Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 12-23-2013, 06:18 PM   #46
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Ahh. Yeah, it's a larger file, in terms of pixels. If your PDF maps app isn't set to import hires by default, I'd recommend it. Or just go into the info for that one map and pull in the hires version. It is pretty pixelated, though, even when you import it as a hi-res file. That might help.
I will post an even higher resolution version, that you can try. It'll be clearer, but the file size is massive. It might actually be more pixelated, once the app does its thing...
Spotwalla location ID: LUC
lucknau is offline   Reply With Quote
Old 12-23-2013, 08:49 PM   #47
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Originally Posted by rootsy View Post
How about Huckleberry Mountain OHV when and if you have the urge?
I just posted the Huckleberry Flats OHV map to the links on the first post.
Cheers!
Old 12-23-2013, 10:39 PM   #48
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Android users will want to download the hi-res version of the Cle Elum West map. For some reason the map size is just great enough that PDF Maps wrecks the resolution during the import. I don't know why, but it doesn't happen on the iPhone. Anyway, the file size is massive, but (I hear) it looks pretty good on the phone.
Thanks, ScottPDX, for helping troubleshoot these. I may owe you a beer or three.
Old 12-24-2013, 12:57 PM   #49
Night Crawler
Night Crawler's Avatar
Oddometer: 101
Do these just show you where you are on the trail? Very cool, just wondering if there are any other features.
Night Crawler is offline   Reply With Quote
Old 12-24-2013, 01:29 PM   #50
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
They do. You can also record tracks, set waypoints, and export or import recorded tracks to or from other programs.
Old 12-25-2013, 12:03 PM   #51
Night Crawler
Oddometer: 101
So I have been playing with this and I am excited to try it out on the trails. If I create a track I want to follow using waypoints will it navigate the route? Does the screen pan around on its own to follow you? Thanks for the help, I am a gps newbie.
Old 12-25-2013, 12:24 PM   #52
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Geospatial/Georeferenced PDFs
So If I create a track I want to follow using waypoints will it navigate the route? Does the screen pan around on its own to follow you?
You can import a path into the map (it likes the KML file format). It doesn't do turn-by-turn style navigation, but it does work like google maps, by putting you on the map as a blue dot. It will pan around, and it will follow you on the map. I usually lock the screen orientation on my phone, because the G force causes the screen to flip all around when cornering.
lucknau screwed with this post 12-27-2013 at 06:49 PM
Old 12-30-2013, 12:25 AM   #53
rootsy
rootsy's Avatar
Oddometer: 126
Thumb
Thank you for posting Huckleberry and Shotgun maps! I appreciate your time and effort. Cheers!
rootsy is offline   Reply With Quote
Old 02-23-2014, 03:55 PM   #54
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,933
Thanks for the hard work and sharing this app.
I'm looking for a map of the Gold Creek / Green Mountain area near Bremerton.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 02-24-2014, 12:37 AM   #55
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Sure thing. No prob. :)
I found a good PDF of the area, and will try to post a georeferenced version in the next few days.
Old 02-24-2014, 08:03 AM   #56
doggitter
Oddometer: 2,088
Do the files you're working with here work in Viewranger also?
So many rides, so little time.
Loren, somewhere on a DR350SE
doggitter screwed with this post 02-24-2014 at 06:27 PM
doggitter is offline   Reply With Quote
Old 02-24-2014, 11:34 PM   #57
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
I haven't use Viewranger but it looks like a tile map program, like Galileo, which pulls from the same databases (openstreetmap, et al). If it can open PDFs, then yes. If it can't, then no.
Old 02-25-2014, 02:19 PM   #58
SuperD!
SuperD!'s Avatar
Oddometer: 261
I gotta say that using these maps in OHV areas is pretty damn cool & WAY more useful than the GPS...though ScottPDX and I still can't agree on which road goes where.
SuperD! is offline   Reply With Quote
Old 02-25-2014, 07:02 PM   #59
doggitter
Oddometer: 2,088
I'll have to say that's a "YES" then.
Types of Map
ViewRanger supports two types of map:
  • Online maps such as those from Open Street and Cycle Map. These maps are downloaded automatically as and when they are needed or can be pre-cached. They are cached on the phone, so if you preview them before going out you can use them in an area with no mobile signal.
  • Unlimited maps - highly detailed online topo maps for USA and Canada, that can be easily stored for offline usage on your mobile devices. These maps contain more detail and come with the USA edition but are charged for on other editions.
  • Premium maps more detailed maps, typically from national mapping agencies such as Ordnance Survey, IGN, or BKG. These maps contain more detail but are charged for. These maps are stored on the phone so can be used when away from the mobile network."
Old 02-27-2014, 10:23 PM   #60
lucknau OP
Greenhorn
lucknau's Avatar
Oddometer: 209
Let us know, one way or the other, if you get a chance to try it out.
Times are GMT -7.   It's 04:43 PM.
