Old 05-29-2012, 09:50 AM   #16
75monza
75monza's Avatar
Oddometer: 343
+1
This is exactly what I did. You can strip all the plastics and the tank from the bike and not have to undo any wiring at all.
I am weird. I use my glove box for storing little things like my parking pass and holding onto my phone or what not if I need to charge it.
Originally Posted by mOtO_man View Post
I put in on the right of the bike. Had to cut out some plastic on the inside of the right fairing for it to fit. The benefit of it being here is that it can easily be accessed and viewed. It did not go in the glove compartment because all the wires would have had to be removed to remove the glovebox....a pain for doing maintenance.
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 01-26-2013, 01:00 PM   #17
EZ300
EZ300's Avatar
Oddometer: 1,088
Wiring up my fuzeblock and don't know which wire to tap into for switched power.
Anybody got a pic or can you point me in the right direction?
.... Is Acc 2 only hot when key is on?
EZ
EZ
AMRA
2007 KTM 990 Adventure
2010 KTM 530 XC-W Six Days
www.rockstarsmc.com
EZ300 screwed with this post 01-26-2013 at 01:13 PM
EZ300 is online now   Reply With Quote
Old 01-26-2013, 06:53 PM   #18
batovif
batovif's Avatar
Oddometer: 46
EZ
ACC2 is switched and ACC1 is always on.
batovif is online now   Reply With Quote
Old 01-28-2013, 05:11 AM   #19
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
With 2 accessory circuits already built into the bike, I'm sorta wondering why there's a need for a fuse block?
Is this just a BMW thing?
Can a mod move this to GSpot?
Sporting Wood is offline   Reply With Quote
Old 01-28-2013, 06:05 AM   #20
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,690
When I bought the bike the Fuzeblock was in the glove box. As has been mentioned this can be a pain when disassembling if you don't have connectors on everything.
I moved it to nestle on top of the airbox, between the H2W pre-filter and the frame on the right. It has been there for tens of thousands of miles with no problems. It is such a good fit I haven't used anything to attach it.
When I need to get to it, this location is easier for me to get to than it would be if mounted on the headlight/fairing bracket, though that was my second choice.
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 01-28-2013, 07:41 AM   #21
EZ300
EZ300's Avatar
Oddometer: 1,088
It simplifies the wiring process when running multiple accessories.
Gps, additional lights, heated grips, heated clothing,...
BMW thing?,...
EZ
AMRA
www.rockstarsmc.com
Old 04-02-2014, 08:18 AM   #22
Dan Diego
Oddometer: 916
In mounting the FZ-1, am I good in using the available aux 2 (switched) wire to trigger the relay?
I plan to splice into it (vs running a wire back to the brake light) unless one of you electrical gurus has a better idea.
There are two rules for being successful in life.
Rule 1: Never tell others everything you know.
Triumph Rocket III Touring, KTM 990 ADV
Dan Diego is offline   Reply With Quote
Old 04-03-2014, 02:12 AM   #23
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 504
mounting
work in progress, but this is what I'm doing:
used the aux switched too to switch the power.
Mainline directly from pos plug right side of the bike (still needs a single connector attached).
Running the ground to the frame.
Connects:
  • heated grips
  • aux lights
  • gps
  • tripy (electronic roadbook)
  • hazard light blinkers controller
  • 1 spare atm
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 04-03-2014, 04:33 AM   #24
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,695
I put mine in the glovebox. That has worked out fine. The only concern that I had was working around the wires in a "field" repair. But even that has worked out. Here I am stripping the bike in Colorado to fix the carbs. I just used a strap to hold up the glovebox as I worked on the carbs. No real problem at all.
Orangecicle is online now   Reply With Quote
Old 04-03-2014, 07:56 AM   #25
75monza
75monza's Avatar
Oddometer: 343
Those are the wires that I connected to for switched power. Never caused me any problems. I ran a wire to the battery for the direct power for the unit.
Been working this way for about 2 years now with no issues. I'm still happy with my FZ1.
Old 04-03-2014, 08:01 AM   #26
Dan Diego
Oddometer: 916
Thanks to 3 ADVers who'd installed the FZ-1, I found a pretty easy way of mounting my FuzeBlock behind the headlight. Easy peasy.
Thanks for the help, guys!
Dan
Times are GMT -7.   It's 03:34 PM.
