Old 03-12-2014, 08:47 AM   #1
lookaught OP
Loner Extraordinaire
Oddometer: 197
Countershaft sprocket bolt dimensions? Anyone know the stock size?
The bike I bought had a used, bent, class 8.8 (which is the equivalent of a Grade 5...) bolt installed by a BMW dealer in place of the OEM counter shaft sprocket bolt.
I would like to order a replacement in my order with McMaster Carr, but am not sure of the proper dimensions and I'm not near my bike to measure. I seem to recall it's an M10 (or maybe M8), but I don't know the proper length or whether it should be flanged or not. The closest BMW dealer is 4 hours away, so I can't just pop over and order one.
So if anyone knows this info, sharing would be appreciated!
The bolt that came out...
Aprilia SXV 550 supermoto
F800GS 30th - sold and replaced by... a 2010 F800GS!
CRF450R
Solo Ride Pennsylvania to Anchorage, Alaska and back 2011
Two Ape supermotos take on the Dragon
lookaught is offline   Reply With Quote
Old 03-12-2014, 09:37 AM   #2
sarathmenon
Oddometer: 1,014
IIRC, it's M8 for pre2010 and M10 post 2010. My 2012 has an M10 FWIW.
sarathmenon is offline   Reply With Quote
Old 03-12-2014, 09:45 AM   #3
lookaught OP
Oddometer: 197
Dammit, I have a 2010 so I guess it could be either. I suppose I'll have to wait to measure the temporary replacement I put in when I get home.
Any idea if the oem is flanged or not? My bike had two washers, one was a centering washer the other was a spring washer. I'm guessing I could use either a flanged or non-flanged, but would like to order the appropriate one if someone knows.
Thanks for the input.
CRF450R
Old 03-12-2014, 10:01 AM   #4
itsatdm
itsatdm's Avatar
Oddometer: 4,935
The stock bolt is not flanged, at least on the 2009 model, and the 2 washers are stock.
Old 03-12-2014, 10:13 AM   #5
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,197
http://www.maxbmwmotorcycles.com/fic...5&rnd=04302013
Chapter 23, part 23. Pics, description.............SCREW - M10X35
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 03-12-2014, 10:42 AM   #6
lookaught OP
Oddometer: 197
Oh wow, I didn't realize those parts diagrams are listed online.
Thank you very much!
CRF450R
Old 03-12-2014, 11:05 AM   #7
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,197
Both Max and A&S BMW have a parts fiche on their site. Max's seems better but sometimes A&S will have more info. I just cut and paste PN's for my email order at the local Dealer so parts boy doesn't get all frazzled and get me an airhead part.
That and when you forget what bolt goes where after an all nighter, you can get the dimensions online to sort it out.
Old 03-13-2014, 04:01 PM   #8
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
LOL So true! However, if you ever get to Hermy's BMW along I-78, their BMW parts guy seems to have memorized half the bolts, and can recognize the other half if you show one to him!
Fred
FredRydr is offline   Reply With Quote
Times are GMT -7.   It's 05:36 AM.
