Do not cap them. Just feed them through to the space between the cylinders and forget about them.
Bob in Monterey
Monterey_BS is offline   Reply With Quote
Old 10-29-2013, 04:49 PM   #1869
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
plugged hoses
Bob:
how come i see pictures of capped hoses for syncrhonization (where are these from? )
LURKER
Old 10-29-2013, 05:12 PM   #1870
Monterey_BS
Oddometer: 249
Bob:
I'm not clear what you are asking. If you post a picture or a link, I'm sure one of us will be able to do so.
Bob in Monterey
Old 10-29-2013, 05:14 PM   #1871
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 576
Bob:
Those capped hoses are vacuum hoses from the right hand side of each intake. When I get around to doing mine I'm going to stick a bolt in each pipe and ziptye or clamp instead of caps. The vacuum pipes off the left of the intakes get removed and sealed with bolts.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 10-30-2013, 10:02 PM   #1872
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
california emission recall
GENTS
Received a phone call from Long Beach dealership were I bought the used 950SE stating dmv had "rejected registration of motorcycle to my name" due to some emmisions recall.
I called a san diego ktm dealer and they stated some sticker that has to be replaced on frame.
I have not removed the sas or epc YET, but bike has akras so no catalytics are on bike.
Will I require emmision check from dmv or is it future crap for california to start smogging bikes???
Years ago they tagged me on a ram turbo diesel that was chipped and no catalytic forcing me to sell truck out of state.
LURKER
Old 10-30-2013, 10:55 PM   #1873
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Escondido, CA, USA, Earth, Milky Way, Local Group
Oddometer: 1,468
I moved to CA three years ago with three bikes including a 950SE with FMFs on it. One bike had factory muffler but all other emissions stuff removed. On all three bikes they just wanted to see the factory emissions sticker. No emissions test was required... and still isn't to my knowledge.
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 10-30-2013, 11:45 PM   #1874
pepetrueba
PePeBaJa
pepetrueba's Avatar
Oddometer: 197
thanks for heads up
Danger. M
Thanks for heads up.
Noticed you're in Escondido. Do you ever rider wuth Afry and Todd.
Afry lives in Ramona with his nicely setup SE and Todd is riding my ex 950SE.
Hope to tag with you guys once I try to finish setting up mine. Also on this forum I believe at least 2 other riders are from san Diego county with SE...
Pepe
LURKER
Old 10-31-2013, 04:01 AM   #1875
Monterey_BS
Oddometer: 249
GENTS
I've got two '09 KTMs (SE and Duke) here in CA that had the sticker "problem." If memory serves, the only change to the sticker was to add a range to the idle spec: 1400rpm +/-50rpm, or some such. The original stickers indicated a single acceptable value. I asked to be given the stickers to apply, but ultimately had to haul them in to have the "work" done by them. It does seem odd, though, that the DMV caught this. It may be part of the dealer's responsibility to verify that all bulletins have been addressed prior to registering.
I believe the "no removal" rules apply to 2012 bikes onward which is one reason I've still got a box of parts on the shelf for my '12 690ER.
Bob in Monterey
Monterey_BS screwed with this post 10-31-2013 at 05:16 AM
Times are GMT -7.   It's 09:25 PM.
