Old 01-20-2014, 05:08 AM   #16
scootrboi
scootrboi's Avatar
Oddometer: 1,647
The handbook that came with my bike had a set of charts included for torque, horsepower, hill gradients and gears, fuel efficiency. The most interesting to me was torque. The engine redlines at 5,750, maximum torque is 3,500-4,500, and best fuel efficiency is within that range. At 50 mph I get 80 mpg, at 57 I get 70. 57 is maximum cruising speed and redline. What seemed remarkable to me was the accuracy of the charts on such an old machine. I climbed a long 5% grade on the Interstate in high gear and maintained a minimum of 45 mph, exactly what the chart predicted, max grade and max torque. The engine was in perfect condition with the advantage of synthetic lubricant. I had not intended to be on that section of I-89. I got on one ramp too soon.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 01-20-2014, 05:23 AM   #17
hugemoth
hugemoth's Avatar
Oddometer: 2,980
Halfway to red line on a Ninja 250 would be 7,000 RPM. Red line is 14,000. Middle of the tach would be 8,000 RPM as the tach goes to 16,000. Yes, it's a very over-square engine with a 62mm bore and 41mm stroke. Try riding one at 3000 RPM and you'll get nowhere fast.
If you ride a low RPM bike it feels strange to ride a high RPM bike but eventually you get used to it and it feels normal. I love the sound of my old GL500 V twin at 9,000+ RPM which is where the max HP is.
Originally Posted by Uncle Pollo View Post
what is low revs
middle of the tach?
Old 01-20-2014, 05:29 AM   #18
nskitts
nskitts's Avatar
Oddometer: 3,232
I am gonna start ridin my Harley on the highway banging off the rev limiter at a screaming 5500 RPM
....now the FZ6 I used to ride didn't even wake up until 8,000 RPMs.
"I never regretted any vacation that I took."
--Dad, a few months before he passed.
nskitts is offline   Reply With Quote
Old 01-20-2014, 06:28 AM   #19
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,146
If it isn't leaking oil out the seals, I fail to see the problem. I had an '83 XL185 that would spit oil all over my legs at anything over 55 mph.
2009 Aprilia Dorsoduro 750 (adventurized): http://www.apriliaforum.com/forums/a...893274&thumb=1
High Country Herb is offline   Reply With Quote
Old 01-20-2014, 07:28 AM   #20
OrangeYZ
Oddometer: 611
My KLR vibrated like shit at high revs. 5000 rpm was the limit of me having a good time, and I didn't pass it (about 65 or 70 mph in 5th)unless I wanted to get somewhere fast or needed to not get run over.
My Tiger 800 doesn't vibrate ever. At 70 mph I'd rather be in 4th gear than 3rd, but it doesn't care.
OrangeYZ is offline   Reply With Quote
Old 01-20-2014, 07:40 AM   #21
randyo
randyo's Avatar
Oddometer: 1,742
Originally Posted by ragtoplvr View Post
There is less engine wear and lower fuel consumption at low RPM
Rod
maybe, fuel consumption is more dependent on throttle opening than rpm
RandyO
IBA # 9560
07 VeeStrom
99 SV650
82 XV920R
A man with a gun is a citizen
A man without a gun is a subject
randyo is offline   Reply With Quote
Old 01-20-2014, 07:59 AM   #22
Wraith Rider
Wraith Rider's Avatar
Oddometer: 1,552
Originally Posted by windmill View Post
Low RPMs are less "stressful" on the rider when doing lots of miles.
Vibrations can be fun for a short trip, but when doing lots of miles, I prefer a smooth running engine with as less vibrations as possible. That's why HIGH rpms are less "stressful" to me and consequently I use the upper half or better the upper most quarter (depends a bit on cylinder number) of the rpm range.
"Why not stay in disguise all the time? You know, look like everyone else."
"Because we shouldn't have to."
Wraith Rider is offline   Reply With Quote
Old 01-20-2014, 09:27 AM   #23
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,732
Originally Posted by Idle View Post
Quite simply, they are brick stupid..
They don't understand that the wind resistance increases exponentially the faster you go. Their bike goes just fine at 10 mph in second gear at 2,250 rpms... So 3,500 at 70 mph is ok.
They don't understand that all engines have a sweet spot.
They don't understand that you need to hold the next gear a little longer than the last one as you accelerate.
They don't understand they are lugging their engine riding in top gear around town at 50mph.
They don't understand that the manufacturers put TALL gearing on the bike to pass emissions.
They can't comprehend that an engine can return better fuel economy and a longer service life if ridden at speed at a higher rpm. It goes against everything they "know".
That is all.
Yup.
Old 01-20-2014, 09:49 AM   #24
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,018
Manufacturers don't always get it right.
My 2008 Harley Ultra couldn't effectively use 6th gear under about 75 or 80. Mileage suffered and any incline sucked.
My 2010 does much better due to revised gearing and changes I've made to the power.
Oh and mine can scream down the highway bouncing off the limiter at 6100!
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 01-20-2014, 10:27 AM   #25
Badjuju
Badjuju's Avatar
Oddometer: 334
Nope. Not particularly true for carbed bikes, and certainly not true for FI bikes. An engine is nothing more than an air pump, and other than when under load (say during acceleration) the sweet spot for air:fuel ratio is approx 12:1 to maybe 14:1 for efficient combustion. Even if you're talking carbs, the fuel is drawn from the bowl by venturi, which is largely dependent on RPM at SS cruising. FI controls fuel flow based on a number of parameters, including throttle position, RPM, engine temp, manifold vacuum and exhaust O2 level.
Some people will tell you that slow is good, and it may be on some days, but I am here to tell you that fast is better... Being shot out of a cannon will always be better than being squeezed out of a tube. That is why God made fast motorcycles, Bubba.... Hunter S Thompson, Song of the Sausage Creature
Badjuju is offline   Reply With Quote
Old 01-20-2014, 10:29 AM   #26
DAKEZ
DAKEZ's Avatar
Oddometer: 19,741
They don't stress about their bike revving...
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 01-20-2014, 10:43 AM   #27
DC2wheels
Castle Anthrax troll
DC2wheels's Avatar
Oddometer: 2,660
Engine speed on the highway (65-75 mph) is all over the place, depending on the bike.
Son has an '07 Ducati 800 Supersport that won't get out of its own way in 6th gear at 65- Revs far too low, geared WAY too high, can't accelerate at all. What were they thinking? On back roads, 50 mph or so, he never gets past 3rd gear.
My '92 BMW K100RS revs around 4600 rpms at 70 mph in 5th (5 speed trans), feels ok and will get nearly 50 mpg
'92 K100RS
'12 DRZ400
sugarhillctd on the world-wide K11OG forum
I got my MotoMatters calendar, did you?
DC2wheels is online now   Reply With Quote
Old 01-20-2014, 10:54 AM   #28
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,007
Originally Posted by iamcanjim View Post
Whenever a new bike is introduced, members here wail and go on about how high the bike will be revving at 80, 90 or 100 mph.
I don't get it.
Perhaps I trust the manufacturer too much, but I always figure that they have designed the bike to be at an optimal rpm at 70 mph.
However, it seems that everyone always claims it is 'revving too high.'
Why do we dislike bikes revving high? Is it longevity concerns? Vibration? Noise (that can probably be fixed by putting the stock pipe back on). Or just a subjective aesthetic concern?
It's probably a subset corollary of the Cruiserface phenomenon. Go down the road blatting potato-potato-potato all day.
--Bill
'73 R60/5 Toaster
Old 01-20-2014, 12:08 PM   #29
windmill
windmill's Avatar
Oddometer: 4,084
Originally Posted by DAKEZ View Post
Really?
I always thought that was a major selling point for Harleys, trading top end HP for low end torque making for a more relaxed ride at freeway speeds.
I think you're being intentionally obtuse.
If I'm so off base, why are touring bikes and cruisers tuned for low rpm torque rather than high rpm HP?
"Take care, sir," cried Sancho. "Those over there are not giants but windmills".
windmill is offline   Reply With Quote
Old 01-20-2014, 12:12 PM   #30
Kommando
Kommando's Avatar
Oddometer: 7,389
I don't get it.
You trust the manufacturer too much. Engineers make mistakes. So do R&D departments. So do parts mfrs. So do assembly departments. Why do you think vehicle recalls exist?
Kommando is offline   Reply With Quote
Times are GMT -7.   It's 01:03 AM.
