Old 02-27-2014, 08:19 PM   #16
toates89 OP
Oddometer: 215
Originally Posted by Soldier311 View Post
On a DR350? Will they work without purchasing longer cables?
I am wondering the same thing.
toates89 is offline   Reply With Quote
Old 02-27-2014, 08:23 PM   #17
toates89 OP
Oddometer: 215
I am looking at the kx high bend for the dr350
KX High Bend 31.50" 4.25" 3.07"
Old 02-27-2014, 11:52 PM   #18
PalePhase
Humour Noir
PalePhase's Avatar
Oddometer: 824
I'm not a dirt rider but my Interceptor came with Gen-Mar risers, and in 3 1/2 years of riding it, I have had no problem with it. My mechanic favors Heli-bars since they preserve the original steering geometry, and he thinks my VFR is a little twitchy -- not that I've noticed, but I don't ride too aggressively (just not a smart thing when you're riding through a herd of Expeditions, Tahoes, and Sequoias.
“Fools learn from experience. I prefer to learn from the experience of others.”― Otto von Bismarck
1995 Honda VF750CD
2002 Honda VFR800
PalePhase is offline   Reply With Quote
Old 03-02-2014, 11:08 AM   #19
FloorPoor
Oddometer: 710
ATV Hi bars(moose brand) on my KLR did wonders for riding comfort, and I only paid $25 for them. For my commuting and long highway sections I adjust them back for an easy, comfortable reach, and when I get to the rough stuff it only takes about 30 seconds to adjust them forward and up for very comfortable stand up riding. I played around with adjustments and found the positions that are most comfortable, then marked the bars so there is no guess work when moving them back and forth. I would recommend replacing the stock bar bolts with high strength stainless steel bolts. Then they wont break, rust, or strip out easily.
One other mod that made stand up riding much better was some wider foot pegs.
"You can have anything you want, but not everything you want."
"There's nothing like that fresh tire feeling "
FloorPoor is offline   Reply With Quote
Old 03-02-2014, 05:28 PM   #20
sperz1
UnStudly Adventurer
sperz1's Avatar
Oddometer: 989
Sorry for the late reply. Yes, they work with the stock cables. No longer cables required!
It takes a lot of water to make dual sporting look this hard.
2015 Harley-Davidson FLTRX
1998 Suzuki DR350se
sperz1 is online now   Reply With Quote
Old 03-06-2014, 08:12 AM   #21
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
The biggest problem with risers is the very long bolts required. When coupled with very strong bars, and a crash, the force transmitted through those strong bars can break a bolt(s) off or worse, trash the upper t-clamp . A good case for cheaper, more bendable handlebars. You can get home with bent bars.... not so great if the bars are no longer attached to the upper T-clamp. You think new bars are expensive, try buying a new upper T-clamp!
buls4evr is offline   Reply With Quote
Old 03-06-2014, 08:18 AM   #22
James Adams
Misplaced
James Adams's Avatar
Oddometer: 9,645
Not all risers work this way.
James Adams is offline   Reply With Quote
Old 03-06-2014, 08:55 AM   #23
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,861
Whether you raise the bars using risers or taller bars, if you raise them the same amount, the moment from the end of the bars to the clamp will be increased the same. The only way you're going to break something is if it was too weak to begin with or overtightened. I guess if you have to overtighten bar risers because the clamp is not as effective that could contribute but that's a flaw in the clamp, not an intrinsic result of using a bar riser.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 03-07-2014, 07:14 AM   #24
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
My point here is that a combination of a very strong bar and risers causes a bigger twist at the point of mounting than the T-clamp was designed for. In most cases the 4 bolts securing the bar are pretty close together. You could even make the case that the increased leverage caused by stronger bars without risers has that same effect. We are talking about twisting leverage in 2 directions when you fall, up and back. A lot of force is transmitted to those 4 small bolts. They bear most of the brunt of that twist as well as what they bolt into.
Old 03-11-2014, 09:48 AM   #25
James Adams
Misplaced
Oddometer: 9,645
It seems like breaking the bolts in a crash would be preferable to breaking anything else, as the bolts are easily replaceable.
Old 03-12-2014, 09:37 AM   #26
Thanantos
Ride hard.
Thanantos's Avatar
Oddometer: 3,666
Originally Posted by sperz1 View Post
I have no experience in this.....
But, ATV Hi bend bars on the DR are the Bees Knees!
Yup, that's what I did on my DR350. Looks great, functions well and was only $50.
2013 V-Strom
Thanantos screwed with this post 03-12-2014 at 09:45 AM
Thanantos is online now   Reply With Quote
Times are GMT -7.   It's 05:48 PM.
