Old 11-18-2013, 09:56 AM   #1
mopulga OP
Oddometer: 425
Short fork boots
Hi all,
Quick question - What model/year airhead BMW used the short 2-3 inch boot covering the fork seal? It is the hard plastic one.
Thanks ya'll.
i
mopulga is offline   Reply With Quote
Old 11-18-2013, 10:54 AM   #2
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,024
First year for the short fork boots was 1974, the R90S.
Pokie is online now   Reply With Quote
Old 11-27-2013, 10:14 PM   #3
tlub
tlub's Avatar
Oddometer: 327
fork boot or slider?
The S (and RS) models had what the previous poster said. But the other models used ribbed boots that protected the slider better until the /7s were no more. However, many folks still add the older style boots to later bikes since they do a much better job of protecting seals from bug abrasion.
tlub is offline   Reply With Quote
Old 11-28-2013, 10:15 AM   #4
supershaft
because I can
Oddometer: 9,116
Many people put the earlier fork boots on later bikes and they do not fit right but then many people put the earlier boots on earlier bikes wrong and they do not fit right. Apparently Duane Ausherman has made it popular for people to not pull the bottom of their boots down to their mark on the fork slider where they should be so that the boot will not be pulled as tight while the bike is on the centerstand. The trouble with that is that the boots bunch up and restrict suspension travel by quite a bit. I am more concerned with how they function while the bike is being ridden! They are much too long to be placed at the fork seal. On the later bikes you can't pull them down far enough if you wanted to for the fork brace. What works on the later bikes is Monolever GS fork boots. They don't bunch up and restrict travel.
supershaft screwed with this post 11-29-2013 at 09:59 AM
Times are GMT -7.   It's 06:10 AM.
