Old 11-01-2013, 01:08 PM   #1
crazyal OP
dumb ass
crazyal's Avatar
Oddometer: 137
Thumb Grip heaters "the real low"
As a KLR rider I'm looking to be cheap and conserve wattage, I read this somewhere thought i should repost here.
The cheap grip heaters with the resistor don't use less power on low they just heat the resistor instead of the grip, so if you install a 12v automotive 2 wire flasher about $5 it will "flash" on low cycling the power about 50% of the time depending on the rating of the flasher. you simply cut the resistor out and wire the flasher in place of it.
I installed mine like this last week road to Recompance with some FF's and it worked great, not too hot, not too cold it was just right!
2001 KLR650 really,I bought another one!
05 weestrom mildly farkled SOLD
02 drz250 the little yellow tractor Sold
crazyal is online now   Reply With Quote
Old 11-01-2013, 01:12 PM   #2
MrPulldown
MrPulldown's Avatar
Oddometer: 3,341
poor mans heat troller. Like it!
MrPulldown is offline   Reply With Quote
Old 11-01-2013, 01:22 PM   #3
SgtDuster
SgtDuster's Avatar
Oddometer: 3,358
Cheap and simple PWM kind of solution.
Brilliant.
But a cheap and "real" 12v PWM controller is 5$ on Ebay...just sayin'! ;)
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is online now   Reply With Quote
Old 11-01-2013, 01:26 PM   #4
crazyal OP
dumb ass
crazyal's Avatar
Oddometer: 137
Hum never thought to look?
Sent from my iPhone using Tapatalk - now Fre
Old 11-01-2013, 02:48 PM   #5
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,213
A true Cheap Bastard would just mount a scavenged light switch (look for a dumpster outside a house being remodeled) where he could flip it off and on with a pinky every so often.
You went and spent a whole $5 that could have been used for a whole stack of socks and underwear at Goodwill...
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 11-02-2013, 11:20 AM   #6
Rootkiller
Rootkiller's Avatar
Oddometer: 372
The grip heaters from California sport touring have a "real low", no resistor or wasted wattage!
Sent from my SM-P600 using Tapatalk 2
Rootkiller is offline   Reply With Quote
Times are GMT -7.   It's 07:06 PM.
