Old 03-26-2014, 08:05 PM   #1
avc8130 OP
Oddometer: 1,599
Extra Parts After Starter Torque Limiter Update?
I helped a buddy do the starter torque limiter update on his 950 last night, but the kit seems to have an extra part we can't figure out where it goes.
The kit had the new side cover, new torque limiter, new idler gear, new gasket and a new hose clamp. All of that makes perfect sense.
In the baggie with the new hose clamp was a bolt. Where does this new bolt go?
Sure would be nice if instructions were included...
ac
avc8130 is offline   Reply With Quote
Old 03-26-2014, 08:19 PM   #2
scudrunner82
combustion addict
scudrunner82's Avatar
Oddometer: 2,618
Hey get out of this thread you outcast! Orange only here. Move along.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is offline   Reply With Quote
Old 03-26-2014, 08:25 PM   #3
avc8130 OP
Oddometer: 1,599
This IS an orange thread!
Of course it's about a PROBLEM...
This thing is tying up my lift!
Oh...btw...to add insult to injury, the oil is milky. Guess that means the whole right side of the bike needs to come apart for a water pump seal/shaft job?
ac
Old 03-26-2014, 08:57 PM   #4
scudrunner82
combustion addict
Oddometer: 2,618
ac
Only problem with my orange bikes seems to be keeping the front wheel on the ground
Can't help you with the extra bolt you have. I'm still new with the whole LC8 thing.
I do know however with the older LC8s the weak point on the engine is the water pump seal and shaft. I've heard its pretty easy to change though, sounds like you have more wrenching to do
Old 03-27-2014, 05:29 AM   #5
avc8130 OP
Oddometer: 1,599
You've clearly never worked on a 950.
Old 03-27-2014, 07:45 AM   #6
AdvRonski
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 713
What size is the bolt?
It may be to replace the one that fastens the idler shaft to the side cover.
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 03-27-2014, 08:30 AM   #7
avc8130 OP
Oddometer: 1,599
I thought about that. But that all came pre-assembled on the new cover. It is definitely too short to be a new bolt for the stator or the cover/case interface.
I know this is going to sound dumb, but "about an inch long". I realize it is metric, but I forgot to measure it and don't have it at work with me.
ac
Old 03-27-2014, 03:37 PM   #8
avc8130 OP
Oddometer: 1,599
Now w/ Pic!
That's the "extra" bolt.
ac
Old 03-27-2014, 04:03 PM   #9
AdvRonski
Oddometer: 713
That looks like a 6x16mm bolt, and the only one I see in the parts diagram is the idler shaft bolt.
It is pretty sad they can't put that info in the box with the parts.
Ronski
Old 03-27-2014, 04:43 PM   #10
ST4s
Oddometer: 50
Extra bolt
avc8130, That is just too funny. When I did my torque limiter replacement a number of years ago the same question came up. Where does this extra bolt go. I asked a senior KTM tech some time later where it should be installed. His response... it is just an extra bolt they put in the kit to confuse the installers. My bike has never had an issue with the bolt uninstalled.
Cheers
ST4s is offline   Reply With Quote
Old 03-27-2014, 04:50 PM   #11
avc8130 OP
Oddometer: 1,599
Cheers
Thanks! I'll chuck it in the bolt bin and forget about it forever.
ac
Old 03-27-2014, 04:55 PM   #12
scudrunner82
combustion addict
Oddometer: 2,618
ac
You should put it on your Yamaha might make it go faster.
Old 07-11-2014, 07:12 AM   #13
Kiwi Pete
Kiwi Pete's Avatar
Oddometer: 49
Quick question - I've just ordered a new torque limiter (60040017000) from ebay rather than the entire kit.
It looks to me like you need the idler gear as well, can someone please confirm?
Apologies if this has been answered elsewhere.
Cheers,
Pete
Kiwi Pete is offline   Reply With Quote
Old 07-11-2014, 07:19 AM   #14
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,467
http://www.ktm950.info/how/Orange%20...r_upgrade.html
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 07-11-2014, 07:24 AM   #15
ADVill
Oddometer: 609
It goes on the clutch side... Inside joke.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Times are GMT -7.   It's 03:25 AM.
