Old 01-15-2014, 05:49 PM   #61
COXR650L OP
Oddometer: 1,530
1st Problem
OK so I have run into the 1st problem.
The larger cam bridge bolts will not come out. Am I safe using heat or will it warp the cam bridge?
COXR650L is offline   Reply With Quote
Old 01-15-2014, 11:56 PM   #62
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,316
All of them? Have you stripped them?
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 01-16-2014, 06:02 AM   #63
charlie264
charlie264's Avatar
Oddometer: 8,314
Have you rounded the nuts, allen heads, they shouldn't be that tight...m8's are 18nm and m6's are 10nm....I'd give a impact driver a go.
Old 01-16-2014, 05:19 PM   #64
COXR650L OP
Oddometer: 1,530
Charlie...
Thanks for the suggestion that was a big help, I wish I would have thought of that sooner. They were really in there. Unfortunately a few still stripped out and I had to weld a bolt to the end. Even then they had a difficult time coming out and sheered one of the bolts off! No locktight, so Im guessing they were really cranked in at a previous valve adjustment.
The progress so far:
The rear cams looked fine. The cam carrier had some wear in the journals, but I think it is ok.
The rear cylinder had an obvious head gasket leak, but everything look in good shape. Plenty of hatch markings on the cylinder and the piston skirt looked good.
The rear piston rings end gap was under the .5mm wear limit, coming in about .45mm.
The piston measured 99.94mm, under the wear limit of .93
Everything looked very similar on the front.
The piston spec'd out .94, however the piston rings had much more wear, being over the .5mm (around .51). Im not sure why the front had more ring wear
In the process of pulling the fly wheel and clutch basket to change the timing chains and oil pump pressure spring.
Overall the ending is very clean inside with no signs of crud or build up.
Old 01-16-2014, 05:23 PM   #65
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,850
Looking good Ben, keep it up!
Been trying to ride once a week at least. Utah season is just around the corner though
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 01-16-2014, 05:59 PM   #66
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,423
Nice. Thanks for the pics and thread!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 01-16-2014, 11:19 PM   #67
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,066
Heat wrenches to the rescue!
When I have problems with the cam bolts, I smack it around a little with a big punch. Then just grab it with a big vice grips. 100% success so far.
"Son, you can't do both"
Old 01-17-2014, 05:48 AM   #68
charlie264
charlie264's Avatar
Oddometer: 8,314
The pressure pump valve has been upgraded by KTM, I recently changed mine. The only noticeable difference is that it doesn't use a cir-clip at the base of the spring, KTM say the piston is different to...................
60038010133 PRESSURE PUMP HOUSING CPL.
Also peanuts recommended change the 60034024144 LOCKING LEVER CPL, if the bearing type fails lots of little bearings, the upgraded one has a solid wheel.
Old 01-17-2014, 06:35 AM   #69
COXR650L OP
Oddometer: 1,530
I have cam chain clatter at idle when the bike is hot so I hope a new spring and valve solves the issues (Pydon mentioned the spring being worn in a post somewhere).
What parts fich is the Locking Lever CPL found in? I cant figure out where it is.
Thanks for the help
Edit: Nevermind I found it!
COXR650L screwed with this post 01-17-2014 at 07:23 AM
Old 01-17-2014, 10:10 AM   #70
COXR650L OP
Oddometer: 1,530
Ok so looking at the end support bearing in the clutch cover for the crank, there is some noticeable wear:
Is this acceptable?
Or should I try and replace it, and if so do I need to split the cases to check the other main bearings?
Old 01-17-2014, 10:26 AM   #71
crazybrit
crazybrit's Avatar
Oddometer: 8,554
I know Pyndon replaced his; he told me this was because it failed the "fingernail" test (could feel a groove). There is no wear spec in the manual for this, only for the crank end that rotates inside it.
crazybrit is offline   Reply With Quote
Old 01-17-2014, 11:22 AM   #72
COXR650L OP
Oddometer: 1,530
Ya it certainly has noticeable grooves in.
What is the best procedure for removing the bearing and then installing a new one? Is the special tool from KTM necessary?
Also is this an indication of the condition of the internal crank bearings?
Old 01-17-2014, 11:26 AM   #73
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Special tool to remove and install (it's in the manual page 5-6). Possible any blind puller will work and looks like you could make the installation tool/holder if you have a lathe.
Dunno but I would have thought so as the primary means of support is the case bearings. If it's cutting a groove in the clutch cover support I'd have thought this would indicate that the case support is out of true .... but I'm no expert I'd check the crank end wear also.
Old 01-17-2014, 11:57 AM   #74
charlie264
charlie264's Avatar
Oddometer: 8,314
Thanks for the help
I doubt its the pressure release, pull the cir clip and measure the spring. Make sure you have a replacement cir-clip first...my broke, wasn't an issue as I replaced the whole thing. I'd check/replace the cam chain tensioners and springs. Measure the oil pump within spec.
Old 01-17-2014, 01:55 PM   #75
COXR650L OP
Oddometer: 1,530
I hope it helps. The oil pump was well within spec, however the old spring was considerably shorter than the new one.
So what to do about the crank bearings
Times are GMT -7.   It's 03:21 AM.
