Old 01-01-2014, 03:58 PM   #1
Pops of the desert OP
Oddometer: 82
CJs Peg Extensions
This may seem like a stupid question but, how do you get the spring back in the foot peg. Have tried everything I can think of and chased it across the shop several dozen times. Help.
Pops of the desert is offline   Reply With Quote
Old 01-01-2014, 04:06 PM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,322
There are tricks with clamping in a wise or similar while you have a steel wire you can use to force it down until its in place then just cut and remove wire.
Feels like handling a grenade, these are strong little springs.
Screwdriver was possible to use last time but was a struggle, got a thinner screwdriver all the way in place from the underside then while wiggling that out getting pin to take its place, not easy but can be done.
Please use safety glasses these things can really fly!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 01-01-2014, 04:21 PM   #3
tedmarshall
tedmarshall's Avatar
Oddometer: 547
Prolly no help now, but there is a tool
KTM sells a spring puller just for this purpose. I have suffered like you. I bought one of these it's kinda like a longshoreman's hook but on a small scale. A vice grip might work, a little one.
Ted
tedmarshall is offline   Reply With Quote
Old 01-01-2014, 04:22 PM   #4
dirtybikefrank
Beast wrestler
dirtybikefrank's Avatar
Oddometer: 443
Thought I was the only one who had that issue before.
After about putting an eye out I used a pair of needle nose vice grips and a small zip tie.
Cheers
dirtybikefrank is offline   Reply With Quote
Old 01-01-2014, 04:30 PM   #5
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,039
I believe Slavens Racing website has a video of installing the spring. When you watch it, you'll go - yeah! Google on youtube slavens peg springs, I 'bet you';; find it quick.
Here it is:
http://www.youtube.com/watch?v=TgEBRGSo7ZU
Happy New Year!
unaweep is online now   Reply With Quote
Old 01-01-2014, 06:51 PM   #6
kanur
cu new er
kanur's Avatar
Oddometer: 740
Welcome to the world of KTM
Just cause I don't run my mouth don't mean I got nuth'n to say. Mike Cooley DBT
kanur is offline   Reply With Quote
Old 01-01-2014, 07:42 PM   #7
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
Put the spring in a vice or pliers, zip-tye the spring while compressed, install the peg, pin and spring, cut the zip-tye. Works every time.
Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Old 01-01-2014, 08:02 PM   #8
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
KTM doesn't sell a spring puller(?) for this task they sell a factory tool (OEM # 58429083000) for installing the footpeg springs- from the 50cc's all the way to the big boys... (it used to be 990s now it is 1190s)
Take your time, if you don't have the tool. Compress the springs as you insert them down into their home- have the pivot pin in the frame gusset ready to tap it through with a small hammer once you get it down in there.
Yes, these are strong springs...
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 01-01-2014, 10:42 PM   #9
Oddometer: 82
Just watched the Slavens video, will try it in the morning.
THANKS
Old 01-02-2014, 04:50 PM   #10
Oddometer: 82
The Slavens video did the trick. Winter maintenance is done.
Old 01-02-2014, 05:38 PM   #11
unaweep
unaweep's Avatar
Oddometer: 20,039
It sure helped me. I'm lucky I still have two eyes.
Times are GMT -7.   It's 12:45 PM.
