Old 11-04-2013, 09:49 AM   #1
wiseblood OP
Hall Monitor
wiseblood's Avatar
Oddometer: 13,161
Is my clutch slipping?
Hey All --
This is regarding a 2007 950 SMR with about 13k miles.
This morning on my commute to work, I noticed something I had never noticed before. In 6th gear, I was having some trouble rolling on. At a certain point in the throttle, opening more did not result in any power. I can't be sure the RPMs were still building, but it definitely felt odd. Like it wasn't "gripping" any more.
Things of note: It was damn cold -- about 34F. (Engine was plenty warm, though.)
It didn't feel like the rear was breaking loose -- no sliding sensation. Just, like the clutch was letting go.
Any suggestions on how to confirm this is the issue, before buying all new friction plates?
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
Big Apple Tag-o-Rama Maps: Click Here!
wiseblood is offline   Reply With Quote
Old 11-04-2013, 09:57 AM   #2
WildAnCrazymtl
Political Prisonor
WildAnCrazymtl's Avatar
Oddometer: 6,307
You could try loading the engine in a hill...
"Work negatively inpacts my free time !" Me.
"Ride it like you stole it, then do the same to me ! " Her.
"A good thing in a bad place, is still a good thing ! " Us.
____________
R1200GS 09
DRZ400 03
WildAnCrazymtl is offline   Reply With Quote
Old 11-04-2013, 10:04 AM   #3
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,176
I had a similar issue in September.
Bike simply had no power. Couldn't keep highway speed on hills.
Turned out to be a damaged diaphragm in the rear carburetor.
Possibly damaged by ethanol.
Check to see if the slide sin the carb snap back quickly when moved with your finger.
If not, it could be the diaphragm.
Let us know.
Q~
Questor is online now   Reply With Quote
Old 11-04-2013, 10:04 AM   #4
tcskibike2008
SnowHawker
tcskibike2008's Avatar
Oddometer: 195
If your clutch was slipping your RPMs would go up but you wouldnt feel the acceleration. Sounds like its just not producing power when its cold.
tcskibike2008 is offline   Reply With Quote
Old 11-04-2013, 10:10 AM   #5
wiseblood OP
Hall Monitor
wiseblood's Avatar
Oddometer: 13,161
I'm gonna try to reproduce this on my ride home. It was still dark out, so I wasn't able to apply as much mental cycles to troubleshooting (while dodging the last of the weekend drunks).
Old 11-04-2013, 02:45 PM   #6
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 512
I bought a used 950SE recently and one of my checks was to see if the clutch was good. It goes against the grain to do this because normally one is sympathetic on the clutch to make it last. Anyway its easy to check, even in the city in the wet. Just go up to top gear, pull the clutch, rev it, drop the clutch and it should almost instantly kill the revs down to fully engaged with power. If it does that then the clutch works and its probably something else. Not very conclusive I know, and not at max torque/power but good enough.
950 SE
WR250R
950 ADV
ICERIDER is online now   Reply With Quote
Old 11-05-2013, 05:19 AM   #7
wiseblood OP
Hall Monitor
wiseblood's Avatar
Oddometer: 13,161
I did this a couple times this morning. About 30-40 mph... up to 6th gear... pull in the clutch, then let it out. The engine bogged immediately.
Based on that, it seems like maybe my issue is something else. Still kinda unsettling. I'm not used to having a "flat spot." So far, it only happens at about 80 mph in 6th gear when rolling on.
Old 11-05-2013, 07:47 AM   #8
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 512
Aha! It sound like we're into the realms of carburation. My 950's do this exact same thing and I put it down to a weak mixture. Just make sure you have no air leaks or vacuum leaks and the tank vent is working.
Above that it means removing the tank, checking float levels, checking diaphrams etc as advised, perhaps raising the needle 1 clip. If you're not into all that just ride around it. Probably showing up more now the temps are dropping.
950 SE
WR250R
950 ADV
Old 11-05-2013, 08:12 AM   #9
wiseblood OP
Hall Monitor
wiseblood's Avatar
Oddometer: 13,161
Humm... Maybe. Just didn't feel right to me. Power just ended. It didn't fade... it felt like it just broke loose.
I did service the carbs at the end of April, and they looked OK. Also, did my 9500 mile maintenance which included inspecting for leaks, just three months ago. Maybe I'll give 'em another look.
Old 11-05-2013, 01:33 PM   #10
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
to rule out the clutch issue i'd go to a steep hil and in 6th gear perform a few roll ons accelerations loading the engine. If it slips you'll know right there, revs will skyrocket after a certain point! If nothing wrong and unprepared, you+bike might take off, so be carefull!
If not, still flat spot, than there's something related to air/fueling.
Try this, in 80mph in 6th when you feel the flat spot, pull the choke lever. if the flat spot disappeards then you've got a air problem (the bike, not you!) probably a leak, of bad diaphragm in one carb.
690R
Old 11-05-2013, 02:07 PM   #11
Questor
More Undestructable
Questor's Avatar
Oddometer: 4,176
Still thinking the diaphragm may have problems and the slide is not working as well as it should.
Your symptoms sounds exactly like what I was experiencing.
On either end of the carburetor there is a black plastic dome.
In that dome is a spring and a rubber diaphragm.
The rubber diaphragm can get torn or have splits in it.
KTM part:
Vacuum Piston Cpl
60031035000
The bike will be normal most of the time, till you need the power and then it will just feel flat. Like you're "missing" power.
Like going up a hill in 6th gear on the highway, and you just don't have all the power you are used to.
The rubber diaphragm is not hard to get to. I'd check that.
Open up the air box.
Pull off the cones.
Use your finger to push the slides back.
They should slide back slowly.
If one slides closed slowly, that would be an indicator of a torn diaphragm.
This just happened to me last month.
Let us know what you find.
Q~
Questor screwed with this post 11-11-2013 at 09:36 AM Reason: Slides should move slowly, not quickly
Times are GMT -7.   It's 07:48 AM.
