Old 01-28-2014, 05:20 PM   #1
390beretta OP
Oddometer: 1,192
The left turn lane
I live and ride a lot in PHX. AZ. Lately I've noticed a lot of cagers using the left turn lane as a "safe place" when they want to turn left. They typically dart into the left turn lane when traffic coming from their left permits. Then, coast/drive slowly, sometimes blinker on/sometimes not, indicating their intention to move to the right when possible.
I have two questions: 1. What is your strategy for handling this type of situation? 2. Is this maneuver legal where you live? It used to be illegal here, but I've never seen it enforced; not sure if it's currently legal.
My typical response when this happens is to move to the far right of my lane (assuming I'm in the lane next to the left turn lane and check my right mirror to see if I can escape to that lane should the person encroach on my lane, thus evading. If my right lane is not clear, I typically cover the brakes and slow down.......but this move still pisses me off.
I came into this world kicking, crying and covered in someone else's blood. I have no problem leaving the same way.
390beretta is offline   Reply With Quote
Old 01-28-2014, 10:29 PM   #2
WhichWayNow
WhichWayNow's Avatar
Oddometer: 157
Here in Idaho, you're only allowed to drive 150 feet in the center turn lane. I encounter people doing the same thing all of the time.
The really dangerous situation is when I'm trying to turn left and one of these morons is driving in the center lane. They're usually looking at the traffic coming from behind them and not where they are going. I've had to ride on past where I was planning on turning to avoid being run over.
WhichWayNow is offline   Reply With Quote
Old 01-29-2014, 07:02 AM   #3
TinDog
Oddometer: 57
Illegal in Utah
Sure, it happens all the time here. All too often the center turn strip is used as a defacto merge lane to get into traffic from the opposite side of the road, but Utah traffic law doesn't allow for even a bit of merge type use. When entering the road, the law here calls to simply cross the strip and into your lane; if you can't pull into traffic without using the center strip, you shouldn't pull into traffic at all per our traffic law.
I think most of the illegal use I see is from ignorance of the law, rather than deliberately breaking the law. My overly cautious model citizen spouse received one of her two lifetime traffic warnings for using the center lane to merge - she had no idea.
TinDog is offline   Reply With Quote
Old 01-29-2014, 07:20 AM   #4
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,827
This is becoming prevalent here, in Chicago-land. It makes me mad, too. I try to make myself as visible as possible (slight weaves) and keep an eagle-eye on the cage. Some cage drivers are observant and look for an opening, others just floor it and everyone else be damned.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 01-29-2014, 08:26 AM   #5
RogueClimber
"Tacticool"
RogueClimber's Avatar
Oddometer: 952
I just plan on them moving across all the lanes to wherever I am and them trying to run me over.
Of course this also goes for the asshats taking right turns and crossing all the way to the inside lane too.
"To the everlasting glory of the Infantry!"
Diligentia -- Vis -- Celeritas
Rob
Save $5 on SmugMug-- zpTBLRFvcME2c
RogueClimber is offline   Reply With Quote
Old 01-29-2014, 08:57 AM   #6
jmq3rd
Oddometer: 256
Luckily Texas is one of those states where u-turns are legal unless indicated otherwise, so if I can't get across a busy street, I just turn right and do a u-turn at the next opportunity.
And no, it doesn't stop everybody else from using the left turn lane as a merge lane.
jmq3rd is offline   Reply With Quote
Old 01-29-2014, 04:41 PM   #7
Jamie Z
Jamie Z's Avatar
Oddometer: 7,701
SOP in this area. Doesn't bother me at all. I do it too.
If I'm on a road and someone is turning left into the suicide lane, I just watch carefully to make sure they aren't pulling into my space. Same as I would do for any car potentially in my path.
No idea if the move is legal or not. I've never seen anyone stopped for it, and I've never been stopped for it.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is offline   Reply With Quote
Old 01-29-2014, 05:01 PM   #8
ttpete
Rectum Non Bustibus
Oddometer: 5,825
Jamie
When I'm pulling out of a driveway turning left onto a multi lane road that has a center left turn lane, if I can't get a 2 way break in traffic, I'll wait until I can get across into the turn lane and wait there until the other side of the road is clear.
15 BMW RnineT
09 Kaw Versys
Old 01-29-2014, 05:33 PM   #9
390beretta OP
Oddometer: 1,192
Yeah, that's what I usually do as well. But, I almost always wait until I can clearly get across both lanes and into the one I want to be in. Thanks for the response.
Old 01-29-2014, 05:45 PM   #10
Dranrab Luap
E-Tarded
Dranrab Luap's Avatar
Oddometer: 31,365
Same here, but I obviously yield right of way to any vehicles in the middle turning lane. If i need to accelerate in it, I'll do that do, but only for very short periods of time. A lane intended to be used by cars going in either direction takes extra caution and courtesy.
Dranrab Luap is offline   Reply With Quote
Old 01-29-2014, 06:19 PM   #11
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,629
I do that too, and many drivers down here do something similar.
That center turn lane can get congested this way. Not only are the left-turning cars using it but also the cars from the two cross-traffic directions are using it as a "safe haven". I don't think it's illegal, but it's not specified as a legal maneuver. I always consider the left-turning traffic on the main roadway as having the right-of-way and the entering cross-traffic being subordinate.
A gray area in our imperfect world.
--Bill
'73 R60/5 Toaster
Old 01-29-2014, 06:26 PM   #12
ttpete
Rectum Non Bustibus
Oddometer: 5,825
If you really want something to think about, we had 3 lane highways years ago. The center lane was the passing lane for both directions.
15 BMW RnineT
09 Kaw Versys
Old 01-29-2014, 06:46 PM   #13
henshao
Bained
henshao's Avatar
Oddometer: 607
I had no idea what the hell you were talking about until someone mentioned a center turn lane. "Lately I've noticed a lot of cagers using the left turn lane as a "safe place" when they want to turn left." Center turn lanes are not terribly common here, we have lots and lots of thick medians.
The situation so others confused like myself can understand: cars pulling out from parking lots or intersecting streets, turn left and go into the center turn lane, instead of waiting until there's room to turn left into the travel lanes where they belong.
When they do this in right front of me I try to change lanes if possible, if not I let them go ahead of me. There's no great way to deal with the whole "do they see me will they merge into me."
henshao is offline   Reply With Quote
Old 01-30-2014, 11:57 AM   #14
390beretta OP
Oddometer: 1,192
Just had a chance to ask a police officer about whether this move is legal: He said no, it's not legal. I asked if police enforce it: He said if we're around and see it; which I think is BS. Not to badmouth the cops, they've probably got more important things to do. Any police officers care to chime in?
Old 01-30-2014, 12:52 PM   #15
ttpete
Rectum Non Bustibus
Oddometer: 5,825
The idea behind center turn lanes is to get left turning traffic out of the travel lanes. And it works well for that purpose. In MI, most all multi-lane roads with no center median use center turn lanes.
Michigan originated what's known as the "Michigan left turn". Rather than explain it, here's a link: http://en.wikipedia.org/wiki/Michigan_left
http://www.michiganhighways.org/inde...igan_left.html
This is an advantage for motorcyclists because there are no vehicles to turn in front of a rider.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 09:53 AM.
