Old 01-23-2013, 04:23 PM   #61
dhally
Hammerhead
dhally's Avatar
Oddometer: 2,343
Originally Posted by HydroDog View Post
My $.02 is your on the right track with this idea.
If you built your roof construction with a continuous soffit and ridge vent, you would have more than enough ventilation to dry out any condensation that might develop in the air space between the foam board and tin.
It is a pole building - there will be plenty of ventilation above the insulation!
WR250R
Sherco 300i
Tiger 800 - FOR SALE
dhally is offline   Reply With Quote
Old 01-23-2013, 04:45 PM   #62
trailrider383 OP
867-5309
trailrider383's Avatar
Oddometer: 3,290
Exactly!!! And I live in the desert. Low humidity.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-29-2014, 05:38 PM   #63
trailrider383 OP
867-5309
Oddometer: 3,290
Time to update this thread. I am amazed it has almost 10,000 views. Don't you people ever ride? I finally started in December and I have the main part of the project done. The tedious cutting of styrofoam to fit around all the obstacles. When it warms up I will tape all the seams.
Old 01-29-2014, 06:27 PM   #64
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,645
Looking good! I am considering doing the same in my shed. But NOT when it is -18F. Gonna be a springtime job.
siyeh is offline   Reply With Quote
Old 01-29-2014, 07:47 PM   #65
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Originally Posted by trailrider383 View Post
What I do now is go out and crack a window and fire up the space heater for 10 or 15 minutes til the temp comes up to around 50 and shut it off til I get cold.
50F is only 18 deg. above freezing. How can you work in such cold? Long underwear and a parka?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 01-29-2014, 10:28 PM   #66
trailrider383 OP
867-5309
Oddometer: 3,290
50F is comfortable with a coat and something on my bald head. We were riding and camping last month with daytime temps in the teens with 20-30 mph winds at the sand dunes. It got down to -1F overnight. See this thread: http://www.advrider.com/forums/showthread.php?t=931730
Old 01-30-2014, 09:10 AM   #67
13.1
Shaken not Stirred
13.1's Avatar
Oddometer: 388
ahhhhh....you dang "flatlanders" are funny
shoot, it was 53F for the high yesterday at my place outside of Show Low,
and I was out in the garage (unheated) in Shorts and a Long Sleeved Pullover Shirt working from 11am tip 4pm
When you have eliminated the impossible
whatever remains however improbable
must be the truth..
13.1 is offline   Reply With Quote
Old 01-30-2014, 09:35 AM   #68
farmerstu
Oddometer: 497
what I'm wondering is what the heck keeps the roof up? it looks like a huge distance between rafters, and with the purloins setting on top of the rafters instead of between them and the way purloins are spiced . looks weak. hope it never snows where you are. and the winds stay down.
also i would opt for some sort of vented heating system. a knipco is not meant for an enclosed space.
farmerstu is offline   Reply With Quote
Old 01-30-2014, 05:05 PM   #69
trailer Rails
trailer Rails's Avatar
Oddometer: 4,167
Um, yea, our mama's taught us how to dress. The heat is in the tools, the more you work, the warmer you get. You only get cold when you stand around and drink too much.
trailer Rails is offline   Reply With Quote
Old 01-31-2014, 05:48 AM   #70
arcanum
Oddometer: 317
Looks like I am a little late to the discussion-- at least as far as the ceiling project goes.
I suggested that a friend of mine try a housewrap underneath the siding of his pole barn. It was just outstanding in how the drafts shut down in the space. I am thinking that housewrap under rigid foam would provide a nice level of insurance and might eliminate the necessity to tape the joints of the rigid insulation.
Some guys place fan fold insulation beneath the roof to cut down on condensation,but unless you install bird stops on the rafters between the purloins, those little buggers will ruin it in a hurry
So if you are anticipating using rigid sheet insulation on a ceiling or are concerned about adding a vapor barrier to the cold side of the insulation,consider that the housewrap lets the moisture out and provides a superior barrier against air infiltration. The stuff is just as tough as nails and there is also joint tape available. A 9x150' roll is a little more than a hundred dollars and money well spent
I am also doing a bathroom in one of my rentals that will get rigid foam sealed with spray at the joints between the joists [treated] because of the high moisture conditions beneath the floor. Therefore, fiberglass insul is out. Then either tar paper or synthetic tar paper to protect the underside of the plywood from condensation,in the event it should occur. there is a ceramic tile floor and thick mud shower going in,so the floor is permanent with only one chance to do it right
It is not a perfect solution,but it will easily outlive the rest of the house
arcanum is offline   Reply With Quote
Old 01-31-2014, 05:59 AM   #71
arcanum
Oddometer: 317
Old 12-24-2014, 10:04 AM   #72
trailrider383 OP
867-5309
Oddometer: 3,290
I guess I need to put a final update on this thread. Here is my home brewed ventilation. I removed the foam plugs under the metal roofing. Cut a piece of aluminum to form the screen pieces. Put some silicone in the hole and shoved them in. Added two Whirlybirds on top. Should work, although I'm sure some "expert" will post up how I should have done it.
Big difference in interior temps summer and winter. Don't have to run the heater any time at all to get it up to 50F for winter projects. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Old 12-24-2014, 10:08 AM   #73
trailrider383 OP
867-5309
Oddometer: 3,290
The link I added for the Whirlybird didn't work on the previous post and this POS won't let me edit the post. Here it is:
http://www.amazon.com/Lomanco-BIB-12...ine+Ventilator
Old 12-24-2014, 10:11 AM   #74
dhally
Hammerhead
dhally's Avatar
Oddometer: 2,343
Lookin' good! Nothing like some insulation to help the heater work. May want to keep an eye on those bird screens - I have had birds get into places I thought was impossible.
WR250R
Sherco 300i
Old 12-24-2014, 10:17 AM   #75
trailrider383 OP
867-5309
Oddometer: 3,290
Birds suck. I agree. I finally got my tractor, rv, pickup and bbq sealed up to keep the bastards out. Nest making, shitting nuisances. I think they are worse than mice.
Times are GMT -7.   It's 07:27 PM.
