Old 10-31-2013, 05:53 PM   #1
Deadelk OP
Oddometer: 15
DR 650 rear shock removal.
The new Cogent rear shock was on the porch when I got home.
Any tips on removing the stock shock and installing the new one?
Deadelk is offline   Reply With Quote
Old 10-31-2013, 07:27 PM   #2
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 621
Remove the seat, side covers and air box.
Enjoy!
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is online now   Reply With Quote
Old 10-31-2013, 08:41 PM   #3
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 425
It is pretty straight forward. You will enjoy the new ride. Are you doing something to the front end?
Graniteone is offline   Reply With Quote
Old 11-01-2013, 05:29 PM   #4
Deadelk OP
Oddometer: 15
Yes, I also have the DDC solution kit from Procycle.
I'll tear into it this weekend.
Old 11-01-2013, 08:34 PM   #5
TrophyHunter
Oddometer: 2,167
I took a few extra items off but not needed. Just made moving around everything easier.
2005 DR650 '07 WR450
2013 HD Road King '73 Hodaka Wombat
"It's a small amount of gas, but it represents a long walk" My Dad...
TrophyHunter is offline   Reply With Quote
Old 11-02-2013, 07:55 AM   #6
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,822
Maybe a little late now but I removed the shock on my DR by taking the swingarm bolt out,moving the arm back and dropping the shock out the bottom,I think I unbolted and greased the shock linkage and it was pretty easy to get the shock out that way. Might be easier to remove the muffler as well which is easy to get off as well.
I didnt want to take the airbox off.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 11-02-2013, 09:22 AM   #7
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 621
We figured out that the rubber boot can stay on the air box and still fit through the frame (better warm than cold), saving the frustration of refitting the thing back over the ab lip. Customers report that exhaust removal works. If you are lubing the swing arm pivot anyhow, tha sounds like a pretty awesome way to go.
Rick
motocd.com
Old 11-04-2013, 09:57 PM   #8
Deadelk OP
Oddometer: 15
Finished the forks and rear shock yesterday, just in time to see the sun go down.
I hate Daylight Savings.
Hope to try the changes out this week.
Old 11-05-2013, 01:19 AM   #9
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,282
I don't know about installing a different shock, but I pulled and reinstalled the stocker by lifting the bike, removing the lower bolt and links, loosening the airbox by removing its mounting screws, removing the upper shock bolt, and wiggling the shock past the airbox, out the bottom of the frame. It went right back in the same way.
Some are guard dogs of the flock. Some herders, search/rescue, or companions. We Devildogs are those, and also retrievers. Hell is our blazing dogpark, our frigid swimming hole. The fallen are our tennis balls. We don't leave the fallen behind, even if the master has to bring them home for us. Semper Fi, my friends.
Kommando is offline   Reply With Quote
Old 11-05-2013, 04:01 AM   #10
DR Steve
DR Steve's Avatar
Oddometer: 315
I've had mine in and out a few times now by dropping it out the bottom. No need to remove or loosen anything other than the lower linkage.
'13 DR650
DR Steve is offline   Reply With Quote
Old 11-05-2013, 07:08 AM   #11
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 621
Really? Have not had any luck with that...
Rick
motocd.com
Old 11-06-2013, 03:16 AM   #12
DR Steve
DR Steve's Avatar
Oddometer: 315
Yes, it's one of your shocks too.
Probably should have been a bit clearer - still need to remove the seat to get to the top shock bolt, but I've not needed to remove or loosen air box/exh. Might be the smaller lower collar/clevis on your shock and my custom midpipe might be giving a little more clearance. Still using the stock header.
'13 DR650
Times are GMT -7.   It's 08:00 PM.
