Old 11-13-2013, 12:46 PM   #16
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Location: Near Six Flags Great Adventure in "God's country"
Oddometer: 384
www.Ohlinspro.com
www.ProPilotSuspension.com
It's and exact Science
Ohlinspro screwed with this post 04-24-2015 at 06:04 AM
Ohlinspro is offline   Reply With Quote
Old 11-13-2013, 12:59 PM   #17
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Originally Posted by kbroderick View Post
I pm'd Monday evening about rear shock and potentially front fork service in a somewhat unique application; did you get the PM?
(I'm guessing it's a weird-enough situation that you may still be trying to decipher it, but I wanted to make sure it got through.)
Thanks,
Kevin
Hi Kevin!
PM Sent!
THX!
Ohlinspro screwed with this post 02-06-2015 at 06:29 AM
Old 11-13-2013, 01:28 PM   #18
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
OHLINS NEw Stlye STEERING DAMPER KTM
Tom-
The Ohlins DAMPER will Fit on your 2014 ktm
They Dampen OUT from Center / Zero back to center-
Both Dampening Level and Return-to -center is easily adjustable with the top clickers
Mounts Under bars / steering stem nut , no need for risers-
Old 11-14-2013, 06:51 AM   #19
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Ohlins sale
Custom SPRING SWAPS for Your Weight and Conditions INCLUDED FREE!!
BMW R 1200 GS and GSA Mechtronic Electronic Controlled OHLINS KITS
OHLINS TTX PIGGYBACKS BMW R 1200 GS and GSA
Popular BMW R 1150GS GSA Ohlins Shown With OPTIONAL BLACK "O" -MUC-VENTURE- COVERS
Ohlinspro screwed with this post 01-31-2015 at 08:32 AM
Old 11-14-2013, 08:43 AM   #20
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Elka Shocks Stage -4 Way Adjustables
Ohlinspro screwed with this post 01-31-2015 at 08:33 AM
Old 11-15-2013, 06:39 AM   #21
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Nitron shock sale!
www.propilotsuspension.com
Ohlinspro screwed with this post 01-31-2015 at 08:34 AM
Old 11-16-2013, 01:38 PM   #22
vnp514
Oddometer: 631
pm sent
vnp514 is offline   Reply With Quote
Old 11-25-2013, 06:31 AM   #23
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Mr Glass angles Tracking Sent for ARound HOLIDAY
Hi Mr Glassankles- (aka M/K.)
Pm sent with tracking , .
can arrange UPS to Hold till after Holiday Delevery -
Let me know if you want us to do it on this end if you prefer-
THANKS!
www.Ohlinspro.com
732-928-7800
Ohlinspro screwed with this post 01-09-2014 at 07:55 AM
Old 11-25-2013, 06:37 AM   #24
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Originally Posted by Ohlinspro View Post
Tom-
I would like to consider this for my 2009 KTM EXC 530 instead of the scott's mount I see on every other KTM out there. If you have a sub mount solution that bolts on as quick as the scott's KTM system and still allows for bar risers/position 3 and 4 type mounting please provide to me a price I can't turn down
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 11-25-2013, 07:33 AM   #25
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Will send pm-
The mounting instructions to attch-
wilth these, no need for high or different handlebar risers as an additional expense, they fit right over stem nut, and use a lobe on rear top bearing raise to center,
easy to install
THANKS!
Old 11-27-2013, 04:44 AM   #26
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
BMW F 800 GS 08-13 COMBO CART kit and NEW OHLINS Shk
HOLY -SWEETNESS!
The most popular Full PRODUCTION CARTRIDGE KITS and Ohlins NEW fully adjustable updated Shocks COMBO-KIT-PRICING-SALE!
The Standard fork has Stamped Steel Sealed "non-fixable" and "non-revalvable" inner struts shown below (Lower pic center) with Non Adjustable Spring Caps or Damping.
They have no bottoming control,and only a 9mm inner rod with basically a "throw-away cartridge" and over preloaded "Super -soft springs".
THE Best Fix is the Ohlins Whole internals with New Springs set, 34mm Od Alum. CArtridge with 12mm Heavy duty rebound rods, and a 55mm tapered bottom out hydraulic cone, with a 160mm internal spring guide, fully external adjustable Spring Preload , Rebound ,Compression damping.
The Newest Ohlins Rear Shock (ONLY CAME AVAILABLE 11/1/13 ) is Divided Fluid , Nitro, adjustable with NEW Style Preloader Spec with More Function and improved features.
F800 GS
Ohlins NEWEST Fully ADJUSTABLE Preload,Compression,Rebound Kit Ohlins NEWEST BM303 SHOCK
Ohlins Piston,Adjustable Valving ( lower PIC Std Top Ohlins New Cartridge ) Adj Preload,Rebound,Compression
MANY THANKS!!!
Ohlinspro screwed with this post 03-28-2015 at 05:53 AM
Old 11-27-2013, 04:22 PM   #27
ssevy
Oddometer: 924
Do you have fork replacement sets and rear mono shocks for a 1995 Triumph Tiger?
Thank you.
ssevy is offline   Reply With Quote
Old 11-29-2013, 05:01 AM   #28
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Thank you.
Will PM you some options -
THX!
Old 11-29-2013, 05:09 AM   #29
Ohlinspro OP
We sell all brands!
Ohlinspro's Avatar
Oddometer: 384
Black friday thru syborger monday PLUS sale!
THANKS! DAVE C.VA For Your Order!!-
Ohlinspro screwed with this post 12-26-2013 at 08:27 AM
Old 11-29-2013, 05:53 AM   #30
NVTS
stupid hipster dufus
Oddometer: 678
Can you PM me a price on a shock for BMW XChallenge. No luggage, ridden aggressively, 200lb rider with gear. Thanks!
NVTS is offline   Reply With Quote
Times are GMT -7.   It's 07:33 AM.
