Old 01-02-2014, 09:48 PM   #1
MymoJoe OP
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,923
KTM950se sub frame bolt and nut
Hi I have lost this bolt and insert nut from my KTM950se. I can't find the nut on a parts fishe anywhere...
does anyone know the part number or where I can located one?
Joe
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 01-02-2014, 10:49 PM   #2
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,740
All 4 sub frame bolts are the same part number. 60003004027.
The nut is a different story. KTM doesn't list a part number. On the top bolts, aren't the bolts thraded into the frame? And on the bottom aren't they threaded into the sub-frame?
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 01-03-2014, 12:50 AM   #3
Sumi
Sumi's Avatar
Oddometer: 1,796
On the ADV there are..
Old 01-03-2014, 05:00 AM   #4
DirtyADV
DirtyADV's Avatar
Oddometer: 2,245
Its a normal nut pressed into the subframe. For lower mounts that is.
And I might be wrong but think that the bolts holding the subframe are M10x1,25, fine thread that is.
But have a sidestand relocator that uses that place and needed to change the nut since the bolt was a normal thread M10x1,5.
EDIT: had to look up and no nut listed for the Adventure either, and thread pitch is correct so a M10x1,25 nut should do the trick.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 01-15-2014, 10:00 PM   #5
MymoJoe OP
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,923
dunno that is why I ask....
the nut appears to be some sort of insert nut that looks pressed in?
So what is the solution?
I tried to jam a nut in place with the OEM recessed allen head bolt.. first ride out it fell out (yeah it was loctited...)
now revisited it, there seems to need a bush to fill the frame to reduce the amount of slop...
I still have no idea what type of nut to use.. I tried liquid metal to "glue" a nut in place that I tapered with a grinder.. and it fell out...... I can't be the first to have this problem..
Simpson Trip 2008
Old 01-16-2014, 03:24 AM   #6
johnno950
Oddometer: 1,049
Have a look at aerobolt australia pty ltd,they have threaded inserts,would it if applicable be of any use to use one of their inserts in the damaged area with a longer bolt/hardened washer?
johnno950 is offline   Reply With Quote
Old 01-17-2014, 01:56 PM   #7
MymoJoe OP
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,923
thanks
Thanks Johnno. I gave them a call. What a fantastic business with great service. They are sending me the correct size inserts...
I will rip the subframe off today.
Joe
Simpson Trip 2008
Old 01-17-2014, 05:31 PM   #8
wcohl
Oddometer: 332
Joe,
If the subframe is like the subframe on the smaller KTM's (<530), there is also a metal plug to reinforce the aluminum tube. I've read of some repairs where a new metal plug was fabbed up without the threaded insert, and only the metal plug was threaded.
wcohl is offline   Reply With Quote
Times are GMT -7.   It's 08:12 AM.
