Old 12-25-2013, 12:52 PM   #19021
ODSC1
ODSC1's Avatar
Oddometer: 193
Originally Posted by fabrizio View Post
https://vimeo.com/82595547
Here is a video of a bike being ridden around Detroit's historic Packard Plant by a non professional rider on a non-closed course...
Special thanks to CW at Cycle Wizard in Frankenmuth, MI. This bike is running like a top thanks to him. Highly recommended expertise, parts, and personality.
I've walked through there 2 or 3 times but never thought of taking a bike through. Neat idea and cool video.
ODSC1 is offline   Reply With Quote
Old 12-25-2013, 07:56 PM   #19022
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,288
Making progress figuring out my coolant leak issues.
I got my $35 motorcycle coolant pressure testing kit. What a great tool for just a few bucks. I was able to do a static pressure test up to 25psi (much higher than operating pressure) and find a few suspect hoses that were weeping. I also was able to do a dynamic test (engine running) and confirm that cylinder pressure was not finding it's way into the coolant (ie blown head gasket). Plus it comes with an adapter to make sure the radiator cap is opening at the correct pressure. Definitely worth the $35!
Unfortunately, I still had some coolant leaks after letting the bike idle for 5 minutes, though it wasn't as bad. It appears I need a new waterpump seal, as coolant seems to be coming out of the weep hole.
Can anyone recommend a waterpump rebuild kit?
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 12-25-2013, 07:59 PM   #19023
mitchn06
mitchn06's Avatar
Oddometer: 553
I would probably just get oem parts. Can you please share a link of the vac kit?
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 is offline   Reply With Quote
Old 12-25-2013, 08:02 PM   #19024
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,288
(click the picture) There are tons of resellers for these Mityvac kits, you can find them on Amazon too. The kit comes with two adapters. The one screws onto your radiator in place of the radiator cap to pressurize the bike's coolant system. The other allows you to screw the radiator cap onto it to pressure test the cap.
jwalters screwed with this post 12-25-2013 at 08:17 PM
Old 12-25-2013, 08:29 PM   #19025
Kiko
Kiko's Avatar
Oddometer: 1,753
My water pump seal started leaking a few months ago. I had no access to a new seal here in Mexico so we removed the water pump and seal, cleaned the seal and re-installed it. Has not leaked since. May want to try that if you are waiting for parts.
Kiko is offline   Reply With Quote
Old 12-25-2013, 08:34 PM   #19026
jwalters
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,288
Thanks! It's a long winter here, so I'll try cleaning the seal before I order a new one. I haven't tore it apart yet, but it looks like it's part #2 that fails and allows coolant past? They want $46 bucks for that bugger! More reason to try and refurbish the old seal.
Old 12-25-2013, 11:53 PM   #19027
Bench Racer
Oddometer: 82
Originally Posted by oldxr View Post
My guess is the problem is you are pulling the throttle more to get past the lean spot.
Maybe I richen my needle. Clip on middle position. But I think it will be too rich and have a bog. Trial and error. Test Test Test. Thanks.
Bench Racer is offline   Reply With Quote
Old 12-26-2013, 08:58 AM   #19028
crypto666
Oddometer: 1,257
Originally Posted by Cpt. Ron View Post
Yes, I am. Since I'm running a stiffer spring (11.5kg?), I needed to add some additional damping to the rebound. Works pretty damn good (along with the front).
I assume you mean you added rebound damping to Borynack et al's stack, not added to the factory stack. Because that factory rebound stack is retarded; 30 0.1 shims don't allow for a very plush setup. That is why you can just about lock the shock up by turning the adjustment all the way.
crypto666 is offline   Reply With Quote
Old 12-26-2013, 09:09 AM   #19029
crypto666
Oddometer: 1,257
Originally Posted by cognugget View Post
Are there special tools for the shock like there are fit the fork?
Sent from my SCH-I545 using Tapatalk
Nope. A flat blade screwdriver will open it up and a 12mm socket will take the valve apart. There are some special things that need to be done, such as filing off the flared threads on the shaft, and bleeding it, and learning to avoid an oil shower. But once you have done one, they are all pretty much the same.
Well hold on, there is one special item, nitrogen. If you don't have a shop near by, you will have to get a bottle, reg, and the aircraft strut filling valve thingy.
There are lots of videos and how to pages out there, check a few out. People have different ideas and you can find what works the best for you. For example, I find bleeding through the compression adjuster worked best for me.
This is a good start here: http://www.borynack.com/xr650r/KYBShowaShockService.htm
Old 12-26-2013, 10:39 AM   #19030
dohcfox
meh
dohcfox's Avatar
Oddometer: 144
Question for those of you that have had the head off of their XRRs. What kind of sealant do you put in between the head and the piece that holds the rocker shafts and cam shaft? Is it possible to re-use the large rubber plug that sits on the outside of the head?
Thanks in advance!
Ser decente no cuesta un culo y queda uno putamente bien!
dohcfox is offline   Reply With Quote
Old 12-26-2013, 10:43 AM   #19031
mitchn06
mitchn06's Avatar
Oddometer: 553
I have used permatex motoseal 1.
Old 12-26-2013, 10:53 AM   #19032
dohcfox
meh
dohcfox's Avatar
Oddometer: 144
Thank you!
Old 12-26-2013, 11:02 AM   #19033
Jayrod1318
Poster
Jayrod1318's Avatar
Oddometer: 1,618
Glad to see you making headway, What did you end up doing with the hoses/clamps?
That clamp above looks good, NOT overtightened.
Jayrod1318 is offline   Reply With Quote
Old 12-26-2013, 03:18 PM   #19034
crypto666
Oddometer: 1,257
Thanks in advance!
Three Bond case sealents are what have been recommended to me. Permatex is probably similar.
I reused my rubber plug, but I also gave it a layer of case sealent. No issues.
Old 12-26-2013, 05:13 PM   #19035
OR Trail
looks for unlocked gates
OR Trail's Avatar
Oddometer: 355
I used Honda high temp gasket sealer - Hondabond HT. I re-used the rubber plug and also put a light coat of sealant on it.
Thanks in advance!
OR Trail is offline   Reply With Quote
Times are GMT -7.   It's 12:39 AM.
