Old 12-20-2013, 12:37 AM   #31
tour OP
tour's Avatar
Oddometer: 35
So far some very interresting reading and learning. Thanx
So it seems to me after some more research that the Rottweiler CPR filter system is the way to go. Long standing reputation and all. Had a look at their site but a phone and bad connection makes things a bit slow.
With the SE sausage filter is it still necessary to remove the safari tank to clean the filter or is it just an unclip and remove system? Also filter socks are they available for the sausage?
tour is offline   Reply With Quote
Old 12-20-2013, 06:56 AM   #32
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,281
Want a hack job(diy)...
ITG sausage
ITG baseplate
You should be able to see that i grease the edge when cleaning the filter. I think this is the way to go with the new 1190 Adv. Sausagestyle and grease ;-)
regards
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 12-20-2013, 07:39 AM   #33
SpeedyR
SE in the SE
Oddometer: 870
you can remove the CPR filter with the tank in place, no problem.
filter socks are available for the sausage filter, they are just the thin fabric types (CPR sells them on their site) instead of the full foam pre filter that's available for the taller ADV filter..
SpeedyR is offline   Reply With Quote
Old 12-20-2013, 08:31 AM   #34
buzybraza
buzybraza's Avatar
Oddometer: 377
Originally Posted by ICERIDER View Post
That sounds like a plan! I'm surprised at how much room there is above the filter. How much is taken off the rear trumpet to fit the sausage filter?
For the guys running the normal non-sausage filter on the SE, do you have to take much off the seat base to fit? And can you run the foam sock as opposed to the thin skin?
Last question.. do you need Flexjets or are you able to reach under a Safari?
Thanks.
1-As for trimming trumpets for the sausage style ITG, look at my link below. If I was doing it again I would cut both the same, straight cut, about one inch to one and a half inches tall measured from carb mouth to keep both trumpets the same instead of the "2 different sculptures" I created (or destroyed!).
2-Non sausage style for me was not an option at all. No way I am going to cut the seat base.
3-Flexjets are a must in my opinion, as are the Factory Pro needles.
http://advrider.com/forums/showthread.php?t=859772
buzybraza screwed with this post 12-21-2013 at 11:30 AM Reason: pictures
buzybraza is offline   Reply With Quote
Old 12-20-2013, 08:37 AM   #35
buzybraza
buzybraza's Avatar
Oddometer: 377
Originally Posted by JOKER650 View Post
This style of filter is the easiest to clean.
Hold it up, run the cleaning soloution from the clean side through to the dirt side and it's CLEAN.
You can do it without even getting your hands dirty.
Foam filters SUCK TO CLEAN.
Your results may differ
in 45,000k of riding, much of it (if not most of it) was in the dirt. Never any traces of dust in the carbs or anywhere on the filtered side of the system
I agree in terms of just cleaning K&N style filters against foam, but how about getting to the filter in the first place? And then putting everything back together? Specifically in the case of the 950/990 KTMs I have done it both ways and I prefer to deal with the ITG foam than with the 950/990 airbox/tank.....
Old 12-20-2013, 04:25 PM   #36
ICERIDER
Adventure Rider
ICERIDER's Avatar
Oddometer: 454
Thanks for all that. I think that's the first time I've actually seen the trumpets cut after all the talk about it.
950 SE
WR250R
950 ADV
ICERIDER is offline   Reply With Quote
Old 12-20-2013, 10:16 PM   #37
tour OP
tour's Avatar
Oddometer: 35
guys this has been a very lekker learning curve for me. so thank you for all of the information on the different products so far. my thinking is this... I will be going for the ROTTWEILER CPR air filter...
why ? well so far I had a look at both of these 2 brands Rottweiler and SW7. Now I am a tight bastard and our currency does not really stand too tall against the US Dollar... but yet I have decided that on the longrun it will be a better investment for the life of my love "Fluffy" 950 SE . She only gets the best from me and sometimes the best might be more expensive but better filtration is more important than price.
I have had 2 of my very good friends (mechanical engineer techy type guys) also look into these two filters and we all ended up with the Rottweiler filter as the best bet. So early in the new year I will get mine.
Now this is just my decision and if any one has more to contribute please feel free as this thread can still add a lot to our lives and those of our beloved LC 8 engines. Honestly the more info we can add here the better for more possible clients like myself that want to go this route.
I will still be reading up as much as I possibly can on this but for the next two days I will be out riding with friends.
One mate will be tagging along with a little Yamaha 125 that he wants to do Southern Africa with.
hope to see some more action here
Old 12-20-2013, 10:50 PM   #38
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
Tour,
Taking my police hat off, buy whichever product you feel best solves your needs. Do your research, ask your questions. But unfortunately, this has been an unusually volatile subject which unfortunately resolves itself in moderator action, too many times and waaaay to often. Caveat Emptor.
Police hat back on.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Times are GMT -7.   It's 05:01 AM.
