Old 01-17-2014, 07:02 AM   #1
john_aero OP
john_aero's Avatar
Oddometer: 1,173
2004 950 Adventure Suspension stretch
ok been readint his section in the HOW
http://www.ktm950.info/how/Farkels/a...05_s_conv.html
and trying find the need for the spacer he lists from superplush
p/n 50180288
I was looking through parts manuals and from what i can see all i need is the hydro stop and inner tube for forks and the shim rebound for the shock
all cheap enough parts.
so my question is. i happily change oil, seals and spring in my forks including a set of 48mm wp forks for my last bike
so when i go to upgrade my springs if i get the heavier springs as required for my weight, the longer rear shock spring for my weight i should be able stretch my own sspension easily and on the cheep
fair enough it wont be re valved but i can live with that for the mean time
am i missing something hre as seems too easy
i cheked part manuals and from break down there are only 4 different parts for both bikes 1 of which is just the rear spring
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 01-17-2014, 07:06 AM   #2
kinta
Kinta
Oddometer: 153
you will need a nitrogen refill for the rear shock as the rebound shim requires the shock body to be taken apart.
kinta is online now   Reply With Quote
Old 01-17-2014, 07:21 AM   #3
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,422
http://www.advrider.com/forums/showp...5&postcount=23
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 01-17-2014, 07:41 AM   #4
john_aero OP
john_aero's Avatar
Oddometer: 1,173
ok so front should be fine as i reubild them before
rear never done so if gave it to a specalist they prob refill it cheap enough
Old 01-17-2014, 12:44 PM   #5
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Except for needing the correct setup to fill the shock with nitrogen, the shock is actually easier to work on in my opinion than the forks. See if you can get someone who knows how to show you.
ben
______________________________
2013 KTM 990 Adventure Baja Edition
armourbl is offline   Reply With Quote
Old 01-17-2014, 12:54 PM   #6
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,422
I've re-valved my own forks but I'd love to know how to take the shock apart. All I really want to do is put a softer spring on it and change the oil...no special tools required (other than the nitrogen recharge)?
Old 01-17-2014, 03:12 PM   #7
john_aero OP
john_aero's Avatar
Oddometer: 1,173
Saw lad sellibg nitrogen re charge kits here as he had them in garage
Might look it up again and get someonr show me how do it
Old 01-17-2014, 03:48 PM   #8
john_aero OP
john_aero's Avatar
Oddometer: 1,173
motion pro do a nitrogen fill valve and gauge
so need find cheap supplier for nitrogen and a regulator
Old 01-17-2014, 05:57 PM   #9
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
I believe you'll need more than just a regulator. You need a vacuum pump setup as well for the KTM shock. But you might be able to find a local shop that will bleed and charge it for you for a reasonable price and would probably do it while you wait.
ben
Old 01-17-2014, 06:01 PM   #10
armourbl
Adventure Life
armourbl's Avatar
Oddometer: 626
Yep. There really isn't a lot to it to be honest. The bleeding process is harder on the KTM stuff compared to Showa which I have more experience with. But the proper vacuum setup makes it easy. Just have to make the investment.
The thing I like about working on my own suspension is I can service it more regularly. Most of the specialized tools could be had and pay for themselves in just a couple of services. I even buy fork and shock oil in 5 gallon quantities.
Nitrogen tanks are a lot like propane. Initial cost is high to pay for the tank, but refill/tank exchanges are cheap. A small bottle will last you a very long time as well if all you use it for is charging shocks.
ben
Old 01-17-2014, 10:37 PM   #11
john_aero OP
john_aero's Avatar
Oddometer: 1,173
Issue i have is there are about 2 places in ireland that do the work but are not cheap due to low volumes in ireland
Id like learn myself so i can do it anythime on my own bikes and othets
Msy look buting few shocks from breakers dirt cheap to practice on
Times are GMT -7.   It's 04:35 PM.
