Old 10-31-2013, 06:41 AM   #18421
BuRPsa
Finally growing up..
BuRPsa's Avatar
Oddometer: 548
Johann,
take carb off, clean it (again, and use compressed air) and set floatlevel to 19mm (? - 1mm more than std).
Set airscrew to 1.5 full turn out (about right).
Turn up the slide-screw a little.
Follow the correct starting procedure (hope you know this?) and have fun.
BuRPsa is offline   Reply With Quote
Old 10-31-2013, 07:21 AM   #18422
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,341
Hard Starting
When I went back to the stock carb and wasn't sure what settings would work right, mine was a bitch to fire, too. We ended up bump-starting it. Once it was lit up, it was easy to get the adjustments to a more appropriate position and it became easier after that.
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 10-31-2013, 10:47 AM   #18423
medisyn
Oddometer: 149
^^THIS. This was the only way I could get mine started after I cleaned and changed the jets on my carb. A push start and then tweak from there and it has been good ever since. I recall push starting it in 2nd or 3rd.
medisyn is offline   Reply With Quote
Old 10-31-2013, 04:35 PM   #18424
1bigrn
Oddometer: 233
upgrading lighting with LED.
im looking to add some LED lights to my XR. The baja design halogen that is on it now is fine. But I need to add some seriouse lighting for next year. The 100W baja halogen doesn't put out enough light for bush riding up north and a moose or deer coming out of the bush in front of me is a legitamite issue.
I'm leaning towards the Baja Design Squadron Light that puts out 4300 lumens.
http://www.bajadesigns.com/ProductDe...umber=497001BK
Or the ADVMosnter fairing with dual LED.
One being flood beam/ 3600 lumens, one spot beam 2700 lumens . For a total of lumen 6300.
http://stores.homestead.com/hstrial-...ing/Detail.bok
http://stores.homestead.com/hstrial-...off/Detail.bok
http://stores.homestead.com/hstrial-...oad/Detail.bok
The Baja Design is a nice clean set up but the ADV MOnster offers some wind protection.
Both items cost about the same. What would people suggest.
AA
1bigrn is offline   Reply With Quote
Old 10-31-2013, 04:49 PM   #18425
drdfblackm
VeeFeer
drdfblackm's Avatar
Oddometer: 864
AA
I had the ADVMonster unit on a previous bike. It is a good product. Put together well. Fairing is made well. I am sure that the Baja Design one is awesome but you pay a premium for that awesomeness. It appears that CREE makes a similar light as the Baja Design and you can mount in your own shroud.
These are not the droids you are looking for.....
drdfblackm is offline   Reply With Quote
Old 10-31-2013, 06:08 PM   #18426
ReadySetGo
ReadySetGo's Avatar
Oddometer: 95
Barnum engine
Crypto666, Not sure how large they went on the valves, the engine invoice that came with the bike states 'kibblewhite valves' but not size. The way the engine runs at high rpm's leads me to believe there's valve/head work done. Will find out when/if I get in touch with Rob. I have a complete running parts bike waiting so if I need another head/part I have them.
drdfblackm, Glad to hear he's still around, all searches for his name on google seem to lead to older post.(2008-older) My paperwork Justin gave me has 2004 info(when the motor was built/ I think). I even searched (some) on T.Talk. I'll P.M. you when I have more time, hopefully he still working on motors and be able to help.
I've lurked on ADV (and other forums) for many years and I've read a lot about the longevity (or lack thereof) of "built up motors" but my experience leads me to conclude that they can last if built properly and maintained properly, seem this motor was built the right way. That's the reason I was looking for Rob. (My 2 cents nobody asked for )
Thanks for the response.
Wendy
____________________
2005 SV1000
1996 Honda Magna 750
2006 Honda XR650L
ReadySetGo is offline   Reply With Quote
Old 10-31-2013, 10:43 PM   #18427
MCVL
MCVL's Avatar
Oddometer: 272
Johann XR650R
Jets seem to be ok, it should start with choke full on
Try removing the spark plug and look at its condition (wet, dry) and check if it gives the spark. If the spark is there and the plug is wet then you need to first try improving your starting technique by sometimes opening wide open throttle, holding decomp lever and kill switch and kicking through 5 times or more, then the standard starting procedure. Or the easiest way - bumpstarting, if not enough bumping power use the decomp lever - neutral, accelerating, clutch in, 2nd gear, decomp in, clutch out, decomp out, trottle from closed to wide open until starts
MCVL is offline   Reply With Quote
Old 11-01-2013, 06:21 AM   #18428
graygoat657
Oddometer: 328
AA
Baja Designs. Made in the US, Lifetime warranty. If you don't intend to keep the bike, then maybe go cheaper.
graygoat657 is offline   Reply With Quote
Old 11-01-2013, 09:33 AM   #18429
AlpinaE24
Oddometer: 589
Yo guys,
My neighbor bought a low hour '01 off of CL 3 nights ago, rode it around the block and 1 mile in the clutch bushing seized. I found him at the stop sign and offered to help him out. I popped the side cover and clutch out, but the outer basket and bushing will not come off the shaft.
At this point I decided to just take it down to north valley honda to have them use a puller/press to get it off. But alas, they have been trying to 2 days with zero luck. I really feel bad for this guy, he just dropped $2300 for a bike that might need to be completely torn down.
Advice? Ideas? Who has gotten a seized bushing off sucessfully without f-ing the shaft?
2003 KX500-plated, 1996 Husqvarna WXE250-plated, 2001 YZ290F
-sold- 2000 XR650R, 2000 XR600R, 1985 XL600R, 1994 XR650L
AlpinaE24 is offline   Reply With Quote
Old 11-01-2013, 09:36 AM   #18430
galland1
galland1's Avatar
Oddometer: 130
If it was mine I would try some heat. Then a die grinder and chisel. Scary stuff.
Sent from my SPH-L720 using Tapatalk
galland1 is offline   Reply With Quote
Old 11-01-2013, 11:46 AM   #18431
brayjay
Oddometer: 251
Originally Posted by AlpinaE24 View Post
Yo guys,
I feel for him, I just paid $4000 for a immaculate LOOKING 2002 that needs an entire rebuild top to bottom. Only thing I can think of is someone swapped the original motor to use on something else and replaced it with this junker. Bought it site unseen so it's my own fault. Live and learn.
brayjay is offline   Reply With Quote
Old 11-02-2013, 10:27 AM   #18432
MCVL
MCVL's Avatar
Oddometer: 272
I bought mine for 5000, it was the cheapest price for them around here, needed a complete top and bottom end rebuild almost as soon as I got it, after it was done and I happily rode for about 700 miles I noticed a sound at the head and after another 700miles of constantly adjusting valves I finally opened it, the rockers and camshaft were worn out the same as how it was at the first rebuild, mechanic that did all that work installed a bearing on the camshaft the wrong side becouse it was like that when he first disassambled the engine
Smth like that http://www.vancouversupermoto.com/cm...XR650R-cam.jpg
it seems it was enough to wear them out, another mechanic suggested to repair the old ones at the workshop, it was 5 times cheaper than new rockers and camshaft, but they did it incorrectly, so there always have been a noise, when I finally got a new camshaft, the noise didn't go away, becouse of the stress, the valve guides wore out too, so now after a year I have to replace them with valves that are now twisted
So, I think that 2300$ is a very good price, don't let it go down on him
MCVL screwed with this post 11-02-2013 at 11:43 AM
Old 11-02-2013, 02:05 PM   #18433
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 788
Bolt type for steel SunTour? Thx!
I have a SunTour 45 tooth rear sprocket planning to use.....but
it does no take the tapered bolts used on alloy sprockets.
I am sure the non-tapered bolts are common, but I could not find them online and dont know what OEM part to ask for.
XR650L or DR650 sprocket bolts and nuts?
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 11-02-2013, 03:03 PM   #18434
ADVSearcher
ADVSearcher's Avatar
Oddometer: 217
Time for a daily life pic of my pig ...
Free riding through the woods trying to find a singeltrack or gravel road ... Got stuck in a ditch totaly exhausted with a soon boiling piggy & my buddys just want to fiddle around with the cameras instead of helping me out
ADVSearcher is offline   Reply With Quote
Old 11-02-2013, 05:50 PM   #18435
DocAxeYarYar
RideDualSport.com
Oddometer: 788
Sweet!
Nice picture, far superior to my very lame picture of a hole in a sprocket.
Thanks for sharing!
My XR650R Build:
Times are GMT -7.   It's 01:32 AM.
