Old 01-17-2014, 12:05 PM   #31
Wonway
KTM Fanboi #2
Oddometer: 440
It also will stop the exhaust from popping on deceleration.
Did you remove the catalytic converter too? If you don't have the SAS system on it could clog the converter.
1994 Ducati 888 LTD #61
2008 Husqvarna TE610
2014 KTM 1190 Adventure R
Wonway is offline   Reply With Quote
Old 01-17-2014, 12:06 PM   #32
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
Originally Posted by unaweep View Post
Ken- what's your thought on removing the SAS? I stripped that stuff off of my 950s but on the 990 I only removed the cannister and left the SAS alone. My understanding, (probably wrong) was that the SAS was not a true weakness like the cannister, but removing it cleaned up all those darned hoses, etc. In otherwords, removing the SAS doesn't really do anything but clean out the clutter.
Thanks for any insight.
For the most part, that's pretty much the case. The Supplementary Air Supply is intended to allow cold air into the exhaust system during over rich conditions to help burn off excess fuel. It's a smog thing but causes no harm.
On the other hand, the 1190's motor is really cluttered and could use some cleaning up... um, for race purposes only of course...
~ Ken
www.powercellperformance.com
PowerCell is online now   Reply With Quote
Old 01-17-2014, 12:07 PM   #33
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 21,335
unaweep is offline   Reply With Quote
Old 01-17-2014, 12:08 PM   #34
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
It's not likely to clog the Cat, but the unspent fuel would serve to cool the cat off which works against it's intended purpose.
I have an Arrow header on it's way to me... without the cat...
~ Ken
Old 01-17-2014, 12:09 PM   #35
unaweep
unaweep's Avatar
Oddometer: 21,335
No cats in any of my bikes.
Old 01-17-2014, 12:10 PM   #36
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
You have the heart of a racer...
~ Ken
Old 01-17-2014, 12:28 PM   #37
Wonway
KTM Fanboi #2
Oddometer: 440
The problem happens when unburned fuel contacts the catalyst and then ignites. This will cause the monolith to melt and block flow. I would not suggest doing this unless you remove the catalytic converter.
I also have a Arrow pipe on it's way without a cat and will be interested to see what you come up with. That is one ugly system that has to go :)
Old 01-17-2014, 01:38 PM   #38
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,053
All this means is that tunes are on the way.....
KTM 1190R...Adventure Beast, 950SE......Desert Beast, KTM 690 Quest...Rally Beast, Husqvarna 501...Trail Beast, KTM 300xc...Woods Beast
Nowwhat is offline   Reply With Quote
Old 01-17-2014, 06:26 PM   #39
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
Coming soon...
photo by PowerCell, on Flickr
~ Ken
Old 01-21-2014, 09:53 PM   #40
Todd-Squad
See Ya, Bye.
Todd-Squad's Avatar
Oddometer: 782
Did you take off the OEM dampner? Or are you running both?
A ride you say? When and Where?
My Favorite Pics
Todd-Squad is offline   Reply With Quote
Old 01-21-2014, 09:55 PM   #41
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
No, the OEM damper is going in a box next to the SAS and charcoal filter.
~ Ken
Old 01-22-2014, 02:31 AM   #42
coloktmGS
Oddometer: 306
So that looks like a scotts rubber mounted sub mount...but the folks from scotts told me they're not building a mount for the 1190 and have no plans to do so...?..
How'd you mount your pin?
coloktmGS is offline   Reply With Quote
Old 01-22-2014, 02:50 AM   #43
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,817
I think that's the coming soon part. Looks like there is room between head tube and tank for a pin mount of some sort, either bolted welded or clamp.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-22-2014, 02:51 AM   #44
Yascher
Yascher's Avatar
Oddometer: 388
Yeah!!! Seems like the tank is on the way of the pin
Yascher is offline   Reply With Quote
Old 01-22-2014, 06:48 AM   #45
PowerCell OP
Manufacture
PowerCell's Avatar
Oddometer: 2,417
We're putting something special together. The factory damper is more of a detriment off road than a benefit. We need an adjustable free-to-center solution.
~ Ken
Times are GMT -7.   It's 09:17 AM.
