Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 02-03-2014, 10:51 PM   #136
trustme OP
trustme's Avatar
Oddometer: 985
Another Photo Essay
Team Winston was finally back on the track at Taupo
Adrian & I discussing the finer points of something
Lets put it into practice
Those 32 mm carbs needed a fair bit of tuning so Saturday was spent sorting jetting with the help of a Triumph guru who was pitted next door
Sunday & we were good to go, had a great dice with a Laverda as I've already mentioned. Between his box full of neutrals & suspect swingarm bushes & my high rev miss we were pretty even
last lap was close but no cigar
Eye Candy
Seriously quick Trident side car
Seriously rough but also quick & well prepared, looks can be decieving
It's running a standard motor , ' yeah right '
This runs at the pointy end of post classics
Says it all really
The lengths some people will go to to avoid helping to pack up
Bike is now ready for the Classic Festival at Hampton Downs
trustme screwed with this post 02-03-2014 at 11:44 PM
trustme is offline   Reply With Quote
Old 02-03-2014, 11:45 PM   #137
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,687
I think Vinces Guzzi revcounter is understating whats been spent on that....
Last time I saw it was at the BS and I don't think he did many races, looks like 4 races last season. Like a lot of the fast bikes, fast and fragile.
here is the times.
http://www.marktime.co.nz/results/nz...ister/14/02/01
best I have done on the long track is 2:09.
Voltaire screwed with this post 02-03-2014 at 11:52 PM
Voltaire is offline   Reply With Quote
Old 02-04-2014, 12:28 AM   #138
trustme OP
trustme's Avatar
Oddometer: 985
Best I got was a 2:12. The motor is starting to free up & feels good, I need to sort the high rev miss. I need to get balls . I know I can go under 2:10.
A year off has made me very rusty.
Old 02-04-2014, 10:27 AM   #139
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,629
Great photos, the main reason I go to races is to watch and listen to these old beauties being run!
Te Hopo is offline   Reply With Quote
Old 02-10-2014, 12:16 PM   #140
trustme OP
trustme's Avatar
Oddometer: 985
Classic Festival
The usual suspects were rounded up
Since Taupo the previous weekend I had been pretty busy , Retorqued the head but did not have time to do anything else so the miss was still a problem.
First practice on Friday exposed another wee issue . ' Old Tight Arse ' had reused the nyloc the secures the clutch basket just once to often, no, probably 10 times too often. The whole shooting box came loose, rebuilt the clutch , nothing loctite could not fix, ready for Saturday
Good to go
Before you ask , that petrol tap leaks , it glassed into the tank so the fix is not that simple, will have to fit a second tap
Sid [ Adrian ] diced all weekend with a standard but well ridden Beemer
Volty hunted Harleys
Trustme chased a top end miss
Sometimes others got in the way
Some riders need lists to remind them of simple shit. by the end of the weekend that list resembled Tolstoy's War & Peace :
Beware the lurking Photog
Numnumnum
We all went round & round , nothing broke , no one fell off, what more could you ask for, .............. except for a Pazon ignition which I'm about to order.
Unfortunately the camera died so not so many photos this time
Old 02-10-2014, 01:22 PM   #141
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,687
Sure was a good weekend. Watching you with your Triumph has been right handy the last two nights in the shed, got Mr T120v head off and motor turning over right nice. Makes a change from checking tyre pressures.
Old 02-10-2014, 01:31 PM   #142
trustme OP
trustme's Avatar
Oddometer: 985
There are a few bits & pieces in the shed like a wiring loom that might be handy. If you are going deeper there are timing gear pullers etc & a Haynes manual you can borrow. Don't need it anymore , I know it inside out & back to front.
My nightmares are the Haynes Triumph manual
Old 02-10-2014, 03:06 PM   #143
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,687
hmmmm second hand Lucas wiring loom.... do you have any Lucas Smoke
Old 02-10-2014, 03:12 PM   #144
trustme OP
trustme's Avatar
Oddometer: 985
Brand spankers , new , pristine, untouched, unfucked with , virginal even. Smoke comes as an extra
Old 03-27-2014, 03:24 PM   #145
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,687
Trustme....Help.....I'm trapped in a shed surrounded by Jerries....one attacked me with a metric spanner ...
Old 03-28-2014, 12:09 AM   #146
trustme OP
trustme's Avatar
Oddometer: 985
https://www.google.co.nz/url?sa=t&rc...FAu9o3F4lEjBBA
I'll pick it up tomorrow
Until then put your tin hat on & use your initiative
trustme screwed with this post 03-28-2014 at 12:15 AM
Old 05-30-2014, 03:05 PM   #147
trustme OP
trustme's Avatar
Oddometer: 985
It's been a while ,I'm a slack bugger, here is an update
After HD I decided to do a couple of mods. I or more correctly Volty completely rewired the bike & fitted a Pazon ignition in the hope of eliminating the high rev miss.
I had been advised to increase the length of the inlet tract
Standard
The mighty $200 Myford earns it's keep
Job Done, not the best pic but you get the idea
Off to Taupo , no Adrian or John so it was a little lonely but the bike had to be good now.
Dismal Fail
Would barely run on the left pot . I was befriended by Pete, he had raced TZ's back in the day, we spent the weekend fiddling with carbs & ignition to no avail. It ran great for 2 laps in one race then started to run like garbage again
Pete & I flummoxed , maybe I should stick to Ipods
The one bright spot, took the Ty , the girls had fun
It was a disheartening weekend , I made contact with Mr Dyno & dropped Winston off during the week.
Winston came back a different bike & I was $900 poorer.
The Pazon pickup sensor was faulty, it took him a while to find it . You would think with a lost spark ignition if it fired on one cylinder it would have to fire on the other. Bike had been jetted too rich , he got a reading of 52HP at the rear wheel .
Mr Dyno was quite complimentary, some of these things don't feel nice on the dyno but this motor feels strong & wants to rev. There is more power in there with some exhaust & inlet mods but go race it as it is.
I entered the HMCC winter race
The usual suspects turned up
We had Mike on his Norton along as well
Unfortunately Mike days was very short, the drive side crank case split during practice
My practice was short & came to an ignominious end
A combination of wet track & cold tyres had unceremoniously dumped me on my arse . Pete was in attendance again & we got to work on repairs.
A nice man from the Red Devil team produced files & knocked the brake lever into a usable state
" I better find the scrutineer "
" I am the scrutineer " Says the nice man & whacks the checked sticker on the bike
Cheers Swarfie / Neville , I'm a bit slow connecting the dots
First race was pretty rough just getting confidence back
Some people think watching grass grow is more interesting
Have you ever seen a cat look impressed
Mean time back on the racetrack Adrian went on his winning way
Volts did his best ever lap
Trustme got around in one piece
Pete gave invaluable assistance, he is more methodical then me , checking tyre pressures & temps before & after each race, taking engine temp readings & checking battery voltage
Sometimes we just talk stuff
Finally a race day where the bike ran good
My wife laughs at us in a nice way , she finds us amusing , the racing is almost secondary to the camaraderie of tinkering with old bikes. It does seem to bring out the best in people. Hmmmmm
The gearbox does have a false neutral that is bloody annoying, I think I will take it to Graeme Cole to sort out , I am unskilled in the black art of Triumph gearboxes & there are some mods you can do to improve things.
All in all , progress, happy happy joy joy.
trustme screwed with this post 05-30-2014 at 08:32 PM
Old 05-30-2014, 06:20 PM   #148
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,598
You need to lower the footpegs on the TY.
motu is offline   Reply With Quote
Old 05-30-2014, 08:37 PM   #149
Padmei
enamoured
Oddometer: 3,739
What a story - it had ups & downs,spills & thrills.
I'm just going out now to increase the intake on my bike - seems the thing to do these days
Padmei is online now   Reply With Quote
Old 05-30-2014, 09:08 PM   #150
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,598
There is a formula to work it out, same as exhaust theory. About 12 inches for a Triumph from memory. Made my bike peaky at the time. I had an 8 stud alloy head (T110) someone had modified with a plate across the ports with carb stud placing, and some long extentions....I used 389 monoblocks with a chopped float bowl. I prefered a single carb - 1 1/4 SU made power all over....and it would idle.
Times are GMT -7.   It's 12:49 PM.
