Old 11-25-2013, 09:47 PM   #91
mint julep
mint julep's Avatar
Oddometer: 185
Hi Scott (Antigravity), great products.
I'm just wondering if any SAE connector plug accessory, out from your Micro Start unit?
I'd like to connect by the SAE connectors to my heated gear (Powerlet jacket liner & glove liners) while off the bike.
Is this possible? Use the XP-1 or XP-3 units as portable battery power to run heated gear continuously while I'm disconnected from the bike.
I have SAE connector on the end of my Powerlet harness connections.
Thanks.
Dave
2012 Triumph Tiger 800 XC
mint julep is offline   Reply With Quote
Old 12-12-2013, 01:02 AM   #92
inyang
5secs away
inyang's Avatar
Oddometer: 404
I picked up 2 of the MicroStart XP3, the vanilla version.
Charge up, it came almost fully charged, then went looking for test dummies.
GSX-R 1000 at a friends shop with a dodgy battery, disconnect battery, start at first attempt.
Hmmm, what next. Aha, an F-150 parked nearby, thought about all the electronic gizmos that need backup power and moved on.
Then this...
From 2013-10-21
Battery terminal off, clamp on the XP3, start....
Crank, crank, crankkkkkkk, vroom vroooooooom....
Leads were very hot
Battery pack hot, still able to hold on though.
I like the way the clamps are protected by plastic, you do not want a short circuit on a Li-Ion battery or whatever new wave tech the batteries are made of.
The motorcycle shop is ordering 5 units.
'11 - 690R
inyang is offline   Reply With Quote
Old 12-12-2013, 07:28 AM   #93
mefly2
mefly2's Avatar
Oddometer: 1,211
Very nice!
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 12-17-2013, 04:42 PM   #94
Burro X
no static at all
Burro X's Avatar
Oddometer: 658
Got mine today - jumped two cars at work already , works great !
Adventures: http://buddywalton.smugmug.com/
Burro X is offline   Reply With Quote
Old 12-18-2013, 06:20 AM   #95
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,000
Burno X started two cars yesterday with his so that sold me on it.
Order placed!
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 12-19-2013, 12:05 PM   #96
Michael
Michael's Avatar
Oddometer: 213
This thang works! I disconnected the battery cables on my F150 6.2 liter. Hooked up the microstart and started it 4 times one right after the other, on a cold engine. I bought 3 - one for me, two for presents!
Michael is offline   Reply With Quote
Old 12-22-2013, 09:22 AM   #97
mrphotoman
mrphotoman's Avatar
Oddometer: 1,207
what is the capacity/mah of the xp1?
is the introductory price of $129 still good?
mrphotoman is offline   Reply With Quote
Old 12-23-2013, 06:48 AM   #98
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,000
First test
I'm not bashing this product, but here's the result of my first testing of the product.
I bought it on line using the ADV discount code " adventure" for $129.
Received it in 4 days ( Saturday ).
Charged phone, no problem.
Ran laptop, no problem.
I took it to work Monday knowing I had an acid test waiting. We have a JLG man lift with an industrial V4 gas engine. It is cold here, about 38 DF, the machine has a drained battery, and had been sitting that way for a few weeks.
Hooked up the cables, then plugged in a fully charger Micro Start. The machine turned over no problem but would not start. On the sixth crank the positive cable solder joint melted. Afterwards the unit showed three solid lights indicating the minimum cranking charge still remained and I think also that we did not over load the Micro-start battery unit during our acid test. I'll contact the seller for warranty of course.
Regards
Fritzcoinc
Old 12-24-2013, 09:21 AM   #99
Antigravity OP
Oddometer: 157
Hey Fritz,
We will warranty it no problem... it reacted exactly as it should. The clamps melted because the load was to high for the unit. We have not testing on industrial motors, or other things outside of our industry.
So anyone interested in purchasing a MICRO-START... It works as intended absolutely and we will offer your money back if it doesn't.... BUT, it is intended for stock Auto and Trucks up to 400 Cubic inches, or Motorcycles and Powersports Vehicles. Outside of those parameters we don't suggest its use. We want happy and stoked customers, we made a pocket size jump starter and personal power supply but it is just that... a pocket size device with incredible power, but does have limitations. We will soon have larger beefier units designed for Diesels and more industrial applications, but a pocket size device really can't do somethings.... Please use it only as intended and you will have great results. Outside of that is a grey area and we don't want to oversell the product and get bad reviews.
We've had some really cool results and emails of people starting V-10s and other stuff, but honestly it is not intended for that use. Wait for our larger ones. But if you own a bike or average car or truck you will be blown away.
http://antigravitybatteries.com
The smallest, lightest and most POWERFUL batteries
Antigravity is offline   Reply With Quote
Old 12-24-2013, 09:30 AM   #100
Antigravity OP
Oddometer: 157
Hey all,
I had a chance to read a couple posts asking questions about the unit here... Sorry I have not responded for what appears to be pages, but often I don't get any notification that there is a post, and I don't check often. So please feel free to write to us at info@antigravitybatteries.com and we will respond very quickly.
Also we do have the Harness Kit now that does allow for you to connect a harness to your bike or car and then you can just plug in the micro-start to this harness instead of having to take off your seat and use the clamps to jump start. Additionally this harness come with a reducer tip that you can plug into it so you can still charge your vehicles battery using the standard SAE type plug. Basically our harness kit will replace your battery tender type harness with much thicker cable capable of handling the massive amps required to jump start the vehicle.
In January and February we will have some bigger models coming out and additionally a very small one about as big as a Galaxy Cell phone that will easily do you motorcycles and up to V6 cars...but it will be so thin you can stow it anywhere.
Old 12-24-2013, 11:27 AM   #101
steve_k
steve_k's Avatar
Oddometer: 1,062
Argh! So many needs and wants.... And this kind of falls in to both categories!
steve_k is offline   Reply With Quote
Old 12-24-2013, 01:43 PM   #102
garandman
Oddometer: 6,163
Originally Posted by Antigravity View Post
Hey all,
where.
Unsubscribe from thread, then re subscribe using "Immediate notification by email."
garandman is offline   Reply With Quote
Old 12-29-2013, 08:19 PM   #103
revtech100
Oddometer: 195
How does it work in a a6.4l f450.
The bike was the cheap part. The divorce it caused cost a little more.
2011 R1200GS Triple Black, 2003 Harley Ultra Classic
2000 Custom Chopper, 2011 KLR650,
2011 Kawasaki 110, 2013 Ural Gear Up
revtech100 is offline   Reply With Quote
Old 01-02-2014, 12:53 PM   #104
mnsty
mnsty's Avatar
Oddometer: 183
So, the Porsche 962 had a dead battery today. Perfect chance to try the Micro Start out. worked great. leads a little warm but started it and amazed the Brit watching me do it.
Currently,
76 R90S Turbo
77 R100RS
83 RS/GS
85 K100RS
90 BMW K1
91 900IE Lucky Exp
00 VOR 503SM
04 KTM 950 GO!!!!!
05 TM 530 Black Dream
= Too much stuff. When will I learn??
mnsty is offline   Reply With Quote
Old 01-02-2014, 01:50 PM   #105
mefly2
mefly2's Avatar
Oddometer: 1,211
Was that a dead battery or just a low battery?
Times are GMT -7.   It's 09:23 AM.
