Old 02-11-2014, 03:35 PM   #16
trailer Rails
trailer Rails's Avatar
Oddometer: 4,065
Call some tool rental places and ask for a pipe defroster. Most places do not carry them. You'll have to do lots of calling. When you do find one, it will be basically a small welder with hundreds of feet of cable. I had a 1" buried copper line that was frozen solid, this machine thawed that pipe in 5 minutes.
trailer Rails is offline   Reply With Quote
Old 02-11-2014, 04:47 PM   #17
_cy_
Oddometer: 6,266
got two of these and have never had to use it. note it's dangerous to use a welder unless one knows specifically what type welder and what settings to use. there's been fires caused by using welders to thaw pipes.
_cy_ screwed with this post 02-11-2014 at 05:13 PM
Old 02-11-2014, 07:05 PM   #18
cwc OP
Oddometer: 934
What is the current rating on those units?
The local guy told me they use about 300 amps and are taking 2-7 hours to thaw a pipe.
Charlie
DR350 It'll get you there
My Ride Reports Here
cwc is offline   Reply With Quote
Old 02-11-2014, 08:16 PM   #19
_cy_
Oddometer: 6,266
Trindl Thermotron has two settings, 200amp and 300amp
200 amp setting puts out AC voltage at 3volts, 300amp setting puts out 6volts AC.
have seen all sorts of funky setting on welding forums including reports of fires. safer to rent one instead of using a welder. unless you are able to duplicate spec's above.
Old 02-11-2014, 08:53 PM   #20
rustycager
rustycager's Avatar
Oddometer: 591
Is this a bad time to open a how to change a leaky flapper thread?
No water is better than water backing up. Spent a bit of my childhood learning that. Grease traps in the summer are hard to forget.
2004 DRZs
rustycager is offline   Reply With Quote
Old 02-12-2014, 04:26 AM   #21
cwc OP
Oddometer: 934
Thanks for the info.
I'm not sure how I'll proceed yet, still considering just waiting.
Charlie
Old 02-12-2014, 05:39 AM   #22
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,165
MN is coming out of the freezer next week!
Welders causing fires? Pipes must get pretty hot. Arcing!
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. screwed with this post 02-12-2014 at 05:49 AM
D.T. is online now   Reply With Quote
Old 02-25-2014, 09:17 AM   #23
D.T.
One wheel wonder...
D.T.'s Avatar
Oddometer: 11,165
My boss is having an issue with his pipes. It's so f'n cold up here the frost line is going way down into the ground!
How low does the water temp go down before you have to worry? 35 degrees at the tap?
Old 02-25-2014, 09:51 AM   #24
Benesesso
Benesesso's Avatar
Oddometer: 9,898
No, you don't have to duplicate the voltage. That will be a function of the pipe's resistance and the amps.
Start with ~50 amps and see what happens.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 02-25-2014, 10:21 AM   #25
mcma111
mcma111's Avatar
Oddometer: 12,249
How's that spring thaw working out for you???
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 02-25-2014, 11:27 AM   #26
cwc OP
Oddometer: 934
FYI the frost is now 62 inches down near Rochester (MN).
I have heard (didn't read it on the internet so I don't know if it is abslutely true) that one should be working the problem when the temp at the tap is initially 40.
A friend that lives near Bemidji was seeing about 35 but after running it for a while it got above 50. That was from a well.
It might not get that warm if you have city water.
In MPLS IIRC water is free so you could just let it run.
Charlie
Old 02-25-2014, 11:31 AM   #27
cwc OP
Oddometer: 934
It lasted about a day. This week in southern MN the highs will be around -2
Charlie
Old 02-26-2014, 07:12 PM   #28
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,628
We are telling our customers when the water temp hits 37 let it run
Seems to be working
siyeh is offline   Reply With Quote
Old 02-26-2014, 08:32 PM   #29
cwc OP
Oddometer: 934
Seems to be working
The local utility in a nearby town suggested this and estimated it would add about US$120/mo. to the water bill.
Of course that is probably cheaper than any thawing or repair would be unless you do it yourself.
Charlie
Times are GMT -7.   It's 06:58 AM.
