Old 02-21-2013, 02:19 AM   #46
L21
Oddometer: 201
Yes just over inflate tube
L21 is online now   Reply With Quote
Old 02-21-2013, 08:06 AM   #47
Hikertrash
Oddometer: 2,990
Originally Posted by TUCKERS View Post
Are you going to change your tubeless tires on the road yourself?
No need for bead breaker or tire irons on a BMW R1150/1200GS.
I agree 100% if you only ride pavement or graded dirt roads. I have plugs in my standard kit, but I also carry a set of bead breakers and tube when I go on extended or more serious off road trips should the rim get bent and not be able to hold a seal. If you're always within cell phone service, yeah I can see no need for the extra weight, but if you travel to remote places, the extra 3lbs is no big deal. I changed my tires with the bead breakers so I'd know how to do it in the field. I don't plan on changing the tires out again like that, but I now know how to throw a tube in them should I need to.
Hikertrash is offline   Reply With Quote
Old 07-20-2013, 07:39 AM   #48
VietHorse
VietHorse's Avatar
Location: Recalculating... recalculating.... HCMC-Vietnam :)
Oddometer: 1,611
Made this thing for the front wheel axle (Hex14mm - Hex22mm):
VIETNAM by Motorcycle | My Ride Reports on ADV
VietHorse screwed with this post 07-21-2013 at 07:10 AM Reason: Added a clearer pix for inmates who PMed for details.
VietHorse is online now   Reply With Quote
Old 11-19-2013, 08:17 AM   #49
Flyboygus
Oddometer: 4
Electrical connections for the tool kit
Just thought many of you might appreciate this, a water proof connector that is reusable.
Especially when you are in the boonies without a soldering iron :-)
http://www.posi-lock.com/positite.html
You just don't want to leave home without one IMHO.
Flyboygus is offline   Reply With Quote
Old 11-22-2013, 04:58 AM   #50
pauljm
R1200GS WC
pauljm's Avatar
Oddometer: 77
Good starting toolkits.
These toolkits are a great start.
http://www.motohansa.com.au/catalog/...ducts_id=66547
Add multigrip, extra zipties, metal putty, tyre repair kit & your pretty close.
R1200GS LC
pauljm is offline   Reply With Quote
Old 08-23-2014, 06:58 AM   #51
Andrew011
Tourist
Oddometer: 31
Another idea for front wheel removal tool: welded 22mm nut to 1/2->3/8 adapter.
Also made an extendable 1/2" lever.
Still working on the ultra compact/lightweight/small toolkit for 1200GS..
R1200GSA 2009
Andrew011 is offline   Reply With Quote
Old 09-17-2014, 07:22 PM   #52
Friction275
Oddometer: 121
This is the tool kit I run with on my 09 R1200 GS.
There's nothing in it that different from other kits. The only thing I do differently, as far as I can tell, is use some things in different ways from others.
-I use my socket extension as a screwdriver via an adapter for the hex bits so I don't have to carry separate full size screwdrivers. The tape on the extension works fine as a grip.
-I use a slide bar fixed socket with a ratcheting adapter so I can use it as a breaker bar or a ratchet. When I use it as a breaker bar I can loop one of the wrenches through it to gain extra leverage.
-I got a silver bag instead of a black one so I could write the torque specs down on the inside of the bag. Not really applicable on the side of the road but handy to have when I'm in the garage or at a shop somewhere.
-I ground down the edges of a 5/8" deep socket to use as a plug wrench. This may have been the long way to go but I had a spare 5/8" socket and none of my plug drivers were small enough to fit in the hole.
I carry a separate tire repair and medical kit so this is just the tools.
Friction275 screwed with this post 09-18-2014 at 04:53 AM
Friction275 is offline   Reply With Quote
Times are GMT -7.   It's 03:18 AM.
