Go Back   ADVrider > Riding > Regional Forums > Australia
Old 04-01-2014, 05:42 AM   #13966
kezzajohnson
kezza
kezzajohnson's Avatar
Oddometer: 1,711
Originally Posted by rvt View Post
When I replaced mine (also from VSM) I drove all the outer races all the way in. Looks like it needs a tweak. Really should read the manual and not guess.
I'm guessing the special tool is flat, so pushes the inner and outer race together in the same plane. Sound right? So it would stop when the inner race contacts the spacer.
Yeah, sounds right. I too have been driving the outer races using a socket of the same diameter and then backing one off a bit. I didn't like the idea of driving them using the inner race because that would probably damage the bearing. Flat round tool sounds like the go, like you say, that contacts the inner and outer race and drives the bearing in evenly until the inner race hits the spacer. Why wouldn't Suzuki just machine the hub to the exact dimensions?
KezzaJohnson Blue 06 DR650se,Yellow 06 DRZ250
Website: http://www.territoryon2wheels.com
"May the Road Never Rise to Defeat you..."
kezzajohnson is offline   Reply With Quote
Old 04-01-2014, 06:41 AM   #13967
CCCC
Oddometer: 325
How do you guys back it off?? By tapping the inner race from the other side??
CCCC is online now   Reply With Quote
Old 04-01-2014, 09:18 AM   #13968
Big Willy
two dementional
Big Willy's Avatar
Oddometer: 2,273
Can't remember whether the DR wheels have a circlip to locate a bearing but if it does, this is the bearing that should be knocked in first.
Start by tapping the outer race of the bearing in a circular motion with a small hammer until it is flush with the bearing housing of the hub.
Grab the biggest socket you can find something like a 30mm and placing it on the outer race of the bearing... tap that also in a circular motion until it seats all the way home. Put the retaining circlip in.
Spacer in and do the other side exactly the same way until it goes no further.
Test for a nice smooth turning of the bearings by putting your finger inside a bearing and twisting it. If the spacer is too loose, the RHS bearing will need a gentle tap in even further...gentle because you don't want to shift the LHS bearing again.
If it is too tight and the bearings are binding and hard to turn, tap the centre of the LHS bearing sharply to displace the RHS bearing slightly.
Check at the finish that the circlip isn't bending outwards trying to get out of it's groove
He has a vairwee good fwiend in Wome you know
Big Willy is offline   Reply With Quote
Old 04-01-2014, 11:49 AM   #13969
ER70S-2
ER70S-2's Avatar
Oddometer: 7,271
Yes to the red highlight. Why wouldn't Zuki machine exact dimensions: the inner spacer might compress incrementally after dozens of reuses, so the hub can't be exact.
No need to back off (as I just recently figured out). I use a 1/4" thick washer, with the O.D. just a bit smaller than the outer bearing race and a threaded rod. The inner race stops when it contacts the spacer and the outer race is, at the same time, in perfect alignment with the inner race.
For instance (although this is the cush hub):
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 04-01-2014, 02:42 PM   #13970
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,356
I'm not keen on hitting the inner race. Was taught to never do this to bearings, can damage the balls/races slightly and cause trouble later.
Think I'll leave them for now, replace them before the next big trip. $55aud down the drain though.
Cheers, RVT
This week's ride: http://share.findmespot.com/shared/f...Vcz6Icqrhsbbpq
rvt is offline   Reply With Quote
Old 04-01-2014, 10:18 PM   #13971
BergDonk
BergDonk's Avatar
Oddometer: 3,930
I have some aluminium discs the right diameter and a length of threaded bar so goes in just like the book, easy. Disc side first is the easiest way to remember it IMHO. Simultaneous contact with both inner and outer races is best.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 04-02-2014, 12:46 AM   #13972
kezzajohnson
kezza
Oddometer: 1,711
discs
+1 that BergDonk. Might have to make up some for myself for the future.
Old 04-02-2014, 03:15 AM   #13973
gavo
Slacker
gavo's Avatar
Oddometer: 1,876
I use a socket or old outer bearing shell to tap new bearings in and remember to freeze you r bearings first and warm the hub, just in the sun will do. Because each time you hammer a bearing in it takes just a little bit of metal from the hub, do it enough times and the bearing will move in the hub.
gavo is online now   Reply With Quote
Old 04-02-2014, 03:44 AM   #13974
philth
philth
philth's Avatar
Oddometer: 6,401
bash it in with a rock
i must not post hairy buttocks
philth is online now   Reply With Quote
Old 04-02-2014, 05:13 AM   #13975
Itchi
Oddometer: 7
Just bought my DR650se
have my full license but always stuck to my beautiful honda spada after a chain of tiny 50 and 250cc bikes to learn on.
just upgraded to my dr650se bought second hand for 5K.
2009 model with some adventure gear.
can't wait to get it serviced and inspected then im out.
Itchi is offline   Reply With Quote
Old 04-02-2014, 07:11 AM   #13976
rvt
Big Fat Trail Bikes
rvt's Avatar
Oddometer: 1,356
Good choice Itchi!
Now you need to bling it up, so you can tell it apart from the rest of ours.
See you on a Perth ride sometime.
Cheers, RVT
Old 04-03-2014, 09:18 PM   #13977
TRTN
Oddometer: 32
Originally Posted by Benz-in-Oz View Post
A faulty kill switch would knock out power to ignition and starter, but shouldn't kill the rest of the electrics. Side stand and clutch lock out switches are prime suspects on these bikes too, but shouldn't take out the lights. There is a main fuse that runs everything plus a fuse for each headlight beam, so it wont be a fuse unless it's blown all of them at once. Probably have to trouble shoot it by trial and error,
Originally Posted by rutsthematter View Post
Check the earth connection and go over all the wiring checking for chafing rubbing. Check fuses and let us know what you find.
Turns out it was probably corrosion / a loose connector somewhere in the bundle behind the headlight. It failed mid ride after a short break and i couldn't find the fault. RACV dropped the bike at a local bike shop who took about an hour to figure it out.
I took most of the wiring apart on the trail but just had bad luck i suppose. It was probably related to dropping the bike in a bog hole on a trip over Christmas. Think i'll get some dielectric grease or contact cleaner on the weekend and 'fix' all the connections i can find. Bypassing the clutch and sidestand switches is also well overdue.
TRTN is offline   Reply With Quote
Old 04-05-2014, 11:59 PM   #13978
Thumper Dan
Oddometer: 329
Iphone
I know this is off topic and may get a butt kickin' but has anyone tried the Hema maps on the iphone?
Went camping out on the DR and could have used some quick GPS assistance (the papeer one got wet )
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 04-06-2014, 12:11 AM   #13979
CCCC
Oddometer: 325
I've got them on the Ipad. Like them a lot but some are not as up to date as I would have liked
Old 04-06-2014, 12:40 AM   #13980
live4daride
Oddometer: 129
Was that from Coogee? I test rode it a last weekend, well set up machine.
"too wet around here, we're gonna wimp out, and save it for a more suitable day. Think I'll go have a coffee and talk about what an adventurous rider i am!! "
TDM 900, Bonneville, Jawa 897 Speedway, WR250f
live4daride is offline   Reply With Quote
Times are GMT -7.   It's 10:45 PM.
