Old 01-14-2014, 10:30 AM   #16
Bar None
Bar None's Avatar
Oddometer: 4,403
Originally Posted by klaviator View Post
Ya beat me too it.
If you don't lay'er down, you might crash
Good one.
Seriously, ride some gravel roads to get some practice in.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Old 01-14-2014, 11:05 AM   #17
eatpasta
Lawnmower Target
eatpasta's Avatar
Oddometer: 10,295
on the Speed Triple; butt pucker and scream like a little girl
on the 525; gas it and grin
We shall not cease from exploration, and the end of all our exploring will be to arrive where we started and know the place for the first time.
T. S. Eliot
Originally Posted by Burnszilla
I was SO high, I could have hunted duck with a rake
Originally Posted by VxZeroKnots View Post
MX stuff isn't my cup of tea, but falling down the side of a mountain is
eatpasta is offline   Reply With Quote
Old 01-14-2014, 11:21 AM   #18
randyo
randyo's Avatar
Oddometer: 1,655
Originally Posted by manfromthestix View Post
Please export this excellent behavior to Virginia! The VDOT sands & gravels the roads here to the point the look like dirt roads by the end of the Winter and then that's it. Yer on yer own until the rain or traffic washes or wears it off.
not all towns in NH have street sweepers, and some towns that do sweep (mine for instance) only sweeps the village roads and none in the rural areas
sand, salt, loose graded gravel, chip n seal, or even snow & ice don't bother me, I just ride according to conditions
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is online now   Reply With Quote
Old 01-14-2014, 11:33 AM   #19
ragtoplvr
Oddometer: 6,044
IF you have low enough speed when you hit the gravel do not clamp down tight on the bars, let her slide and wander a bit. Look where you want to go.
Of course if you have too much speed, I suggest tucking your arms in and rolling, fetal position if you have time.
Rod
ragtoplvr is online now   Reply With Quote
Old 01-14-2014, 01:00 PM   #20
motorat
TBD
motorat's Avatar
Oddometer: 921
in cazadero, ca, the gravel is the road.
easy with the front brake and enjoy the ride.
take a riding class like www.americansupercamp.com and have fun
to ignore the facts does not change the facts
motorat is online now   Reply With Quote
Old 01-14-2014, 01:27 PM   #21
DAKEZ
DAKEZ's Avatar
Oddometer: 19,702
Add a bit more throttle (most of the time)
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ screwed with this post 01-15-2014 at 05:04 PM
DAKEZ is offline   Reply With Quote
Old 01-14-2014, 02:09 PM   #22
Ocky OP
Oddometer: 50
Purely gravel roads are ok, they are pretty uniform in consistency and tires can dig in, but the gravel ontop of the asphalt acts like marbles on a hard floor. The fact the consistency changes so quickly will result in a high or low side. Avoiding by staying in the line of car tires is good but sometimes you can't or you missed it.
Going slow and staying vertical I guess are the only things to do
Ocky is offline   Reply With Quote
Old 01-14-2014, 03:27 PM   #23
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,186
Originally Posted by filmfan View Post
Be aware that you are likely to find gravel and sand and ride accordingly.
This. Learn what it looks like, where it accumulates, and how to avoid it.
They liberally cover the roads with red sand here anytime it snows. It is left everywhere and it is extremely slippery. I've even had cages slide around the stuff when it's piled deep enough.
I find, however, that it only takes a few days for traffic to clear most of it off. I have to adjust my cornering lines to stay in the "tire track" on sweepers and try not to ride on the parts of pavement that car tires don't normally hit, as this as where the sand will be.
I've drifted the rear tire several times on the stuff. I hate it. I've found that if the rear tire goes out under throttle, just holding the throttle steady until you're through it is the best course of action. Chopping the throttle could result in an uncontrolled slide.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-14-2014, 04:26 PM   #24
randyo
randyo's Avatar
Oddometer: 1,655
or sudden grip and subsequent highside
sand, ice, what ever slick surface, best course of action is usually steady throttle, continue your line, be smooth
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
Old 01-14-2014, 04:38 PM   #25
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,123
You need a lot more seat time. It's not rocket science. It'll come if you ride enough.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-14-2014, 05:11 PM   #26
Kommando
Grumpy Young Man
Kommando's Avatar
Oddometer: 7,242
Originally Posted by Ocky View Post
Something that has always been a problem for me is riding over gravel covered asphalt. Where I live doesn't snow a lot but a couple weeks ago it did and there is still significant gravel covering less traveled roads. I have had a couple unfortunate experiences going through a turn and having my rear tire slip(this is after I have already slowed down and am going 20mph or less).
Apparently increasing the traction of 4 wheeled vehicles for a couple days is an Ok trade off for making the roads hazardous for 2 wheeled vehicles for a month or more.
Fit knobbies. Ride dirt. Ride wet clay. Ride bottomless pillowy sand. Get used to riding on wet grass too. Gravel on the road will then seem almost like dry and clear interstate.
Some are guard dogs of the flock. Some herders, search/rescue, or companions. We Devildogs are those, and also retrievers. Hell is our blazing dogpark, our frigid swimming hole. The fallen are our tennis balls. We don't leave the fallen behind, even if the master has to bring them home for us. Semper Fi, my friends.
Kommando is offline   Reply With Quote
Old 01-14-2014, 05:19 PM   #27
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,408
Just remember three things... Floor it, turn left, don't fuck up... no, wait, that's car racin. Learn to ride on the dirt, a lot. if you don't, you'll never get comfortable with it.
Old 01-14-2014, 06:23 PM   #28
Other Bob
Other Bob's Avatar
Oddometer: 423
Pissed Chip seal SUCKS!
*** As if sanding during Winter weren't bad enough, last summer the VDOT came around and chip-sealed the road near our house. I was DISMAYED .
*** It's been 8 months since they did this and it still SUCKS, but it is what it is and I just ride accordingly.
Doug
Michigan's DOT chip-seals quite a bit, particularly on rural roads - right where I like to ride! Pretty much kills the buzz of using that road for a whole summer. Really sucks if you live on that road. Happened to me - TWICE!
Doug, you might be surprised by what makes up the "chip" matrix in that crap. Run a magnetic garage floor sweeper over it and you will find a surprising amount of shreded metal among the concrete chips. Apparently not all recycling crushers have magnetic separators, so at least some rerod gets chipped, sized and sorted with the rest of the concrete.
Since the metal is maleable the little bits get beaten into round'ish ball bearings instead of grippy jagged-edged concrete chips. Ok, ok, so maybe the ball bearing analogy is a stretch ... I'll just stop here.
OP, you will get used to gravel. Stay alert for it, especially in the spring, following thunderstorms, and at the apex of tight right hand corners (where cars will often drop a wheel onto the shoulder and drag gravel out onto the paved surface).
Stay loose, keep calm, carry on.
Bob
Other Bob is offline   Reply With Quote
Old 01-14-2014, 06:53 PM   #29
Other Bob
Other Bob's Avatar
Oddometer: 423
Originally Posted by randyo View Post
*** sand, salt, loose graded gravel, chip n seal, or even snow & ice don't bother me, I just ride according to conditions ***
Nice picture Randyo!
Do you use any 'special' to protect your bike (particularly the electrical system) from the salt? For instance, maybe a light spray of WD40 on the wiring harness, connectors, and bare aluminum cases? It would disperse the water (and the salt brine in it) during a ride, at least for a while.
WD40 does pose some risk of fire, so maybe just a post-ride spray and wipe down after cooling? Another product? It looks like you ride year round, AT-weather-ATT, so I'm nominating you as the guru on this subject.
Thanks,
Bob
P.S. S'not a hijack .. it is rock salt, after all!
Old 01-14-2014, 08:21 PM   #30
Sp4rks
Oddometer: 243
1)Try to not to eat a gravel sandwich
2)Eat a gravel sandwich anyway
3)Pick bike and dignity up off the ground
4)repeat
2002 KTM 125sx:
Acerbis Uniko handguards, KTM Powerparts skidplate, FMF Shorty Exhuast, FMF Fatty Expansion Chamber, Renthal Sprockets, Renthal Chain, Pirelli Hard Terrain tires, SDG Seat, Acerbis and UFO plastic.
Sp4rks is offline   Reply With Quote
Times are GMT -7.   It's 01:55 PM.
