Old 12-14-2013, 07:44 AM   #1
mitchell205 OP
Oddometer: 150
950-990 exhaust question
Hey if anyone has a 950-990 muffler laying around that could measure the inlet size and overall length for me that would be great. I have a new husky terra 650 and was contemplating useing the dual fmf's from a 950 if I can make it work since there's not much in the way of aftermarket. Thanks
2014 Terra 650 2006
2007 KTM 250
1973 Honda CB200 Cafe racer
mitchell205 is offline   Reply With Quote
Old 12-14-2013, 10:53 AM   #2
WIsixfitty
ceiling unlimited
Oddometer: 2,288
I have an OEM/stock one at my shop I can measure up if that will work.
It might be a day or so before I get back there tho.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 12-14-2013, 01:17 PM   #3
mitchell205 OP
Oddometer: 150
Yes
Yes thank you
2014 Terra 650 2006
2007 KTM 250
Old 12-14-2013, 02:20 PM   #4
WIsixfitty
ceiling unlimited
Oddometer: 2,288
OK here it is. The stock anchor silencer.
All dims are in inches so the measurements will be a bit wonky as it's built to metric tubing etc.
Over all length 19.5"
Outside diameter 4.73"
Inlet inside diameter, or the actual hole 1.55"
Outlet tube inside diameter 1.10"
I also measured the tube leading to the silencer. 1.65" OD or (assuming .040" wall) 1.57" ID.
If you need I have a few KTM tubes along with flange rings etc laying around.
Old 12-14-2013, 11:26 PM   #5
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,071
The inlets on the KTM Adventure mufflers would be a pain to hook up. You'd be ahead to just get two Q4 mufflers from a dirt bike which have inlet tubes you can work with.
"Son, you can't do both"
Old 12-16-2013, 01:58 PM   #6
mitchell205 OP
Oddometer: 150
Thanks for the info guys... Best I can tell where it will mount is 1.8 inches outside pipe diameter... The pipe on my ktm 250 is much larger so I guess I will have to find a muffler closer to the right pipe size than a 950...
2014 Terra 650 2006
2007 KTM 250
Times are GMT -7.   It's 12:44 PM.
