Old 06-27-2013, 07:32 PM   #166
_cy_
Oddometer: 6,177
Originally Posted by Butters View Post
It looks like Pak-meister still sells them albeit at $80 (he stepped in at about page 8 as a re-seller):
http://www.cobraheat.com/EZ-Pull-Blo...tem_p_160.html
hmmmm $89 + shipping = about $100 ... what to do?
it was a no brainer at $60 ... but at $100, think I'll use my existing climbing pulleys
Old 06-30-2013, 02:38 PM   #167
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
No one has any in stock anymore, and ADV engineering is now defunked.
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline   Reply With Quote
Old 07-04-2013, 09:25 PM   #168
ScienceOfDirt OP
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,722
Let me contact the guy who made them, and see if I can get another run done. No promises.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 07-04-2013, 10:44 PM   #169
mint julep
mint julep's Avatar
Oddometer: 185
Good luck & thanks.
2012 Triumph Tiger 800 XC
mint julep is offline   Reply With Quote
Old 07-04-2013, 11:13 PM   #170
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,106
Any of you guys use one to get out of a situation you couldn't get out of on your own?
My experience with it is:
Plus - they really are light and they really are strong and small.
Negative - they have a large rolling coefficient of fiction. I'm just guessing here but I think you only end up with about a 2:1 advantage though of course will always pull 5:1. If any one is really interested I can try and get one of those luggage scales and get a more accurate number.
I can say it's uber important to keep all ropes and pulleys lined up perfectly though that is tough to do in rough situations.
I ended up getting a larger set that I'm guessing gives closer to a 3.5:1 advantage in a 5:1 configuration.
Sent from my SAMSUNG-SGH-I847 using Tapatalk 2
rickypanecatyl is offline   Reply With Quote
Old 07-04-2013, 11:18 PM   #171
rickypanecatyl
Oddometer: 1,106
Oops this was the pic I meant to post! When bridges break on you in the middle of nowhere often that's an opportunity to use your block and tackle!
Old 07-05-2013, 03:06 AM   #172
_cy_
Oddometer: 6,177
how big of a pulley system did you end up going with?
pictures?
Old 08-03-2013, 12:56 AM   #173
mint julep
mint julep's Avatar
Oddometer: 185
Just checking for any updates from the makers or from ScienceOfDirt.
Old 08-05-2013, 10:57 AM   #174
StuInFH
Oddometer: 418
Cobra Heat order
I found the block and tackle set on CobraHeat's website. Ordered on 7/17, got Order Confirm on the 19th and cc was hit then. I asked for an update last week and got an Order Cancelled email this a.m., no explanation.
Guess I'll have to go with the pulley and a Z-drag system if we strike out on another run of the block and tackle.
StuInFH is offline   Reply With Quote
Old 08-05-2013, 07:45 PM   #175
SportFaller
Oddometer: 668
I called several weeks ago and they said they had none in stock, and they are no longer in production.
Bikeless in WY
Old 10-11-2013, 09:40 PM   #176
mr. thumbs
mr. thumbs's Avatar
Oddometer: 1,118
Anything similar out there on the market?
mr. thumbs is online now   Reply With Quote
Old 11-15-2013, 02:39 PM   #177
Adanac rider
The Great Gazoo
Adanac rider's Avatar
Oddometer: 171
Dodging pain
BestRest products has some innovative stuff, not cheap... but then how much would you pay to avoid a hernia?
Adanac rider is offline   Reply With Quote
Old 01-29-2014, 07:52 PM   #178
jlw
Oddometer: 16
new producer
I would like to have a compact block and tackle just like the ones formerly produced by Adventure Engineering.
I might be able to get a local machinist to do a run of them. I was thinking UHMW spool on a stainless shaft in a aluminum house. I would use
7/64" Amsteel spec'd at 1400 lbs minimum strength.
No doubt the cost would be reduced if they were made in a batch. I am hoping to get the cost around 100 per set.
Let me know if there is still interest in a product like this.
This post is just to gauge interest at this time. Will start new thread if this turns out positively.
jlw is offline   Reply With Quote
Old 01-29-2014, 09:05 PM   #179
danman
tumbling tumbleweed
Oddometer: 174
Interested.
Want to get a ball park on price and size. I don't think it has to be as small as the EZ pull, also looking to get a better advantage than 2:1, if possible. Would be great to have a complete package of pulleys, carabiners, and rope, with enough strength to move an 800GS or Triumph 800XC.
Also please post in this thread if you start a new thread, I am subscribed here and don't want to miss if you start a new thread. Others may be subscribed here as well. Good luck and thanks for looking into this for us.
2009 Kermit Chair, Black
2011 Kermit Leg Extensions & Cup Holder, Silver
2013 Kermit Table, Natural
danman is offline   Reply With Quote
Old 01-29-2014, 09:09 PM   #180
crazybrit
crazybrit's Avatar
Oddometer: 8,554
Well I agree with the "ball park" on price/size part but I'm more interested in as small as possible for trailbike applications where the chances of needing to haul are higher due to the terrain difficulty .... though I guess there are probably riders here skilled enough to ride gnarly single track on a 800GS
Originally Posted by danman View Post
Interested.
crazybrit is offline   Reply With Quote
Times are GMT -7.   It's 09:42 AM.
