Old 12-21-2013, 07:50 AM   #3781
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Originally Posted by GreatWhiteNorth View Post
Definitely interested. I've got a KLR650 headlight mount handy, just compared measurements, and it looks like this would fit in between the headlight mount tabs quite nicely. Do you think it would function OK as a headlight assembly?
I think the Flood pattern with the clipped beam would be great. You would need to combine it with one of our LED controllers. The controller will give you an adjsutable low beam, full power high beam. We can make it plug n play to your stock headlight connector.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 12-21-2013, 01:48 PM   #3782
frogy
frogy's Avatar
Oddometer: 874
Originally Posted by sanjoh View Post
Not at all. If you have any questions, post em up.
This light has a low profile, which looks to be a good fit for under the front fairing for the Super Tenere'.
4 Cree XM-L U2 LEDs
Available in Spot (15 deg) or Flood (45 deg)
4000 lumens
aluminum housing
o-ring sealed housing
one meter wire lead
includes stainless steel mount and mounting hardware
PMMA shatter proof lens
water and dust proof, IP67 rated.
Hmmmm...interesting. I have been thinking of installing some narrow beam LEDs under the truck independently wired. We travel East 800+ miles every year after Xmas and have been caught in some white-outs. Headlights and factory driving lights just blind me. Install one of these real low so it just lights up the road with headlights off and parking lights on during white-out just might do the trick. Maybe put your wireless rheostat on the dash for on coming traffic
2002 R1150RT, 1985 Naked K100RT
frogy is offline   Reply With Quote
Old 12-23-2013, 11:15 PM   #3783
Spayn
Oddometer: 140
Anyone has installed F11 or M15 to the KTM 1190 Adventure?
Spayn is offline   Reply With Quote
Old 12-24-2013, 03:33 PM   #3784
GreatWhiteNorth
GreatWhiteNorth's Avatar
Oddometer: 2,547
Got pkg in the mail today!
My daughter bought me an M60 for Xmas, which arrived today. Thnx for the super quick shipping, and wishing you a Merry Xmas. Nice looking light!
GreatWhiteNorth is offline   Reply With Quote
Old 12-26-2013, 06:05 AM   #3785
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
Merry Christmas
Old 12-29-2013, 09:25 PM   #3786
red_rock_beetle
Oddometer: 10
That F40 is a good looking rig, why must you tempt me? any info on wattage yet? and I have been having battery issues since I installed the M60s and controller I got a couple months ago, Is there any amp draw from the controller when it's off? or is my battery on its way out? either way, I love these bright-ass LED man, good job!
red_rock_beetle is offline   Reply With Quote
Old 12-30-2013, 10:17 AM   #3787
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
The controllers do pull a small amount (20ma) of power even if off. We recommend using switched power (on/off with bike).
If you aren't using switched power you will need a trickle charger or just ride more
Old 12-31-2013, 08:43 PM   #3788
Rev
Asshole
Rev's Avatar
Oddometer: 279
Where is it better to mount aux lights? Higher or lower?
I have an 08 KLR and I have choices of mounts to either go on the fairing (pointing where the headlight goes) or the forks slightly above the fenders (pointing where the wheel goes)
overall, I see pros & cons both ways. Up high, less likely to get smashed in a fall or hit by brush in the woods, but they arent "dynamic" and moving with the bike as I ride. I *feel* that the higher they are mounted, the better chance that ill be seen by oncoming cars and be able to throw the light further.
Down low, about the only pro I can see is the ability to move with the forks wherever im steering. I feel the throw could be slightly put at a disadvantage and at more risk for rock/brush damage.
Insight?
Give a man fire, and he's warm for a night.
Set a man on fire, and he's warm for the rest of his life.
Rev is offline   Reply With Quote
Old 12-31-2013, 09:54 PM   #3789
sdd04
Location: The Ozarks....SW MO, NW AR-great place to play!
Oddometer: 875
personal opinion is to mount high.
sdd04 is online now   Reply With Quote
Old 01-01-2014, 02:25 PM   #3790
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,554
Does that include the Rotary LED Dimmer with High Beam Bypass? That may explain the degrade in battery performance after I installed the dimmer and the M30's on the GSA. Or the battery's just wearing out.
Posting all the bikes you have or have owned in this spot is stupid.
squiffynimrod is online now   Reply With Quote
Old 01-01-2014, 03:39 PM   #3791
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 620
Those pitch black dips in the road get shallower the higher up you mount the spots.
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 01-02-2014, 11:23 AM   #3792
inyang
5secs away
inyang's Avatar
Oddometer: 422
"inmate' discount still on?
At your site and the 'inmate' discount code is not accepted.
No more discount or different code?
'11 - 690R
inyang is offline   Reply With Quote
Old 01-02-2014, 02:53 PM   #3793
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,369
fixed, "inmate" good for 10% off
Old 01-02-2014, 05:46 PM   #3794
hoadie72
Oddometer: 74
I missed that there's an inmate discount when I placed my order. I'll definitely remember next time!
I installed a pair of M60s + dimmer on my F650GS over the weekend and while I've tried the lights out twice at night, I'm impressed both with the increased visibility other road users have of me, and how much brighter these lights are at night when on high. It's difficult to say exactly, but they seem to be twice as bright as the puny OEM high beam, and that's with the M60s still pointing to the ground a bit.
Anyway, I have a question - with the dimmer set to anything other than the lowest setting, off, or full, one of my lights makes an audible high pitched humming noise. The dimmer I bought is the "Rotary LED Dimmer with High Beam Bypass". Is this to be expected?
hoadie72 is offline   Reply With Quote
Old 01-02-2014, 06:00 PM   #3795
Jnich77
Jnich77's Avatar
Oddometer: 819
Two model 30's and a model 60 + my high beam with a OEM spec bulb in the middle of nowhere Tx.
Jnich77 is offline   Reply With Quote
Times are GMT -7.   It's 05:30 PM.
