Old 11-01-2013, 06:50 PM   #1456
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,176
Originally Posted by motolab View Post
So, if you changed a light bulb, and the engine ran poorly afterward, you would change it back?
Regards,
Derek
If you updated some wiring and changed out a working light bulb, and the light shines poorly afterwards, would you change it back?
That said, I agree that a faulty slip on muffler is not likely to have a great effect on idle but run fine otherwise.
Sent from my SCH-I535 using Tapatalk 2
Sparrowhawk is offline   Reply With Quote
Old 11-01-2013, 07:04 PM   #1457
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,506
The installation of a slip-on muffler alone will not make such a drastic change at idle that a mixture screw adjustment can't fix it. If it won't, it's a foregone conclusion that something else is wrong.
Regards,
Derek
I don't entertain your level of confidence.
Old 11-01-2013, 08:32 PM   #1458
bmwktmbill
Traveler
Oddometer: 5,107
Test the continuity of the light bulb, run some water thru the pipe. First tighten the carb.
Pull the rag out of the air intake, ya I'm an idiot, yes I did that, ran a little, then quit.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 11-01-2013, 08:38 PM   #1459
motolab
motolab's Avatar
Oddometer: 2,584
That means you need to gain some additional experience.
Regards,
Derek
motolab is offline   Reply With Quote
Old 11-01-2013, 11:07 PM   #1460
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
Originally Posted by meat popsicle View Post
But now onto my issue: what makes bikes not want to stay running when cold, even with the enrichner?
tight valves can cause this
2 SPOT is offline   Reply With Quote
Old 11-01-2013, 11:12 PM   #1461
motolab
motolab's Avatar
Oddometer: 2,584
This would be more pronounced when the engine is hot.
Regards,
Derek
Old 11-01-2013, 11:19 PM   #1462
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
not always.
Old 11-01-2013, 11:25 PM   #1463
motolab
motolab's Avatar
Oddometer: 2,584
not always.
Name such an instance and the reason for it.
Regards,
Derek
Old 11-02-2013, 12:21 AM   #1464
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
i cant, i pulled that suggestion right out of my ass with absolutely no background or experience to come up with it,,,,,
so sorry, wont happen again.
Old 11-02-2013, 08:21 AM   #1465
Tonicu
Oddometer: 168
Question Lc4 bst 40
I posted this on the incredibly good LC4 thread, but maybe this one is more appropiate. Please excuse me for the copy&paste. Pictures here :
http://www.advrider.com/forums/showt...86958&page=312
I found some time to pull the carb after the bike completely stopped and refused to start again when at single track steepy sections. As usual, it run fine on road but not so fine offroad, continously stalling.
The carb was full of gas, flooded. Apart from the weird colour of the needle all the rest looked fine. The needle was in the 4th slot from the top ... before I lost its circlip.
A few of you suggested it could be running lean and causing overheating, but taking a look inside the carb it doesn't seem to be the case.
I was hoping to take a look at the jets but haven't yet succeeded in unbolting those butter screws at the bottom of the carb.
This carb is a second hand one with only 12k kms, plus another 5k I've done, since the older one needed a new slide&guide, membrane and needle at 50k kms.
Tonicu is offline   Reply With Quote
Old 11-02-2013, 08:30 AM   #1466
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Its real easy to misconstrue a person's tone or intent in forum posts. Thanks to all for throwing their ideas on the table.
2 SPOT: Valves were adjusted by Scuderia West less than a thousand miles ago (I didn't have time to do it myself, but they are a good shop). If they've slipped this quickly I'd be real pissed.
bill, I'm guess if the new exhaust can was a dud it would effect how it runs when hot too. I'm going to chase down these other possibilities first (air leaks, old jets, fine tuning). Although I would just pull the exhaust can and test cold start before running water through it.
Now I did have a paper towel blocking the engine-side carb boot; I'm pretty sure I pulled it before shoving the carb back on... but wouldn't a blockage enrich the air-fuel mixture like a true choke and interfere with warm running?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 11-02-2013, 09:47 AM   #1467
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,218
we'll assume the valves are in spec, next i go to a low float height.
my suggestions are based on the bike running fine before you didnt really do anything but a mild carb rebuild including moving the float height, you didnt say how the float height was set but i am thinking you found it high and lowered it?
Old 11-02-2013, 11:45 AM   #1468
motolab
motolab's Avatar
Oddometer: 2,584
Low float height equals high fuel level.
My advice to Meat was and is to set the float height between 14.7 (standard) and 16.7mm. The reason for suggesting more than 14.7mm is because the mixture on BST40-equipped 620-660 LC4s tends to be richer toward the bottom (in terms of rpm), which will be exacerbated by opening the airbox and installing the correct main jet to go with that (not recommended on pre-highflow models unless significant measures have been taken to prevent detonation), as well as by emulsion tube wear (over time). That said, a strange float height adjustment alone will not cause the idle mixture to be so far off that adjusting the fuel screw can't correct it. If anything, a low float height will cause the engine to start more easily from cold.
Regards,
Derek
Old 11-02-2013, 01:41 PM   #1469
motolab
motolab's Avatar
Oddometer: 2,584
I think this one is more appropriate.
Make sure that the float seat is clean, free of debris and undamaged. Replace the float seat o-ring if it is cracked/shrunken/deformed/hardened or otherwise damaged. Replace the float needle if there is a witness line evident under magnification where the tip has been contacting the seat. Replace the float assembly if one or both of the floats are fuel logged (this happens rarely). Using a float height setting tool, set the float height to 14.7-16.7 mm.
Does it run better when the engine is cold, or when it is hot?
Use a hand impact driver with the appropriately sized JIS bit. Reassemble with socket head cap screws.
Regards,
Derek
Old 11-02-2013, 01:58 PM   #1470
Mo-Tarded
Mo-Tarded's Avatar
Oddometer: 177
Originally Posted by Sparrowhawk View Post
Meat, is it possible that you have some schmutz in your idle jet or circuit causing it to be a little lean and unresponsive to adjustment?
I was thinking the same thing... If it has sat for any length of time perhaps it has ethanol poisoning.
"Our lives can be spent carrying out actions that we hope will lead us to a greater sense of purpose, accomplishment and meaning, but all these are secondary to the need to feel alive." - AntiHero ADV Rider
Mo-Tarded is offline   Reply With Quote
Times are GMT -7.   It's 03:53 PM.
