Old 01-14-2014, 12:54 AM   #1
Ocky OP
Oddometer: 50
What do you do when you hit gravel covered asphalt?
Something that has always been a problem for me is riding over gravel covered asphalt. Where I live doesn't snow a lot but a couple weeks ago it did and there is still significant gravel covering less traveled roads. I have had a couple unfortunate experiences going through a turn and having my rear tire slip(this is after I have already slowed down and am going 20mph or less).
Apparently increasing the traction of 4 wheeled vehicles for a couple days is an Ok trade off for making the roads hazardous for 2 wheeled vehicles for a month or more.
Ocky is offline   Reply With Quote
Old 01-14-2014, 01:37 AM   #2
Jacl-Kampuchea
Booze Merchant
Jacl-Kampuchea's Avatar
Oddometer: 721
I keep going, I may give it more gas and enjoy the bike's drift.
Jacl-Kampuchea is offline   Reply With Quote
Old 01-14-2014, 01:43 AM   #3
EltonAvenue
Oddometer: 544
Loose gravel & tight sphincters go together like beer & brats, or beer & nuts, or even beer & more beer!
You can either continue to be afraid of it or get used to it by "testing" just how far you can go with your slides, better still, join a local off road club,
OR, sell the bike & buy a 4WD!!!!
EltonAvenue is offline   Reply With Quote
Old 01-14-2014, 02:46 AM   #4
Aussijussi
Oddometer: 1,147
Cross your fingers?
Aussijussi is offline   Reply With Quote
Old 01-14-2014, 02:51 AM   #5
filmfan
Oddometer: 752
Be aware that you are likely to find gravel and sand and ride accordingly.
We get plenty of snow here, and by the time spring rolls around you can't tell that some roads are actually paved, for all the gravel and sand on them. Gravel on pavement is like riding on ball bearings.
Staying away from the inside on turns helps, as what's left seems to stay the longest there.
Based on my experience on the bicycle in these conditions, a tire with a deep open tread helps a lot. Though on the moto I run regular pavement tires, and I just ride with extreme caution for the first couple of months.
filmfan is online now   Reply With Quote
Old 01-14-2014, 02:52 AM   #6
gsweave
Yinz, blinkers are on.
Oddometer: 11,771
Stay alert, stay loose
1 Peter 2:16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 01-14-2014, 03:08 AM   #7
ohgood
ohgood's Avatar
Oddometer: 2,903
what do you do when you hit gravel covered asphalt?
lots of things !!!
sometimes its a hoot to spin up the back
slide the rear
feel the front drift back to traction
sometimes I fall down.
no big deal, the bike knows what pavement, dirt, trees, grass, mud, gravel, and lots of other surfaces look like from many different angles. hell it doesn't even close its eyes or tense up anymore.
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 01-14-2014, 03:48 AM   #8
Skyshadow
Skyshadow's Avatar
Oddometer: 637
Suck it up and get used to it, learn where it occurs and anticipate it. Some bikes handle better than others on the stuff. Just don't go in with too much lean or too hot. With climate change you are going to be dealing with a lot more than before.
Skyshadow is offline   Reply With Quote
Old 01-14-2014, 04:17 AM   #9
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,655
The head of our town's highway department (in N.H. their title is "Road Agent") explains that the possibility of a traction related accident has his department laying down LOTS of sand and salt. They do sweep the roads once it looks like winter is finally over.
But on a MC especially with a heavier bike- IF POSSIBLE- I try to stand it up to very near vertical and let up partially, if not fully, on the brakes and glide through the crap....providing the gravel section is short and I can still get through the corner after that.
Barring that, some lean angle might be OK and the rear might hang out a bit but stay off that front brake as much as possible until the gravel/sand ends. Front end lockup is NOT your friend.
'92 K100RS
'12 DRZ400
sugarhillctd on the world-wide K11OG forum
I got my MotoMatters calendar, did you?
DC2wheels is offline   Reply With Quote
Old 01-14-2014, 04:19 AM   #10
tvpierce
tvpierce's Avatar
Oddometer: 385
Lay 'er down!
(Somebody had to say it!)
The laws of the road are superseded by the laws of physics.
"But I had the right of way!" makes a pretty crappy epitaph.
tvpierce is offline   Reply With Quote
Old 01-14-2014, 04:33 AM   #11
klaviator
klaviator's Avatar
Oddometer: 6,486
Originally Posted by tvpierce View Post
Lay 'er down!
Ya beat me too it.
If you don't lay'er down, you might crash
I ride, Therefore I Am.
klaviator is offline   Reply With Quote
Old 01-14-2014, 04:57 AM   #12
manfromthestix
Lost in Space
manfromthestix's Avatar
Oddometer: 2,245
This man knows what he's talking about. The thing that will knock you down is lean angle - so long as the bike is generally upright you can slide or skid without any issues, but get the center of gravity off-line and you may be asking more of the tires than they can provide in that situation. Stay within the bounds of traction and you'll be fine. As others have stated, once you get familiar with it you can have some fun with spins, power slides, drifts, etc. but I save that stuff for my little dirt bike and not the ($$$) Big Pig.
Please export this excellent behavior to Virginia! The VDOT sands & gravels the roads here to the point the look like dirt roads by the end of the Winter and then that's it. Yer on yer own until the rain or traffic washes or wears it off. We've had on again - off again winter here so they've put down huge amounts of sand everywhere, to the point that riding a bicycle will shake your fillings out of your teeth. I saw where a car flew off the road on the grit just last weekend; it's a sharp turn, but he would have been fine except for all the sand. The deer like the salt, too, they come down out of the woods to lick it up from the roadsides.
As if sanding during Winter weren't bad enough, last summer the VDOT came around and chip-sealed the road near our house. I was DISMAYED . It was a crappy job to begin with and has haunted my bicycling and motorcycling since:
The windrows got so deep I took a flat blade shovel and wheelbarrow out and collected a bunch of gravel to patch my driveway , thanks VDOT. It's been 8 months since they did this and it still SUCKS, but it is what it is and I just ride accordingly.
Take care, be safe, end enjoy the ride! As a geologist I love it when the leaves are off and the snow/ice highlights the local structure:
Happy New Year!
Doug
"If it doesn't blow smoke and make noise, it isn't a sport!" - radio ad for shop in Bozeman, MT
manfromthestix is offline   Reply With Quote
Old 01-14-2014, 05:11 AM   #13
tkent02
Oddometer: 2,518
Don't look at the gravel. Look at a clean line between the gravel. Your tires go where you look.
Get off the brake before you get to the gravel. Tires can go over some gravel without slipping, the soft tire rubber just wraps around each individual rock and grips the pavement just fine. Too many rocks too close together, they will slip. Some tires are much better than others at this. Being on the brake makes any tire much more likely to slip, and makes it harder to hook up again once it finds clean pavement.
Generally dual sport tires or knobbies are much better than street tires. New soft tires are better than old hard ones.
How far will the tires slip? Depends on the orientation of the bike to the gravel. Gravel tends to end up in lines roughly parallel to the road. Just like paint stripes or train tracks, if you put your bike where a tire slipping will take you across the stripe or track, if it slips it's no big deal. When the tires gets to the other side of the stripe, it will hook up again. If on the other hand, the tire slips along the stripe, it will never get to clean surface, never will hook up again. Down you go.
Consider every corner to have gravel until you can see it doesn't, that way you won't be surprised.
tkent02 is online now   Reply With Quote
Old 01-14-2014, 05:11 AM   #14
Aj Mick
Aj Mick's Avatar
Oddometer: 676
My thoughts exactly….. beaten to posting!
Gravel and sand are out there; expect it and get used to it.
there are old motorcyclists and bold motorcyclists
but you seldom meet an old, bold motorcyclist
Aj Mick is offline   Reply With Quote
Old 01-14-2014, 08:24 AM   #15
C/1/509
Oddometer: 5,409
Try not to crash?
C/1/509 is offline   Reply With Quote
Times are GMT -7.   It's 06:56 PM.
