Old 10-22-2013, 08:39 PM   #1
Alejo OP
Alejo's Avatar
Oddometer: 181
Neutral Sensor failure
Hello mates...
KTM 990 2007 - S.
Bike starts fine in the morning, neutral green light ON..... when it gets hot neutral green light goes away and bike turns off... if i pull the clutch lever then the bike starts and i can release the clutch lever. it stays on but every time I turn off the bike and turn on again I have to pull the clutch lever even though the bike is in neutral (neutral green light off but bike is in neutral).
Any idea of what is going on??
I will appreciate.
Sorry for my English, it is not my primary language.
Once you ride Off road you will never want to go on road again
Alejo From Costa Rica Centro America
Alejo is offline   Reply With Quote
Old 12-03-2013, 05:59 PM   #2
dgjackson40
Oddometer: 276
No answer?
I am having probably the same issue. This is my first post as the proud owner of a 2007 990. I picked it up Friday purchased from a friend and fellow ADV Rider member. He is awaiting his 1190. Anyway, when I got the bike home Friday after about a 100 mile trip I parked outside my garage and just put the kickstand down to kill the engine while I opened the garage door. I then got back on the bike and pulled in the clutch and started the bike and drove into the garage. I could not get the neutral light to come on for the life of me. It would go in neutral but light would not illuminate and when I put the stand down it killed the engine. When in what I presumed was neutral you could hear gear chatter at that time. I then let the bike set for about 30 minutes and tried the neutral and the light came on, bike would start and run with stand down. Then today I pulled into the driveway after work and put the bike in neutral and put the stand down and let it run. I went and opened the garage door. Before I got back to the bike the neutral light went out and the bike immediately shut off. I pulled in the clutch put the stand up and started the bike and put it in the garage and was able to get the bike in neutral with a light and let it idle for a while to see if it would shut down again. It didn't so that is where it stands. Its seems to be sporadic. Is this a side stand switch issue or what? I love the bike by the way and as I do not have a gremlin bell on it as yet perhaps that'll solve the issue if someone bestows one on me!
dgjackson40 is offline   Reply With Quote
Old 12-03-2013, 09:22 PM   #3
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,180
Well, it's a really simple switch. There's a small plunger that wipes across contacts and grounds them. So, it's dirty, down in the engine oil you know. Or the wire is weak, connector loose, etc.
I'd vote for a dirty connector. Pull the cover over the front sprocket, pull off the switch and lightly sand off the brass contacts. Don't loose the plunger/spring.
"Son, you can't do both"
Old 12-03-2013, 11:04 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
I will add
Sidestand could be loose. Also all the collected grim behind the front sprocket could cause problems.
Cheers
Old 12-04-2013, 07:33 AM   #5
renogeorge
Oddometer: 1,486
Check sidestand switch--common failure point
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 12-04-2013, 08:21 AM   #6
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,283
Also, check the gear position sensor. They are known to come loose and cause quirkiness. If the two retaining bolts are loose, just Loctite them in place.
Orangecicle is offline   Reply With Quote
Old 12-04-2013, 11:42 AM   #7
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,180
Cheers
Yeah, this can cause running problems. But, his neutral light doesn't come on... so probably not the main problem.
Old 12-04-2013, 09:36 PM   #8
dgjackson40
Oddometer: 276
I plan on installing the sidestand relocation kit this winter so I am guessing I can sort this all out at that time and clean things up.
Old 12-05-2013, 05:59 AM   #9
motomal
motomal's Avatar
Oddometer: 175
http://www.advrider.com/forums/showthread.php?t=746414
This old thread may help you out... Good luck.
2007 KTM 950 SM
motomal is offline   Reply With Quote
Old 12-05-2013, 01:34 PM   #10
dgjackson40
Oddometer: 276
Thanks motomal!
Old 12-06-2013, 12:14 AM   #11
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
So it may happen to 990s as well as 950s.
If the gear drum with the extrusions slides, it could be a solution to drill a small hole and screw a small headless bolt in there. That could be a permanent fix.
http://advrider.com/forums/showthrea...=746414&page=2 post # 24
Cheers.
Old 12-07-2013, 06:05 AM   #12
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,735
I have Pebbles's old shift drum. The drum is steel and the plate with the gear indicator holes in for the springs and plungers is alloy.
I can easily move the plate with a pair of circlip pliers. Probably best to move it to the correct position then lock in place with several dot punch marks around the perimeter.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 03:02 AM.
