Old 12-04-2013, 10:23 AM   #1201
GoGo Gadget
GoGo Gadget's Avatar
Oddometer: 1,275
Originally Posted by RocketMoto View Post
Hi GoGo:
If you purchased your headsets from us, I think we have some extras here. Give us a call and we'll send you a few.
Otherwise these are included in the SMH10 supplies kit.
Sweet. Just called. Thanks
I don't know how or when I'll die, but I know someone will be holding my beer for me when I do.
I have been told I have the body of a God. What does this Buddha guy look like?
GoGo Gadget is offline   Reply With Quote
Old 12-07-2013, 07:03 AM   #1202
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Glad to help
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your *personal* ADVRider discount code to use at RocketMoto.com
Autocom | TPX Radar/Laser | Sena Bluetooth
| Hi-Power LED Lights
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 12-17-2013, 09:29 PM   #1203
simmonsk133
Oddometer: 94
Me 20
Me too on the 20.
Thanks!...
The more I drive the Ural, the better my BMW shifts.
simmonsk133 is offline   Reply With Quote
Old 12-19-2013, 06:40 AM   #1204
CHRIS_D
CHRIS_D's Avatar
Oddometer: 903
RocketMoto,
I been having a lot of problems with the controller's pins staying in contact with it's mounting plate. I have gone through a couple of mounting plates in attempt to prevent this from happening. The pins end up losing contact if you hit controller just right when adjusting volume etc. IMO The mounting plate is too flexible plus there's too much space between the controller's pins and plate. Has Sena done anything to update this mounting plate? Have you heard of this issue before? Thanks!
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 12-20-2013, 11:05 AM   #1205
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Originally Posted by CHRIS_D View Post
RocketMoto,
Hi Chris:
What kind of helmet do you have?
The issue we see most often is this -- the back of the Sena clamp is curved. If the surface of your helmet does not match up with the curvature of the clamp exactly (ie. you can see space or light when sighting down the side of the helmet) then you must use the adhesive mount plate.
What happens is that a helmet that has a very thick bottom edge, like Nolan, Schuberth, or helmets that do not have the proper mating surface to the clamp will cause the plastic vertical part of the clamp to distort and stress. This, in turn, causes pin connection problems to the BT main unit, and often causes the base of the vertical section of the plastic clamp to crack.
If you use the Sena adhesive mount, with our adhesion promoter pad and proper install instructions - on any helmet, the issue will be eliminated as the clamp is now spaced a bit away from the helmet's surface and it will not fall off either. The adhesive mount plate is rather flexible and will match to the contour of a wide range of helmets shells, easily.
Feel free to give us a call, 877.533.4245. We can discuss your particular situation and we'll get you on the right path.
=Adam=
| Hi-Power LED Lights
Old 01-01-2014, 12:32 PM   #1206
brumbackkid
Ntlost
Oddometer: 8
Sena Bluetooth question
I already have a pair of radios..SMH10 I believe. Question for Sena regulars...when using bluetooth and Pandora....will vox voice communication override the music or is it one or the other?
brumbackkid is offline   Reply With Quote
Old 01-02-2014, 07:00 AM   #1207
Ron from BC
Ron from BC's Avatar
Oddometer: 1,376
Sena 20S
Adam, if you've seen this new model can you tell me if the module is as big as the 10?
'02 BMW R1150 GSA
'06 Kawasaki KL250H Super Sherpa
Ron from BC is offline   Reply With Quote
Old 01-02-2014, 10:37 AM   #1208
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Ron:
The 20S is not as tall or deep, but it is a bit longer...
Dimensions of the 20S: 94.7 mm x 48.3 mm x 25.5 mm (3.7 in x 1.9 in x 1.0 in)
The SMH10 main unit, mounted on a helmet clamp is: 83.8 mm x 86.4 mm x 68.5mm (3.3 in x 3.4 in x 2.7 in)
=Adam=
| Hi-Power LED Lights
Old 01-02-2014, 10:41 AM   #1209
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
It will override - that is, it will switch the music off, and will switch back after about 20 seconds of no speech. The forthcoming Sena 20S is 'supposed to be able' to reduce the volume of the music while on intercom, and then resume music to full volume after speaking.
Some folks have found that using the touch the jog dial method to activate the intercom is more reliable and user-freindly than the VOX mode. YMMV.
=Adam=
| Hi-Power LED Lights
Old 01-06-2014, 09:30 PM   #1210
MTvtwin
noob rymes with boob hehe
Oddometer: 79
more please?
Any chance another group order is happening? Planning a trip with lady (her first riding trip) and comms would help... If theres extras please shoot me a PM.
Sean
get busy living or get busy dying.....
http://www.advrider.com/forums/showt...light=krackers
MTvtwin is offline   Reply With Quote
Old 01-07-2014, 06:18 PM   #1211
AdvRydr
De asini vmbra disceptare
AdvRydr's Avatar
Oddometer: 3,252
I'm a little bummed because I just ordered and got a pair of SMH10 units, and only now notice they are not waterproof. Will the SMH20 be waterproof? We ride regularly in rain and so we need some level of waterproofing.
AdvRydr is offline   Reply With Quote
Old 01-07-2014, 06:35 PM   #1212
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,834
Please put me in line for a Sena 20. I love the fact that it has 2 bluetooth modules. I have a Zumo 660 that never worked as it was advertized with my SRC and Galaxy 3/4
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch is offline   Reply With Quote
Old 01-07-2014, 07:16 PM   #1213
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Thumb
In four years, we've had a very small number of water intrusion issues on the SMH10. My guess is the one's that had trouble may not have had the gasket under the back cover positioned properly at the factory. Keep the rubber plug over the USB socket and you should be good.
=Adam=
| Hi-Power LED Lights
Old 01-07-2014, 07:22 PM   #1214
RocketMoto OP
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 933
Should be pretty slick.
Drop me a PM with your email and phone, and we'll add you to the list.
=Adam=
| Hi-Power LED Lights
Old 01-07-2014, 07:33 PM   #1215
Cigars&Scotch
My eyes are up here
Oddometer: 1,834
pm sent
thanks
Mike
77 BMW R90S Huh ?
Times are GMT -7.   It's 10:18 PM.
